How low is too low?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by swaggingprius, Nov 7, 2011.
  1. swaggingprius
    swaggingprius Member
    88
    29
    East Coast
    Hello,
    I used to post under another tag, but my email got hacked. I am back. As a quick recap of what I have done to my car since I bought it in Feb is:
    Homelink Mirror
    Pioneer Nav/DVD
    Weathertech mats
    PC Foglights
    HIDs for headlights
    Five Axis
    Kyowa Racing Wheels
    and most recently, Tanabe Coilovers:cheer2:
    It is low, really, really low. Even at the shop they were like; "I didn't know a Prius could look this awesome." :)
    In any event, I took it for a spin and oh, oh. I am rubbing! It happens at the parkways, when I am doing over 65 as the surface becomes more jumpy. I spoke to the shop and they said they will readjust and bring back up a bit. Hopefully, you can tell from the pics, but I believe that front is lower than the back. You can tell since the gap in the front practically is zero between the tire and the fender, while in the back the gap is even around the tire and fender.
    You be the judge
    Thanks!
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    Are you rubbing the inner fender liner or your front lip?
    After removing my front bumper cover I failed to screw the mounting clips correctly so it caused my inner fender to pop out a bit. When I would hit the corners hard or hit a bump on the freeway the tire would rub the liner. It eventually wore a hole in the liner before I could fix the problem. Get yours fixed before you end up with a hole or broken front lip. :)
  3. swaggingprius
    88
    29
    East Coast
    I believe that the rubbing is the tire with the inner fender liner. :(
    Even though it has only been a few miles and a few rubs, I think that the damage to the front lip would be much harder if the rubbing was with front lip. So, far the damage to the front lip is no different from previous pre-coilover boo-boos
    Oh, and yes rubbing also occurs with hard cornering (as expected).
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    Either way, raising the front end a little bit should fix the problem. The car looks good. :)
  5. swaggingprius
    88
    29
    East Coast
    For those with front lips, especially with Five Axis, what is the clearance between the ground and the lowest point of the lip? :confused:
    What did you use to drop the car? :p
  6. macmaster05
    macmaster05 Senor Member
    4,050
    730
    It doesn't look that low, I would switch to LP tires.
  7. andino
    andino Senior Member
    746
    551
    San Jose, CA
    Too low is relative. Personally, I don't think your car is low at all yet. I feel like my car sits like a monster truck on htechs.
  8. fuzzy1
    10,647
    Yes, low is relative. My stock version is almost too low to visit dad, and did scrape on rocks several times on the way to a local trailhead.
  9. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    I gotta add something here: My Prius II, stock, rubs the ground whenever I enter my garage at home and leave my garage at the office. It's that plastic cover under the car and it is really beat up. And now you lower the car even further? I think lowering the car looks nice. But I'd be looking for car parts along the road if I lowered my Prius.
    Mike
  10. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Your car looks good, I think lowered looks good generally. And like you said, with coilovers, just bring it up a bit.
    How is it in and out of driveways, ramps, etc.?
  11. sc24vr6
    sc24vr6 Member
    185
    52
    socal
    from your pics I dont think you will having rubbing problem, maybe adjust your front shocks a little more stiffer?? my riding heights is lower then yours and I dont have any rubbing issue from tires only lip keeps kissing ground :)
    BR
    Robert
  12. F8L
    19,011
    4,083
    Grass Valley, CA.
    The rubbing could be a result of wheel offset which is why yours don't rub. Just an idea.
  13. sc24vr6
    sc24vr6 Member
    185
    52
    socal
    But from his pic wheels look not aggressive at all, thats why I guess is his shocks not stiff enough :)
    Maybe OP should post his rims spec with tires size
    Robert
  14. macmaster05
    4,050
    730
    ouch. diss.
    Reminds me of the time I went swimming with my friends once. It was the end of summer and I wanted to show off my abs. When I got there though, they were not impressed.
  15. swaggingprius
    88
    29
    East Coast
    View attachment 33121 Wow! So many variables. Choosing lowering springs only makes a stiffer ride and wears the shocks quicker. Going for coilovers still gives you smoother ride or less stiff ride, approximately less wear and tear on shocks, but now it might not be stiff enough to hold up.
    So, the wheels and tires are 17 in 206 Kyowa Racing with 215x45x17 Goodyear tires. I don't know about offsets.
    For driveways and ramps even before the coilovers I had to come in an angle or I would get some type of contact lip with ground. Especially true with my driveway, so since then I park on the street.
    Hopefully these before and after pics provide better detail
    Thanks for the comments
    BTW, what makes wheels look more aggressive?:confused:
  16. swaggingprius
    88
    29
    East Coast
    Do you have pics of your car?
  17. swaggingprius
    88
    29
    East Coast
    Never mind, 5 min later I remembered your car is that black awesomeness and it's huge thread.
  18. F8L
    19,011
    4,083
    Grass Valley, CA.
    Have you located the spot they are rubbing on?
    I 'mgoing to guess they are rubbing on the inner fender liner, in front top outside edge. :)
  19. swaggingprius
    88
    29
    East Coast
    I do think it is the fender, but here is a pic before the readjustment of the coilovers. Later tonight, I will take for a spin and hopefully it will look cool and no rubs.
    Next step will be to make it look more aggressive, still need to figure out how. :D
  20. F8L
    19,011
    4,083
    Grass Valley, CA.
    Sometimes people use the word aggressive to describe how low a car sites or how the wheels sit within the wheel wells. Your wheel offset looks good. Some prefer to have the wheels poke out a bit but from an aerodynamic standpoint this is not what you want. Having the wheels poke out will disrupt the side airflow and increase coefficient drag as well as frontal area. Better to keep them ever so slightly tucked behind the fender.
