Using PIP As A Generator
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by El Dobro, Oct 29, 2012.
  1. El Dobro
    El Dobro A Member
    7,102
    3,282
    Chassis ground would be my bet.
  2. lensovet
    2,615
    496
    Burlington, NJ
    The instruction video for the inverter says that apparently it should come with cables for hooking it up
  3. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    Red = +, Black = -, Green = Ground.
  4. lensovet
    2,615
    496
    Burlington, NJ
  5. Corwyn
    2,171
    659
    Maine
  6. El Dobro
    El Dobro A Member
    7,102
    3,282
    This is the one I used.
  7. lensovet
    2,615
    496
    Burlington, NJ
    "12 V of current"
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    What if you install a heavier 12 volt battery that has the amp hours to handle 6000 watts? And let the PIP charge that? Maybe the ICE will cycle longer due to the larger amp hours.
  9. lensovet
    2,615
    496
    Burlington, NJ
    interesting, so the 1500W model doesn't have the connecting cables. wonder why.
  10. lensovet
    2,615
    496
    Burlington, NJ
    assuming you can figure out how to stuff it in that space…
  11. El Dobro
    El Dobro A Member
    7,102
    3,282
    Mine came with them, but they're not very long. I didn't want to keep the inverter in the car.
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    since it's just for emergencies you could just set it in the cargo area temporarily
  13. El Dobro
    El Dobro A Member
    7,102
    3,282
    Didn't he used to sell Shamwow towels?
    priuskitty likes this.
  14. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    lensovet likes this.
  15. El Dobro
    El Dobro A Member
    7,102
    3,282
  16. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Tracksyde and usbseawolf2000 like this.
  17. lensovet
    2,615
    496
    Burlington, NJ
    I guess that partly explains the high cost
    I've had simulated sine UPS devices for years and they have been okay…
  18. El Dobro
    El Dobro A Member
    7,102
    3,282
  19. The pip is designed to specifications that keep the whole system in balance. You cannot change one component without affecting the rest. Such as your house, with 500 volt light bulbs your house would be much brighter and cheerier, right? Or might something fail?
