ATF fluid changes ARE Required.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill Norton, Dec 15, 2012.
  1. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    experimentation
  2. Bill Norton
    Bill Norton Senior Member
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    And follow the correct procedures? Which is never change the fluid...
    We're beating a dead horse with this partial faithfulness to Toyota's recommendations.
    I believe Toyota's ATF WS is just some generic ATF, (not even synthetic), that they can market at a big profit.
    I believe there are vastly superior ATFs out there.
    Which transmission is harder on its ATF. The Prius or the biggest dam pickup Toyota sells while hauling the biggest dam trailer allowed up the mountains?
    The moral of this thread is:
    JUST CHANGE IT. TOYOTA GOT IT WRONG IN THE MANUAL FOR THIS MODEL.
    As said, over and over, this info needs to be made available to Prius owners.
    I don't care what ATF you use. I like the measurably best lubricants in my vehicles.
    Fostel, Dino33ca and edthefox5 like this.
  3. Mendel Leisk
    42,122
    ^ There are two points of contention: the fluid to use, and when to change. I don't see why one screw up deserves another. I change it, more frequently, but don't see your leap of logic that this justifies using unspec'd. fluid. But, it's your car, LOL.
    And FWIW, the Toyota stuff cost me $9.32 a liter. The time before I bought Honda auto transmission fluid it was close to $20 per liter.
  4. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    Yeah, right, Lots of Luck! ;)
    Did you see the post in this, or a related thread, where other car manufacturers that use this licensed
    Hybrid Gearbox design call out using their own house-brands of ATF?
    This is not some mysterious automatic transmission. It's just a box full of little gears and bearings and two MGs.
    It needs a clean lube, (that meets basic specs of course).
    Just change it.
    That walmart ATF meets the spec and says it is equivalent to ATF WS.
    I prefer to use the highest quality lubes available. Not some mysterious generic house-brand of ATF...
    That's how I sold my '89 Geo Metro with 290k and still not consuming oil between 10k changes.
    And my buddy had a '86 Accord with 1.4 Million Miles on it before retiring it.
    Mobil1 all the way in both cars. No major engine work on either cars.
    But forums are really just a collection of opinions, right? And everybody and has one, right?
    And they're all like a.. h... , they all stink, right?
    Only time will tell if I totally destroy my gearbox by using the highest quality lubes, right?
    frodoz737 likes this.
  5. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    OK Fellow Tech/Maintenance Geeks,
    I did a 3rd ATF change since getting my '10 in November of '12 with 108k miles on the car.
    I used Mobil 1 ATF for the second change and and just got the analysis back after 7k miles.
    I added a magnet to the drain plug last time. It had a light covering of black dust-like particles, too fine to make out individual specks.
    Only I screwed up by trying to control the flow coming out of the drain hole using the magnetic drain plug. (I added a 'super magnet' to the stock drain plug, see #1 post.)
    I was trying not to let the flow go full blast and get some into the analysis bottle.
    When I brought the drain plug out into good light to inspect it, I could see that the particles on the magnet had been disturbed. I suspect I knocked some of the particles off the magnet as the the flow was going into the sample bottle.
    This is probably giving me more big particle count in the analysis.
    I won't do that next time.:(
    The attached report shows my particle count is better but not good, IMO. Better luck next time with the sample process...
    You can definitely see the different recipe of additives and viscosity of Mobil 1 ATF.
    This time I'm using Redline D6 ATF.
    It has a similar viscosity to ATF WS, but it is not some unknown-origin house brand of ATF.;), just stirring up the faithful...
    Oh, and I forgot to mention an important issue.
    I had the car accurately leveled and didn't spill a drop and it took all 4 qts.
    Others have reported the same thing. 'The Critic' said he added "a few ounces more than 4 qts" and it finally started to flow out of the fill hole.
    Thank you Toyota for being so vague on this subject also.
    Dang those * asterisks *,, from the owner's manual:
    Fluid capacity* 3.5 qt. (3.3 L, 2.9 Imp.qt.)
    Fluid type Toyota Genuine ATF WS
    *: The fluid capacity is the quantity of reference. If replacement is necessary,
    contact your Toyota dealer.
    Page 563
    They only missed this important spec by more than 0.5 qt.
    This important info should be included on all threads concerning ATF changes.
    Fostel, Dino33ca, pjksr02 and 4 others like this.
  6. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Agreed. This is how much I had left in my 5th qt.
    However, as mentioned earlier, the fluid does expand when it warms up, so up to 10mm under the fill hole is acceptable. As for how one would measure their fluid level to be 10mm under the fill hole - that is simply beyond me.
    iPhone ?
    Fostel and Bill Norton like this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Bill that looks much better and was worth the early change. Seems like alot of aluminum wear. They must have used more aluminum in the gear set metallurgical formula & running gear to save weight. Anything to improve gas mileage!
    And you can see with the pretty new WS fluid the pack that's on board. Alot of Calcium & Boron for TAN mitigation and that's about it.
    Use Redline D4 next time and change it at 25,000 miles. Redline now specs D4 for the Gen II and I think its the same for your 3. I'm almost due for my 25,000 change on my 07 and will have that tested and will post it. Should show the same excellent wear numbers as my last 25,000 sample.
    Good job!
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    :ROFLMAO:
  9. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    xs, yeah, I'm pretty sure aluminum can not be part of the gears metallurgical recipe.
    I suspect somewhere in the gearbox, thrust bearing loads spin against the aluminum case.
    Although, a friend says he has read about Honda using "dissimilar metal welding" on the front subframes of their new models. I say Bo Ogus... We can put that welder over there next to the Lead to Gold converter !:D
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    You are right about it not being in a transmission gears metallurgical recipe except maybe in trace amounts in some strange alloy that would have no effect on density.
    You wouldn't see it in automotive transmission gears, but, there is dissimilar metal welding and it is getting into some automotive applications. The forms I am somewhat familiar with (I had it done about 20 years ago but never did it myself) are forms of friction welding, often called inertia welding because inertia is often used to generate the friction.
    It's an interesting process
    Friction welding - Wikipedia, the free encyclopedia
    Once the tooling is setup it's relatively inexpensive so I wouldn't be too surprised to see it in automotive sub-frames. It would be a good way to add some hard points to an aluminum structure.
  11. edthefox5
    10,096
    4,836
    Clearwater, Florida
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The :ROFLMAO:was in response to
    which is still :ROFLMAO:
    Nitriding is a surface hardening process that has nothing to do with that. The gears are still a steel alloy without a significant amount (~0%) of aluminum.
  13. bwilson4web
    16,472
    Good data. So let's look at these between 112k miles and 420 miles:
    Column 1
    0 [th]Fe[th]Si[th]Al
    1 [tr][td2]14%[td2]17%[td]22%
    Source: Marked Prius oil 5-1-13.pdf
    Earlier tests on virgin Type WS have shown there is no Fe, Si, or Al. So these metrics give a clue as to the carry forward . . . the dilution of the virgin oil by the oil that can not be drained. Interesting how the specific atomic weights seem proportional to the carry forward. It suggests the lighter material will tend to layer on top and denser on the bottom of the transaxle sludge.
    Our first drain and sample at 5,000 mi showed metalic and sealant particles. By draining early, we cut down how many times these debris particles passed through gears to be crushed to powder. The 112K and 420 mi samples gives a clue as to how bad it can get. You'll notice the larger particle population is rapidly going down.
    The V100 (viscosity at 100C?) shows a pattern I had not seen before in the earlier Prius, a viscosity increase. I suspect this may be a by-product of the particle load but it has me scratching my head . . . and a little curious.
    Our NHW11 and NHW20 samples have shown a history of decreasing viscosity, a 'shear down'. But here we are seeing evidence of increased viscosity. It would help if we had the virgin, Mobil ATF viscosity at 100C to determine if the "7.0" is an increase or decrease.
    I remain confident that one of the best things we can do with our new Prius is to change the transaxle oil with the first engine oil change, at 5,000 miles. The second should probably be sooner rather than later. My viscosity trend suggests 15,000 service miles or around 20,000 miles. Thereafter, longer change intervals make sense but I don't have metrics suggesting the period.
    I am seeing some cold-soak behavior in my wife's ZVW30 suggesting the low temperature viscosity may have increased. The first-trip of the day, loss of speed in "N" seems higher than I remember after our second transaxle oil change. Fortunately, I have the oil needed for the next change and just waiting on a weekend to make it happen and send the sample off. Before I do, I'll try to record some metrics with our miniVCI to document before and after behavior.
    peterjmc likes this.
  14. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Toyota claim that the fluid in the transmission is good for the life of the car. I think there is some hysteria here regarding the necessity of changing the ATF fluid. Has any one noticed a large rash of failing Prius transmissions lately? If anything the Prius tops most reliability surveys.
    If you feel better changing your fluid do it but it probably won't make much difference to the reliability of your car.
    Don't put anything but Toyota's fluid in there as it is specially formulated for compatibility with your electric motors.
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You have almost made the connection, you will not see transmission failures, there is (almost) nothing to fail, you will see shorted M/Gs, from metals moving in the ATF.
  16. Feri
    Feri Active Member
    761
    144
    OK I'll play your game. Has there been a plague of shorted M/Gs?
  17. bwilson4web
    16,472
    When Toyota claims an early transaxle change voids their warranty, I'll be willing to consider not changing the oil. But my first NHW11 change at 53,000 mi. after the car had spent 49,000 mi. with the former owner in a hot and dusty state, Texas, notorious for high-speed driving. The plastic head light covers were already 'frosted' from the dust and dirt. Similar to what cars from the Australian interior are likely to see. But my first change was part of a cold-weather study: 2003 Prius - Cold Weather and Transaxle
    Fair enough as I know there is some:
    NHW11 transaxle:
    The transaxle failures occur AFTER the warranty expires during which time the cruddy oil does its damage.
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You may note that transaxle failure is the first repair mentioned.
    Luscious Garage | Blog | Prius Taxi Repair
    Luscious Garage | Blog | Gen 1 Prius Transmission Repair, P3009, P3120, P3125
    This gentleman thinks the suspended solids block fluid flow and overheat the insulation, leading to M/G failure
    Gen1 tranny service DO IT NOW! | PriusChat
    - Luscious Garage | Blog | Gen 2 Prius (2004-2009) Transmission Failure, P0AA6, P0A92, P0A7A
  19. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    Feri,
    Your quote, "Toyota claim that the fluid in the transmission is good for the life of the car."
    What is Toyota's claimed life for these vehicles ? Are you good with that?
    How do you explain this is the one and only car that should never have it's dirty fluid changed?
    We've been over this many times on various threads. I want my car to last as long as possible.
    Why does it need to have a life time?
    They don't throw aircraft away at certain miles/hours of use.
    I have a buddy with 320k miles on a Gen2. The only major repair was replacing one of the battery modules with a $40 used replacement. His previous car was an Accord wagon with 1.4 Million miles on it. NO Major engine work. Always used Mobil 1 in engine and transmission.
    You can maintain your car anyway you like. How long do you expect it to last?
  20. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    Bob,
    Thanks for you looking at and reporting your findings !!
    FYI from Mobil 1 ATF site:
    Mobil 1 Synthetic ATF
    Viscosity, cSt (ASTM D445)
    @ 40 ºC 36.3
    @ 100 ºC 7.4
