Fuel Filler Countdown
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by El Dobro, Jun 18, 2013.
  1. El Dobro
    El Dobro A Member
    7,102
    3,282
    Has anyone had it yet when you fueled up? I would imagine those with a lot of EV use have had the fuel countdown.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Yeah, I was counting down last week when gas was $4.29 a gallon ( had three gallons left since April) Filled up today at $3.79 a gallon:D
  3. bisco
    52,652
    i haven't seen it, and my last tank was high ev. could it be that you just don'r notice it? by the time you shut the car off, get out, swipe your card, remove the hose and open the cap?
  4. El Dobro
    El Dobro A Member
    7,102
    3,282
    As soon as you hit the filler door button is when the countdown starts, if necessary.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I must be a mushroom because I have no idea what you're talking about. Where does the countdown show up?o_O
  6. bisco
    52,652
    on the display. i'm pushing the button as i get out of the car, so, i would never see it. of course, i don't see the message when i leave the filler door open or the low gas warning either.:rolleyes:
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    me neither because the car is off when I fill up:rolleyes:
  8. El Dobro
    El Dobro A Member
    7,102
    3,282
    When you hit the filler button, a display pops up and says refuel ready. If the system isn't ready yet, a row of pips pops up and you have to wait until they countdown before filling the car.
  9. El Dobro
    El Dobro A Member
    7,102
    3,282
    It works whether the car is on or not.
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    "filler button?" do you mean the gas filler door release?o_O
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    so....what happens.....does the gas filler door not open till it counts down?o_O
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I'm TOTALLY confusedo_O
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Cr*p now I have to wait another six months:mad:
  14. El Dobro
    El Dobro A Member
    7,102
    3,282
    Right, but it's not just a fuel filler door release in the PiP, it also signals the car that you want to add fuel. If there's excessive fuel vapors in the tank, it signals a pump to remove the vapors before you open the cap, so you don't get a face full. That's what the countdown is for. The Volt does the same thing.
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    ah......check with me in six months:D
  16. El Dobro
    El Dobro A Member
    7,102
    3,282
    It's on page 174 of the owner's manual.
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yeah, thanks, but I want to see it live:p
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I'll have a filler countdown event in December:ROFLMAO: :LOL:
  19. retired4999
    2,652
    627
    Eau Claire, Wi.
    You do know that it is allowed to fuel more often don't you? :p
  20. El Dobro
    El Dobro A Member
    7,102
    3,282
    After 630 miles, I'm down 4 pips on the fuel gauge, so when we ever get a hot day here, I'm going to hit the button just to see if it does the countdown.
