Possible to increase interstate mpg? Scangauge?
Discussion in 'Gen 3 Prius Fuel Economy' started by gone postal, Feb 19, 2014.
  1. Mendel Leisk
    38,955
    Personally I'd never block the upper, since inverter rad is behind there. Lower I block 100% as long as temps are at or under freezing. When temps start climbing I remove 50%. And any time I'm using AC for cooling, I do not want any blocking.
    Maybe a typo??
  2. Hybrid Dave
    Hybrid Dave Member
    184
    73
    St Augustine, FL
    I also drive I-95 here in Florida on my commutes. I have a 2010 Prius IV with the stock 15" wheels and OEM Yokohama Avid S33s running 44 psi. Average temps when I drive in the morning are in the mid to high 50's. At a constant 70 mph, I see around 50 mpg give or take a few 1/10ths. It is a pretty reasonable speed if you stay in the right lane. Depending on road incline and wind, I've even been able to bump up to 72 mph and maintain 50 mpg. Drafting at a reasonable distance can see 50 mpg even at speeds around 75 mph. It just depends on weather and the condition of the road. Parts of Jax are kind of rough and I've seen as low as mid 40's at 65-70 mph due to cracks and groves in the road.
  3. SKMoss
    SKMoss Junior Member
    32
    SW Riverside County, CA
    2014 Prius Plug-in
    Torque seems to get a lot of attention. From what I can tell they have not produced an IPhone version. Does anyone have suggestions for one of the iphone variants that would be as good?
  4. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
  5. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    Yes the E model does show temp and RPM etc I have that model ... but I would not recommend since it lacks of the really cool feature Xgauge !!! and only shows 2 things at the time. If I knew the difference, I would not have saved the $50.
    But certainly easier to use and setup.
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    If you are comfortable at 80F there's no reason to set the climate control at 75F. There isn't one perfect or set temp. Some days I run the car cooler, some days warmer.
    High inverter coolant temps are between rare and uncommon here even fully blocked. Just pulling a number out of the air as an example, if 100F were "high" or "a concern" then how do you justify driving the car when the outside air temp is that high?
    Everyone is different. Do as you feel best.
  7. neez
    neez Member
    194
    37
    Probably going to bet the 2015 prius will have active grill shutters. Seems several cars have gotten them in 2014.
  8. pmike
    pmike Member
    233
    Central Florida
    I am sure you could work a trade with someone, their 15"s for your 17"s.
    You can get prepaid Android phones for $10: Boost Mobile Kyocera Hydro Waterproof No-Contract Smartphone $10 (In-Store Only) 03-08-2014 - Slickdeals.net
    I would get something to monitor inverter and coolant temp and experiment with lower grill blocking.
    I think a great way to do grill blocking would be to buy a Grillcraft lower billet grill and cover it with vinyl or even a magnetic sheet.
  9. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Here is a steady state MPG for a Third Gen with the 17 inch wheels.
    Robert Holt likes this.
  10. neez
    neez Member
    194
    37
    Yea, get an android tablet. Seriously, they are dirt cheap these days, like $80 for a 7" tablet. Doesn't need to be fancy or have ultra long battery life. A single core processor is fine for running 1 app.
  11. Hybrid Dave
    Hybrid Dave Member
    184
    73
    St Augustine, FL
    If anyone has Sprint, they often give a free tablet and all you need is to add a $5/month data plan. Right now they are doing a free Tab 3 for signing onto the Framily plan. I am thinking about doing that and using the Tab with Torque. I just need to decide on a OBDII scanner to use.
  12. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    I, too, have both a new 2014 Prius and an old ScangaugeII™--but, alas, they're NOT (yet) connected! Why? Because I have no idea which Prius parameters to look at.
    So-o-o-o-o, what recommendations do you have for a Prius-newbie? What info (probably all via X-Gauge?) should I be trying to monitor and observe?
  13. bwilson4web
    15,586
    • engine coolant temperature
      • 40C with heater off - engine will auto-stop at a light or when stopped
      • 55C with heater on - engine will auto-stop at any opportunity
    • engine rpm
      • to tell when the engine is actually off
    • MPG or gallons/hr or mass flow
      • gives accurate metrics for what the car is actually burning
    70AARCUDA likes this.
  14. 70AARCUDA
    845
    209
    Tucson, AZ
    Thanks! ...and, I see that NONE require X-Gauge programming...excellent!
    Just ONE final question: Does invoking the 'HYBRID' setting truly ensure that the SGII™ won't "stay ON" and thus discharge the 12VDC battery?
  15. xliderider
    xliderider Senior Member
    7,901
    3,130
    Honolulu, HI
    Not Hybrid, I believe it's NO COMM, as opposed to 0 RPM for Sleep Event.
    Even then, it's recommended that you wait and watch the SG to make sure it powers down after shutting down your Prius.
    SCH-I535
  16. 70AARCUDA
    845
    209
    Tucson, AZ
    Hm-m-m, now that is a command that I am not familiar with; is it something in the newest Version release?
