Draw-Tite, Curt, or Hidden Hitch...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 67tony, Apr 15, 2014.
  1. 67tony
    67tony Junior Member
    36
    Michigan
    ...for my 2010 Prius? (Intended for a 2-bike rack.)
    Which is the least protruding?
    Thanks!
  2. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Try the Torklift Central "EcoHitch" site, if you really want the hitch to be tucked in with minimal aero disturbance
  3. 67tony
    36
    Michigan
    Yes, I saw that option, but it was about twice the money compared to the three listed above.
  4. john1701a
    john1701a Prius Guru
    12,761
    5,247
    57
    Protruding? You mean sticking out beyond the bumper or simply being visible below the vehicle?
    That is what I installed last year and have been very happy with the choice. It doesn't stick out either, but it's not hidden in any respect.
  5. B. Roberts
    691
    212
    Do you have a picture of what it looks like installed on your Prius? Would be pretty helpful if you could post.(y)
  6. Denver Corrick
    Denver Corrick Junior Member
    North central Ohio
    From the videos on the net, it appears that the Hidden hitch, Curt, and Draw-tite all install below the plastic trim panel. The EcoHitch installs above the plastic trim panel which should make it much more aerodynamic with little air flow disturbance. The question is, is the $100+ higher price worth it with the gas savings by the aerodynamic improvements by being under the trim panel?
  7. MikeDee
    MikeDee Senior Member
    1,552
    590
    San Francisco Bay Area
    I doubt there is any mileage penalty. You've got the rear axle, struts, wheels, etc blocking the airstream. Also the Eco hitch is harder to install and requires cutting of the plastic panel. It's nice though.
  8. B. Roberts
    691
    212
    If the hitch bar resides outside the rear cover panels, there would be a bit of air flow disruption. Probably not an issue at slower speeds. Imagine some degradation would be present at higher speeds. How much? Hard to tell.
  9. retired4999
    2,652
    625
    Eau Claire, Wi.
    Curt hitch on 2012 plug-in
    john1701a likes this.
  10. B. Roberts
    691
    212
    Hidden Hitch may be tucked up to the bumper a little more. My son and I had Vibes... he put a Curt on his and I eventually got a Hidden Hitch. Turned out that the Hidden Hitch was tucked up a tad more than his Curt. It was a noticeable difference that he pointed out.
  11. retired4999
    2,652
    625
    Eau Claire, Wi.
    Yep! I totally agree with you!
  12. 67tony
    36
    Michigan
    Thanks B. Roberts, and retired 4999.
    Although only a slight difference, that's the type of information I am looking for!
    Hidden Hitch here we come...
    B. Roberts and retired4999 like this.
  13. B. Roberts
    691
    212
    Wish we could get a Hidden Hitch picture on a Prius to compare and see the differences. Someone's gotta have a Hidden Hitch installed in this Forum, right?
  14. john1701a
    12,761
    5,247
    57
    Here's a photo with 2 bikes loaded on a Thule rack, to the Curt hitch:
  15. retired4999
    2,652
    625
    Eau Claire, Wi.
    Nice Picture John!
    For some reason every time I see your post's, I think of silver! not blue go figure. :D
  16. Denver Corrick
    North central Ohio
    I ordered a Hidden Hitch for mine on Thursday. I bought it online for $114.73 including shipping. Hopefully it will show up next week, and I will get it installed and add some photos of the installation, and the final look.
  17. anhnamngheo
    anhnamngheo New Member
    I had order Draw-tite hitch and it was very easy to installed. I had four bikes and still average about 45mpg.
  18. MikeDee
    1,552
    590
    I got my Draw-tite hitch from Amazon. Packing was nonexistent so some of the paint got rubbed off and there were a bunch of labels to be removed. However the price was good. I installed it without jacking up the car.
  19. Gee3
    Gee3 Junior Member
    I bought a 2014 Prius 4 and I thought the manual said hitches aren't recommended. Is that true? Or is that something new for the 2014's?
    iPhone ?
  20. john1701a
    12,761
    5,247
    57
    Hitches aren't recommended, since that implies TOWING, which isn't something you should do with a Prius.
    If all you're going to use the hitch for is carrying cargo on a rack, then it's no big deal. Go for it.
