Fuel history per trip question
Discussion in 'Gen 3 Prius Technical Discussion' started by mroe1, Mar 19, 2014.
  1. mroe1
    mroe1 Junior Member
    22
    Phoenix, Arizona
    So I am trying to find the best way to go to work, weather it me highway or though the city gas millage wise. I started out this morning, after resetting the trip meters, and fuel consumption readings. I got to my destination, put the car in park, and you would think it would then give me a reading on what my average MPG was for the trip. It did not. Because I want to log that reading and take a different route home. When does the system to me what my MPG for the trip?
  2. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    The CONS displayed on the dash under the HSI is your trip average from when you reset it to present. Average speed is displayed as well.
  3. mroe1
    mroe1 Junior Member
    22
    Phoenix, Arizona
    That is under 1-minute interval fuel consumption. I'm talking about history in either Trip A or B
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The CONS and MPH at the bottom of the screen are averages for Trip A or B until reset, not 1 minute averages. I typically use Trip A for tank averages and reset at each fillup. I will use Trip B for short trips such as you are describing, record and then reset for the next short trip.
  5. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    You're looking at the nav screen, right?
  6. mroe1
    mroe1 Junior Member
    22
    Phoenix, Arizona
    Yes, I just hit the display button on the steering wheel to bring up Fuel Consumption History, then you can toggle between history A or B. But after a trip and stopping, it doesn't show the trip info. I reset it at the beginning of my trip.
  7. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    That screen you're looking at won't the display trip info you're looking for. It's not available there. You can force a 5 minute trip report by depressing and holding the DISP button while on the 1 minute screen.
  8. mroe1
    mroe1 Junior Member
    22
    Phoenix, Arizona
    So have done several tanks of gas now and changed between driving in regular mode vs eco mode. It's not much, but does make a difference. Lowest millage 46 MPG and high as 52 MPG. I have not been using the dash board figures, the eco mode to get the best MPG. I have been just keeping track of the millage on the odometer and the gallons used to fill it up and then doing them math. so for now I am staying in the eco mode get my best MPG.
  9. GaryHere
    GaryHere Member
    147
    27
    Arizona
    With the ending display (comes on after power off for 30 secs) is the MPG shown only from the time the power was last turned on? So there would be a discrepancy in this MPG and the trip Bs? Mine is way different. Trip B today was 22 miles= 54.3. Ending display showed 64.2?
  10. Greg C
    Greg C Junior Member
    30
    Sydney, Australia
    I have been driving mine in ECO mode for almost all its life. Economy about 10% better as the handbook says and finer control of the accelerator when in EV mode.
