DIY Oil Changes...easy or hard? Worth the hassle?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by prevee5, Jul 2, 2014.
  1. Okinawa
    Okinawa Senior Member
    1,333
    317
    Thanks for the info. That's about what I guessed. I'm retired with little to do so I suppose I'll go.
  2. telmo744
    telmo744 HSD fanatic
    2,168
    764
    Portugal
    Also happened to me in Portugal. So very true, the dealer doesn't care for your (our) engine as customers. Quite unfair...
  3. coolcarguy
    coolcarguy New Member
    27
    2013 Prius Plug-in
    is the Penzoil and the Mobile 1 oil as good as the Toyota oil ?
  4. mikefocke
    3,638
    1,626
    Sanford, NC
    I've gone to the Jiffy lube places with my own oil and filter. They do the labor, I supervise the fill. I get my own oil and a $10 discount. I know it is done right and my hands are clean.
  5. Okinawa
    1,333
    317
    A parts person at a Toyota dealer told me that Toyota synthetic oil is made by Mobil. I can not verify the truth in that. Just passing along what he told me. I certainly would not be afraid to use Mobil l.
  6. Mendel Leisk
    38,232
    Deleted
    (I'm repeating myself ;))
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Mobil1 is not the Toyota oil, and actually had its spec downgraded a couple of years ago. Now it is just making the company money based on its old brand recognition.
    Oil is best chosen by spec: 0w-20, ACEA A5, and ILSAC 4. Mobil does have an oil that almost meets this spec but the name escapes me. I usually end up buying the Pennzoil Ultra because it only costs about $25 for 5 quarts at Walmart, and lately has had a promotion as well that brings the cost down to around $2 -3 a quart.
    #47 SageBrush, Jul 29, 2014
  8. El Dobro
    El Dobro A Member
    6,972
    3,209
  9. SageBrush
    11,627
    2,530
    Southwest Colorado
  10. wjtracy
    wjtracy Senior Member
    11,313
    3,588
    Northern VA (NoVA)
    ...it's hard for the consumer to answer the question because we are not privy to extensive lab testing etc and seems to me they are always adjusting the formulations so any answer is soon outdated. You can look at specs and many feel the Toyota is among the best. For example, the Toyota stuff seems to have superior low temperature low viscosity so that's good for the start-up period where we need to get the oil moving. I go with Mobil-1 which is $22.xx for 5 quarts at Walmart...if Walmart had the Toyota I'd be tempted to go with that but they don't so there you have it.
    You can look for ACEA A5/B5 rating but at least in USA that's a rare rating in 20 weight. Gen2 we can get A5/B5 in the 30 weight.
    #50 wjtracy, Jul 29, 2014
  11. SageBrush
    11,627
    2,530
    Southwest Colorado
    This is the Pennzoil Ultra Specs. Available at Walmart :)
  12. SageBrush
    11,627
    2,530
    Southwest Colorado
    This is a cool tool to compare oils and specs:
    dataStack
    From the tool, looking at ACEA A1 and A5, and ILSAC GF5
    The colors are misleading. GF5 improves fuel economy and oxidative thickening
    Note the after treatment compatibility ;)
    #52 SageBrush, Jul 29, 2014
  13. Ivan White
    Ivan White Junior Member
    70
    Haven't seen the 0W20 Pennzoil Natural gas oil at Walmart. Mine has 5W-30, 10W-30. Hopefully we'll see it soon as I'd love some AND the gasoline discount coupon. Incidentally, my coupon on 5W-30 says the offer end on 06/30/14. Have you used yours lately?
  14. SageBrush
    11,627
    2,530
    Southwest Colorado
    I bought the oil early July and was able to obtain the discount on fuel which is good until October.
    I'm not sure why the expiration date for the promotion did not disallow my code, or if it would work today.
