Prius 2008 GPS navigation does not work
Discussion in 'Gen 2 Prius Audio and Electronics' started by Salman khan, Jul 30, 2014.
  1. Salman khan
    Salman khan Junior Member
    london
    Hello Guys,
    This is my first posting in this forum, bought my 2008 Prius Tspirit. The GPS navigation is not working, not in car so can't remember the message. The previous owner stated he only used it locally so didnt need gps and said it just need a programmable disc. There is a gps disc in the car, every time i load nothing happens, nothing wrong with cd player as it plays music cds whenever i insert it.
    The car has done 47000 mileage and i am based in london, uk. The rear parking works. its not huge issue as i have TomTom but nice to have orius in-built working as well.
  2. AzWxGuy
    AzWxGuy Weather Guy
    970
    491
    Tucson, AZ
    2021 Prius
    I don't have navigation and I'm not in the European market, but isn't the NAV disk a DVD, and isn't the drive for said disk under the driver seat? I think that is what I have read about the NAV system here in the states.
    Data Daedalus likes this.
  3. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Yes you should insert the DVD into your GPS unit under the driver seat.
    The dash is for CD only. Read your NAV manual to know how to insert the DVD.
  4. Salman khan
    london
    Ok, so you insert DVD under driver seat, i will certainly try that. Thanks.
    Hopefully it would be easy task to go under drivers seat. Will try and let you know guys of the outcome.
  5. dolj
    dolj Senior Member
    7,510
    3,774
    Wellington, New Zealand
    The correct terminology is "under the left-hand front seat".
    In the UK the car is a RHD, but the locations of the JBL amp (if fitted) -- and as you have the T-Spirit, it is -- and the Nav DVD player do not change positions in relation to the steering wheel.
    So to reiterate, in all models of Prius world-wide, and where fitted, the nav DVD is located under the LH front seat and the JBL stereo amp is located under the RH front seat.
    You load the nav DVD from the back seat as the mouth of the DVD player is accessed from the rear of the front seat. Instruction in the nav supplemental user guide.
    hope this helps
  6. Salman khan
    london
    Thanks guys, it worked. I was looking under driver seat first but then looked under passenger seat and found it there.
    regards,
    sal.
  7. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    it wouldn't have been a problem if you guys didn't drive on the wrong side of the road.;)
    Data Daedalus and AzWxGuy like this.
  8. Arch
    Arch New Member
    Austin, TX
    This is also my first post. I have a 2008 Prius whose GPS recently stopped working after the dealer replaced the 12V battery. I got a message that said, 'Program can not be read, contact to a dealer.' After laughing about the message, I returned to the dealer and was told that their serviceman determined that the DVD player is the problem because the GPS disc loaded fine on another car. I was then given the name of a company in Austin, TX to call, and learned that the DVD player replacement cost will be $650. So, I'm asking if anyone has had a similar experience and more importantly, what was the fix?
    Arch
