Low Battery engine behaviour
Discussion in 'Prius c Technical Discussion' started by Species5618w, Aug 2, 2013.
  1. Species5618w
    Species5618w Member
    140
    I am wondering what should the engine do if the battery drops to 2 bars.
    I was stuck in heavy traffic the other day. The battery drops to 2 bars and the engine kicked in. However, the engine speed seemed to change a lot based on the sound (much like the warm up cycle, but shorter) and the battery was never charged to 3 bars before it shut off again. So every couple of minutes, the engine would kick in, charge a little bit and then stop.
    Is that behaviour normal? Shouldn't the engine charge the battery a bit more to avoid the frequent start/stop of the engine?
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    That's normal. If you press the brake, the engine revs down... as long as you are moving. If you aren't moving it's the same as if you don't have your foot on the brake.
    minkus likes this.
  3. It can be normal...if I start the car cold with a low-ish battery to begin with, and I just take off, the battery drains down to 2 bars pretty quick. (Don't worry, 2 bars does not mean less than 25% charge, it's actually a bit more than 25%...) Anyway, the engine kicks in to keep the battery from going below 2 bars, but that also means your fuel economy goes down a bit.
    I usually try to pull in for the night with 5-6 bars.
  4. Species5618w
    Species5618w Member
    140
    Actually, this was in traffic. Since the I was moving 1 meter/5 minutes (literally), I was always in EV mode and I guess the lights and other electronics use power as well, so the battery would eventually draw down to 2 bars. However, the engine did not kick in long enough to charge the battery to 3 bars. It uses a lot of gas though and revs up and down, which is extremely annoying. I'd rather the engine run at ultimate RPMs and charge the battery to at least 4 bars. It shouldn't be hard to detect that cars is stuck in traffic, thus would not have a chance to charge the battery through driving.
  5. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Sounds perfectly normal from a Prius hatchback point of view.
    Most of the car's strategy has a reason.
    Would you really find it less annoying to have the engine run at high speed for a longer time in stopped traffic? The car can't predict the future. Heck, I can't predict the future.
    Most of the time I'm stuck in traffic, after a while the traffic clears and then the engine gets to charge the battery while I'm driving at a normal speed. Much more efficient (and, to me, less annoying) than what you've asked for.
  6. Species5618w
    Species5618w Member
    140
    Thanks. As long as it's normal.
  7. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    With the ScanGauge I can see mine charge the battery up to 45.0% SoC and I think it gets defensive around 38.0 SoC, depending on circumstances. As others have noted - 2/8 on the dash battery display does not mean 25% - the car will never let you go so low. I can't remember if mine reads 2/8 or 3/8 at 45% SoC but it's certainly down around that level.
    In short: normal.
  8. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Yes, it is normal. I always try to stay in EV drive as long as possible so my SOC is often down to 2 bars. I have SGII to monitor the SOC as it provides more information than the bar graph.
    The power management control ECU set the Lower SOC control limit at 40.0%. Once it drops to 39.6%, it will automatically start the engine to charge the battery to 45.0%. Once it reach 45.0%, it will stop the engine. This SOC is different from the Target SOC control shown above. The Target SOC shown above is for speed above 46 mph and is around 60% whereas 45.0% is for the controlled SOC once it drops below 40.0%.
    The HV battery is smaller than the hatchback so it only need a short time to charge to 45.0%. Similarly, it also looses charge faster than the hatchback. That is why this start/stop cycle is more frequent than the hatchback.
    Vincent
  9. Sergio-PL
    Sergio-PL Member
    160
    46
    Poland
    Yaris Hybrid (I assume the same construction as Prius C) uses more battery range. I've pushed it recently to it's limit while recording data on Torque App. I don't have graphs yet but looking into Excel Yaris managed to get top speed of 173 kmh (108 mph) despite that maximum declared speed is 165 kmh (103 mph). There is no speed limit as in Prius.
    It took about 50 seconds to deplete battery from 60% SoC to 33,3%. Then car slowed down a bit. ICE RPM was steady at 4800 RPM. So the lower battery limit is much lower than in Prius. Battery Current was at steady level of about 120 A for all 50 seconds. MFD was showing 2 bars. Never dropped to 1 bar. When car slowed down HSD indicator dropped from top of the power scale to eco/power intersection.
    Back to the main topic. Yaris Hybrid behaves the same in traffic jam. It turns on ICE, runs it for a (quite short) while, then shuts off. It pushes about 30A to the battery at this time. In Prius it works much longer (from 2 to 3 full bars) and pushes about 10 to 20A. Technology in Yaris/PriusC is harder for the battery but much more effective in terms of fuel usage, because smaller ICE works near it's full efficiency.
    Both cars does not charge battery when car is moving and brakes are engaged (on high speed regen braking loads the battery, but below 10 kmh / 7 mph recharging operation is paused until car stops or accelerates). That's why engine sound is different while braking than while standing still. You can also feel a bit of vibration while engine switches from idling to 90% load and charging operation.
  10. priusrick
    priusrick Member
    257
    40
    What about engine battery low when it's sitting outside (OFF) while I'm at work and come out to it to go home?
  11. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    What about it?
  12. priusrick
    priusrick Member
    257
    40
    Why is it low?
    SCH-R530M ?
  13. minkus
    369
    125
    Cleveland, OH
    Lower than it was when you parked it? How much lower, and how big of an outside temperature change from morning to evening commute?
  14. priusrick
    priusrick Member
    257
    40
    Much lower, almost full when I parked it and on the opposite end when I got end. Maybe 10 degree change during the day at the most.
  15. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    It shouldn't discharge that much without using it. Do you have the solar sunroof vent? I wonder if maybe that quit working and your battery is powering everything... although, those solar cells don't produce a lot of power so the fan can't use a lot... hmm... do you have a light that stays on? I've got nothing. Sorry.
  16. priusrick
    priusrick Member
    257
    40
    No solar roof and no lights that I know of
    SCH-R530M ?
  17. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Are you absolutely sure that the car is completely OFF when you leave it ??
    If you are talking about the main propulsion battery (as opposed to the 12 V one), then about the only things that would cause that much of a drop is the battery going bad, the car still being ON or a major fault in the electrical system somewhere.
    In any case, it probably needs dealer attention to figure out.
    minkus likes this.
  18. priusrick
    priusrick Member
    257
    40
    Definitely off, yes main propulsion battery
    SCH-R530M ?
  19. Sergio-PL
    Sergio-PL Member
    160
    46
    Poland
    If you are completly sure that the car is completly OFF then visit your service as soon as possible.
    Hybrid battery is disconnected from the system completly as soon as you turn it off (you can hear characteristic click from the rear of the car) and reconnected just before "READY" indicator is back on.
    You can have one bar change between startups due to recallibration but nothing more. Battery should keep it's charge for few months.
    minkus likes this.
  20. priusrick
    priusrick Member
    257
    40
    Got clean bill of health despite the battery's continued behavior
