Has anyone attempt to remove the hybrid and synergy emblem?
Discussion in 'Prius c Accessories and Modifications' started by Mikej, Aug 17, 2014.
  1. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    If so, how did you do it? Does it have the "alignment hole" behind it? (im not going to remove toyota emblem)
    I'm planning to use hairdryer and dental floss, then apply goo gone to remove the sticky residue.
  2. Carbphrek
    Carbphrek New Member
    Tampa, FL
    2014 Prius c
    The backend badges minus the the cowboy hat badge are just glued on. Took me about 20mins during a downpour to remove the left & right side badges. The dental floss kept breaking (used the cheap stuff from the dentist loot bag). The leftover adhesive peeled right off, no goo-gone needed. I washed him and gave the badge spots a quick wax over. My Pc is 3 weeks old so no ghosting issues.
  3. Native2PS
    Native2PS Member
    144
    65
    Kihei, HI
    Dont use goo gone, it strips the clear coat, just work it off with your fingers, and wax over and you should be fine
    ztanos likes this.
  4. w2kpugsly
    w2kpugsly Junior Member
    97
    san diego
    The side badges have an alignment hole. Not sure about the front one; although you'll definitely have an indent where the cowboy hat used to sit.
  5. robertmaria
    robertmaria Member
    202
    please DELETE this account
    2014 Prius c
    i messed up the side ones because of the holes. i will put some Hello Kitty stickers over the holes at some point. the rear tailgate without badges looks very nice though
  6. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    You might not want to remove the hybrid badges - they're not just there for marketing - they are there to let first responders know not to just cut into the car where there might be high voltage cables and dangerous batteries to try to rescue you. Hybrid cars require special procedures in an accident scene.
    Here's a PDF made for firefighters, there's an identification section concerning the hybrid badges.
    http://afvsafetytraining.com/erg/Toyota-PriusC-2012.pdf
    robertmaria likes this.
  7. pp60142
    pp60142 Junior Member
    i have removed all symbols from back and side. looks different.. like 10 min. job. but i debadge next day i bought. pictures coming soon.
  8. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    dang it, there are holes on the side badge, any solutions to hide the hideous hole? or I have to give up removing the ugly hybrid badge.
    #8 Mikej, Aug 21, 2014
  9. robertmaria
    robertmaria Member
    202
    2014 Prius c
    omg,,, ok i need new hybrid side badges then. i bent the old ones. are they expensive?
  10. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    I don't see hybrid badge on Lexus ct, why should the lowered end car carry the burden?
  11. Super Mario
    Super Mario Member
    142
    57
    Medford, NY
    Hybrid badges are on the CT, they are on the lower rear of the car by the rear door I believe
  12. Super Mario
    Super Mario Member
    142
    57
    Medford, NY
    . Check ebay, I don't think they are very expensive, maybe 10 dollars each but not 100% sure
