'06 Oil / Motor noise question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by VESPAGUY, Aug 12, 2014.
  1. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    I should also have warned you not to let the dealer just replace the bearing shells. This would quieten things down by reducing the bearing clearances, but would not address any damage to the crankshaft journals, cylinder bores/piston rings, and camshaft ware. Problems with these will show up later, but show up they will. Take a look at the first picture then the third picture down. The first is the shell damage the second is damage to the crankshaft journal.
    Images for big end shells after running without oil
    John (Britprius)
    #21 Britprius, Aug 15, 2014
  2. VESPAGUY
    VESPAGUY Junior Member
    34
    KCMO
    John, thanks again. I appreciate your advice and insight.
    Prius goes to the Dealership today at 2:00pm CDT/USA
    cheers!
  3. Britprius
    5,194
    1,917
    Did you look at the link I just added.
    John (Britprius)
    VESPAGUY likes this.
  4. VESPAGUY
    34
    KCMO
    Update; Prius and I visited the dealership on Friday. I drove two service Techs around the area where the dealership is located. The petrol motor did its usual thing, sounding more fluttery. Each could not specifically verbalize what they noticed but agreed the engine sounded odd.
    With the second Tech, we pulled into a service bay. He checked the dipstick... looked ok. He hoisted Prius and got out a stethoscope type device and went around poking and probing the motor but couldn't specifically locate an obvious sound.
    Then, at my request, he unplugged the oil pan. Then with a small container I supplied him (I wanted an oil sample to take with me for further inspection) he dispensed the first part of the motor oil into this container. While allowing the remainder of the oil pan to drain into his shop collection caddy, we relocated to a shop bench where he got out his Mag light and cast it upon the freshly tapped (and hot) oil.
    It was bright, sparkling (Metallic) Oil Green!
    The Service Manager had made his way back to the bay by this point and was able to view this along with the Tech and I. The tech mentioned right away... "Oil looks good, except... it's not supposed to be metallic!" So, as the "Smoking Gun" was revealed the Service Manager and I made our way back to his office where he transferred me to their loaner vehicle person.
    In the process of getting a loaner, yet another Manager-type came up and talked with me. This time while apologizing sincerely all the way he offered-up that they would plan to not only replace the petrol motor but also add an extended warranty (3 years) AND a new service contract. I took his offer under advisement, grabbed the key fob to a shiny new 2014 Camry and was on my way.
    Later on that evening (6:30pm), I get a call from the same Service Manager. This time he is providing me with an offer to 'get into a new car' in lieu of the new motor, etc. I reiterated that I have been enjoying no car payments and that jumping into a fresh batch of debt wasn't my first choice, but we'd talk about it.
    On Saturday I get a call from the second manager-type. He, again, is apologizing and suggesting that they want to do whatever is needed to regain my trust in them/Toyota, etc. (By this point I hadn't really lost it!) He states that he'll have a Sales Manager contact me for further info on the whole new car offer.
    My wife and I have discussed the idea of fixing the Prius and waiting until the next Gen Prius is available as the first choice. This will prevail unless they really drop their drawers and get us into a 2014 for much less than Net and give us full Retail for ours.
    So! That's where things stand today. Thanks for being good listeners. I'll keep in touch. You too!
    Cheers!
  5. Mendel Leisk
    38,985
    Good to hear things are resolving for you.
    I can't help speculating what went on behind close doors, to take them from engine replacement (petrol motor ;)) to car replacement...: HOPEFULLY they don't try to pass off your car to some unsuspecting victim. If you take them up on the offer, it'd be interesting to follow your old car, if that's possible.
  6. VESPAGUY
    34
    KCMO
    Here is the (first 5 Cups) Oil dispensed from the oil pan.
  7. Britprius
    5,194
    1,917
    I feel you are now getting somewhere towards a happy outcome. Like you I would be wary of a new car with payments unless they really do make an offer you can't refuse.
    The offer of a new engine and extended guarantee to me sounds a good outcome as this should give you trouble free motoring for the next three years taking you into the territory of the next generation Prius with a car that should still have good sale ability.
    Please keep us informed of how things go whatever your decision.
    John (Britprius)
  8. JC91006
    JC91006 Senior Member
    16,500
    8,412
    I personally would reject any offer of a new car, I would insist on the offer of a new engine and 3 years warranty.
  9. Britprius
    5,194
    1,917
    I would love to see inside the oil filter I bet it is crammed with metal particles. The metal carrying oil would also have to pass through the oil pump on it's way to the filter. What a mess.
    John (Britprius)
  10. bisco
    49,815
    that's great news, and a whole new level of respect for the service manager. all the best with your decision!(y)
  11. Mendel Leisk
    38,985
    The more I think about, the more I smell a rat with this new car offer.
    From personal experience with a new car lemon (extensive body work was done due to damage in transit). We traded early and all we really garnered was slightly improved courtesy and a marginally better trade in value. I'm sure they did the minimum patch up and passed on the "near new gem" to some poor shmuck.
    I think you should stick to your guns on the engine replacement. And even that is a massive imposition, a patch up of THEIR mess.
    #31 Mendel Leisk, Aug 18, 2014
  12. VESPAGUY
    34
    KCMO
    Thanks friends. My gut tells me I want my Prius fixed.
  13. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    Unless you were planning to buy a new/used car, or the current Prius was on its last leg, then the dealer's offer to "help" you out with a new purchase might very well be in your favor. I define "help" as a Prius for many thousands below invoice, complementary floor mats, extended warranty paid by them, and the pre-paid service only costing you 10%, because:
    1) They screwed up.
    2) The dealer wants you to spend tens of thousands of dollars, to buy a new Prius, to rectify their $1613 mistake (cost of replacement short block engine, excluding additional parts and the labor costs; LINK).
    Lets not forget that the dealer gets quite a lot of money if they move a certain number of cars, which is why they might be willing to let a car go for a lot less than invoice, especially if they are super close to hitting the threshold, to get the big pot of money from the manufacture (small loss for a big gain).
    KBB.ORG says your 2006 w/ 147k miles in my area is worth $6192 to $8899 at the dealer, with a fair purchase price of $7546.
    Private party is $5521 (good condition), $5758 (very good condition), and $6116 (excellent condition).
    A fair price for a new 2014 Prius Two, from KBB, is $27,050.
    $27,050 (new replacement) - $8899 (maximum dealer price of your used Prius) = $18,151 (excluding taxes, increased insurance costs, zero interest b/c of 0% interest on OAC).
    So who is really doing who a favor? Sorry vespaguy, we screwed-up, but want you to pay $18k+, to fix our $2k+ mistake. I bet they wouldn't even bother replacing the engine either, even with a used engine. Off to auction and write the difference of sale minus value, on their taxes. Lets add insult to injury when you factor the depreciation that KBB has computed (LINK); don't know what their assumptions are, but this is just a gauge to give you an idea:
    DEPRECIATION: $-11,091 (year 1), -$2,975 (year 2), -$1,894 (year 3), -$1,623 (year 3), -$1,623 (year 4), -$1,623 (year 5).
    Total Depreciation at end of 5 years: -$19,207
    Good luck.
  14. Britprius
    5,194
    1,917
    A short engine block does not rectify likely damage to the valve gear and cam bearings running with no oil risks damaging all moving parts lubricated by the oil.
    John (Britprius)
  15. Former Member 68813
    3,524
    981
    US
    As a minimum, the OP should get an used engine with some short warranty. Asking for brand new shiny engine with long warranty is too much and not going to happen.
    Alternatively, the dealer could buy it back at fair value.
  16. exstudent
    2,214
    901
    Torrance, CA
    [/QUOTE]
    John (Britprius)[/QUOTE]
    That explains the $5k difference Camelback Toyota lists for a Short Block Engine ($1613) vs Engine ($6853).
    Hope OP reports back what he ultimately pursued: engine (hopefully new) or buying a new car.
    #36 exstudent, Aug 19, 2014
  17. VESPAGUY
    34
    KCMO
    Thanks again...all.
    Would the Oil Pump or any other motor/engine components be affected by this Oil deficit???
  18. Britprius
    5,194
    1,917
    Most certainly yes. The oil pump pumps unfiltered oil to the oil filter that you know was full of metal particles, and consists of steel rotors with fine dimensional tolerances"driven directly off the crankshaft" rotating in an aluminium housing. The result is scored rotors and housing with increased clearances.
    This means any metal particles passing through the pump will score both the rotors and the aluminium housing allowing oil to leak back through the pump reducing pressure and oil flow rates. The metal contaminated oil that you looked at would be clean compared with what the pump has drawn up and passed to the oil filter, and the oil filter has trapped "why I said I would liked to have seen inside the filter".
    As stated previously all moving parts within the engine require good lubrication with clean oil at all times. This means, crank and bearing, pistons,rings,and bores, camshaft, timing chain,and tensioner, variable valve timing mechanism, valve cam followers. In other words the complete engine. Nothing will have escaped the affects of either running without oil, and or running in metal contaminated oil.
    This should not affect the transmission apart from possibly discharging the HV battery if the car was driven to far when the engine stopped.
    John (Britprius)
    #38 Britprius, Aug 20, 2014
  19. VESPAGUY
    34
    KCMO
    Update:
    Prius received it's new petrol motor this week with 102,000 miles on it, and a 24,000m/2 year full warranty. Hendrick Toyota extended an additional service/maintenance contract to us too. They were very reasonable to work with and I feel that I received a fair deal.
    The motor now sounds like the motor did pre-oil pan plug loss. I'd like to think that we've got another good 2 years... hopefully in time for the Gen IV to be out.
    Thank you all for the comments and recommendations.
    I'm back on the road, loading it with clean Ethanol-Free 91 Octane and CLEAN oil and enjoying 46 MPG again!
    ...keeping my fingers crossed.
  20. Britprius
    5,194
    1,917
    Happy things worked out for you and the dealer was fair with there response. You should be good for another 100,000 miles of motoring with a little luck.
    John (Britprius)
