Most recent tank
Discussion in 'Gen 3 Prius Fuel Economy' started by wesayso, Jun 2, 2011.
  1. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    436 miles
    10.28 gallons
    $3.65gallon
    42.4 calculated mpg
    45.7 computer mpg on tank.
    24mph
    had some "spirited" driving on a few curvy back roads...
  2. wesayso
    wesayso Member
    385
    35
    Hampton, VA
  3. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    519.3 miles
    10.106 gallons
    $3.499/gallon
    $35.36 total
    51.38 calculated mpg
    53.7 computer mpg on tank.
    $0.0680/mile
    37 mph avg. speed
  4. Jon Stapel
    Jon Stapel Junior Member
    45
    Cheswick, PA
    504 Miles (my first 500 mile tank)
    9.659 gallons
    $3.759/gallon
    $36.31 total fill
    52.2 calc mpg
    54.4 display mpg
    $0.07/mile
    31mph avg speed
  5. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    35K maintenance.
    5/31/14
    35,959 miles
    oil & filter change
    Mobil 1, 0-20W
    OEM filter
    Rotate tires
    Check fluids.
  6. bwilson4web
    15,394
    Sorry but this log does not help. This data should be put in either fuelly.com or on the EPA web site, www.fueleconomy.gov under user data. I have to put you on my ignore list as every time you post, it suggests there may be a new subject posted I might be interested. I appreciate your interest in keeping a record.
    The reason for using fuelly.com and/or the EPA web site is it puts your data in a place with others who share their Prius tank performance. It means your data helps make the averages and distribution more accurate. This thread does not provide running averages or performance relative to other Prius in your area.
  7. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    545.5 miles
    10.576 gallons
    $3.519/gallon
    $37.22 total
    52.8 calculated mpg
    $0.0682/mile
    29 mph avg. speed
  8. Horsefeathers
    Horsefeathers Member
    104
    59
    SW Georgia
    I am inching ever upward toward my goal of 60. I could easily get more miles on a tank, but I do a lot of rural driving over two counties and have to plan my fuel stops pretty strategically.
  9. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    543.9 miles
    11.107 gallons
    $3.399/gallon
    $37.72 total
    48.97 calculated mpg
    50.7 computer mpg on tank.
    $0.0693/mile
    28 mph avg. speed
    ***Hot Hot. Lots of AC***
  10. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    381.6 miles
    7.371 gallons
    $3.349/gallon
    $24.69 total
    51.77 calculated mpg
    53.6 computer mpg on tank.
    $0.0647/mile
    29 mph avg. speed
  11. wesayso
    wesayso Member
    385
    35
    Hampton, VA
  12. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    1. I'm not doing this to help you.
    2. Look at my sig. I DO post to Fuely. Every fill up since I bought the car.
    3. Ignore me, or don't. I do not care.
  13. wesayso
    wesayso Member
    385
    35
    Hampton, VA
  14. cipsaz187
    cipsaz187 Member
    147
    42
    So how many gallons do you have left when the last pip starts flashing?
  15. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    I can get 100 miles after flashing starts.
  16. wesayso
    wesayso Member
    385
    35
    Hampton, VA
  17. wesayso
    wesayso Member
    385
    35
    Hampton, VA
  18. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    522.7 miles
    9.08 Gallons of Pure Gas
    $3.499 per Gallon
    $31.79 Total
    calculated mpg 57.48
    Computer mpg 60.3
    average speed 44 mph
  19. John Bergendahl
    102
    17
    gulfport,ms
    Last tank 460 miles this tank i have 420 and still 2 bars left.Once the last bar starts to blink i go will up so i normally drop in 9.5 gals
    How much linger can i actually drive once the computer says 2 miles left ?? Dont we hold 11 gals ??
  20. Mendel Leisk
    38,240
    ^ Depends on how lucky you're feeling.
    My take: running the gas tank close to empty does nothing towards improving the mpg; I just tank up any time it's significantly below half-full and I'm passing by my favourite brand station.
