Prius lost iPhone phonebook
Discussion in 'Gen 3 Prius Audio and Electronics' started by matsprt, Oct 6, 2012.
  1. matsprt
    matsprt Junior Member
    SoCal
    Not sure what or how it happened but for the last 6 months no problems. Now I see the iPhone phonebook is no longer seen by my Prius. It still receives calls and I can go to my phonebook on the phone and make calls through the BT system? If I try to make a call through the car it says there are no entires for "dial by name" option.
    2011 Prius III with solar and navi.
  2. lensovet
    2,614
    495
    Burlington, NJ
    Have you tried deleting the BT pairing both on the phone and the car and setting up the phone fresh from the car?
  3. lbr
    lbr Junior Member
    Holland
    My iPhone phone book gets lost every couple of weeks.
    When i have this I just reload/import my phonebook again. Out of my head there is a button on the left side
    Of the phone book screen to reload.
  4. matsprt
    SoCal
    Well the suggestion to re-import the phone book worked. Now I wonder how long until it "loses" it again. This is the first time in six months....don't really want to do this on a regular basis.
  5. Christopher Neglia
    Christopher Neglia Junior Member
    Jacksonville, Florida
    I just had a major let down! The Iphone 4s is not compatible with audio bluetooth streaming in my Prius IV. I called toyota support and they sent me to Toyota.com - Connect, on the site it will ask you your phone model and car info, then it lists all the capabilities of you phone connections with green check marks and red X's. What a bummer.
  6. lensovet
    2,614
    495
    Burlington, NJ
    Works absolutely fine for me
  7. lbr
    lbr Junior Member
    Holland
    Works for me also. But you have To Connect it twice. Once for the phone and once for the audio.
  8. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I had an iPhone 4S for a year, and now an iPhone 5 for several weeks, and everything works fine.
  9. Christopher Neglia
    I was able to get it to work . It works great now!
  10. lensovet
    2,614
    495
    Burlington, NJ
    i had to that the first time only; now it connects automatically every time i get in the car and turn it on.
    PS. Can someone explain to me the point of having the address book in the car at all? You can use Siri/Voice dialing on the phone to dial someone's number, and the recents call list/incoming call info shows the person's name even if you never transfer your address book.
  11. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I have not been able to successfully have Siri voice dial a number using bluetooth in my V+nav. Siri breaks the bluetooth connection between ending the request and dialing the number and the car doesn't respond as quickly. Any suggestions?
  12. lensovet
    2,614
    495
    Burlington, NJ
    I'll give this a try tomorrow
  13. lensovet
    2,614
    495
    Burlington, NJ
    so I did try this. I had BT audio playing, held down the home button, gave my command, everything worked fine. it is kind of funny to watch the screen though, because when siri is active, the Prius thinks it's placing a call to itself…
  14. chrisj428
    680
    144
    35
    Vernon Hills, IL
    Ah -- you had the Bluetooth connection already open playing music. What happens if you're listening to another input -- say SAT or USB?
  15. lensovet
    2,614
    495
    Burlington, NJ
    i'd expect it to work the same as any other phone call, since that's what the system sees it as, but let me check.
  16. chrisj428
    680
    144
    35
    Vernon Hills, IL
  17. lensovet
    2,614
    495
    Burlington, NJ
    it worked just fine.
    but I also realized that we have different systems. I'm trying all this in a 2012 PiP, and the audio/HU system was completely refreshed in 2012 with Entune and all that stuff. In fact, I realized that the Prius native voice dialer works just fine even if I never transfer the phone book to the car.
  18. TonyK51
    TonyK51 Junior Member
    44
    East Tennessee, USA
    yes, I realize this is an old thread but it has happend to me multiple times in our 2011 Prius Model 4. Both with iPhone 4S and iPhone 5.
    Have not been able to determine what the trigger is but something is causing the Prius to lose the iPhone phone book stored in memory. Re-importing the contact list and then re-setting the quick call feature is time consuming and annoying.
    Anyone else having this issue or know how to resolve it fully?
    Thanks,
  19. cbon22
    cbon22 New Member
    San Jose, California
    This happens to my wife's car every few months or so. She also has an iPhone. It happened again today. It isn't much trouble to reload the contacts, but losing the quick dial is very annoying. Haven't been able to detect what the trigger is; but am going to start monitoring it every time I get in the car. If you figure it out please let me know.
