Smart entry issue, questions about engine sound and maintenance interval question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ausgeschnitzel, Aug 29, 2014.
  1. ausgeschnitzel
    ausgeschnitzel New Member
    Helsinki
    Greetings, it's my first post here. I bought my 2009 Prius about a year ago. The car had ~114000 km on the meter (that's ~70900 miles for the metric system illiterate) and now has 120400. As you can see, I don't drive very long distances. The car has served me well without major issues but a there are a couple of things I'd like to ask about.
    The first one is a weird problem with the shotgun side smart entry. It had always been a little lazy, taking a few seconds with my palm in the door handle before anything happened. At some point it stopped responding at all. The driver side and trunk smart entry work just fine. Fast forward to recent days when it has been very rainy and damp. I noticed the driver's side unlocks very quickly at the smallest touch on the handle. Figures, it's wet so conductivity is better. Then I got the idea of trying the passenger side again. It unlocked again. Not as responsively as the driver side but well enough. Seems to me there is some sort of contact issue. Any similar experiences or ideas? Could I try something myself or just take it to a shop? Having it not work is not the end of the world so I'd rather not spend much money on it.
    Another thing I have wondered is my Prius' engine sounds noisier than my co-worker's. His car is a 2008 but has about half the kilometers on it. Revving the engine higher is more audible inside the cabin in mine. It does not sound wrong or faulty but it's just louder. Is it just expected as the car ages? Could the engine mounts be worn, causing more vibration?
    What's the replacement interval of fuel filters on a Prius? I couldn't find any mention of it by googling. I'm asking because I had an E85 kit installed and wonder if I should have the filter replaced. Even though the car has been running just fine, legend has it that a residue of gunk from petrol could come loose with the ethanol. Just to clarify, the engine noise isn't related to using E85, it was that way before it.
    In case you wonder why I would bother with E85 especially when I drive so little, well, because I could (I like tinkering with stuff) and because of political reasons. Also, our local E85 (branded RE85) is made from biowaste which makes a lot more sense to me than growing it on a field and actually has a small cost advantage because of taxation.
  2. JC91006
    JC91006 Senior Member
    16,470
    8,383
    The car was not designed to run on E85. You should google E85 to have a better understanding about engine compression and E85 fuel.
  3. bisco
    48,984
    welcome to priuschat! those are tough questions! i'm sorry, i got nothin' for ya.:(
  4. Patrick Wong
    18,199
    6,464
    It could be that a wiring harness connector for the antenna, touch sensor and the door electrical key oscillator on the front passenger-side door has a dirty or corroded contact.
    For North American models, the fuel filter is within the fuel tank so if you want to replace the filter, the entire tank must be replaced. Since you are in Europe you should consult the Toyota Europe techinfo site for repair manual info and to see whether the fuel filter is separately replaceable.
    Toyota Service Information
  5. ausgeschnitzel
    Helsinki
    Thanks for the replies.
    What do you mean, exactly? I know E85 has a higher octane rating and benefits from a higher compression ratio so cars specifically designed for it could squeeze more out of it. On the Prius the fuel consumption increase seems to go approx. proportional to the reduction in E85 energy content. It's not a dealbreaker to me, though.
    I see. That explains why it's not in the service schedule. :)
  6. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    I don’t think that you should replace fuel filter especially if you can monitor fuel trim numbers. Gas here in Finland is very clean and prius doesn’t have rusting tank or any other things that would block fuel system. By monitoring fuel trim numbers you also know if your e85 conversion kit is working properly. Re85 should be dyed to red (check that it is) so it’s easy to check if it gets to your oil if it does maybe you need to change it more often. I did that with my e85 converted corolla. Report if there is any starting problems in winter. With my corolla I needed to add 10% gas so that it did start in winter.
    PS: Kirjoitin englanniksi, vaikka suomikin olisi ehkä käynyt…
  7. Sadrac
    Sadrac New Member
    Ames, Ia
    Hey,
    I new here! My car is a 2009 too. Im in the USA. Did you got any answer about the engine sound? My car started doing the same like a month ago and I dont know what to do.
    Please help!
  8. Patrick Wong
    18,199
    6,464
    In both cases, the exhaust system should be inspected for holes or leaks.
