Airrex Suspension Prius Project Build
Discussion in 'Gen 3 Prius Accessories and Modifications' started by eight08customs, Aug 8, 2014.
  1. RightOnTime
    RightOnTime Senior Member
    744
    1,612
    183
    Kidnapped in OC, CA
    Hahaha! Not my car :(
  2. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    So that is LEDs in the front huh? Have u found a pic of the rear RightOnTime?
  3. eight08customs
    eight08customs Senior Member
    245
    583
    Hawaii
    Sorry for the lack of updates. but its just an waiting game for me for everything to come together.
    on a good note one main peice to the puzzle shipped out
  4. Accordlayingkit
    1,616
    1,747
    377
    What is it??
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,291
    Palmdale, Ca
    Haha, it's a surprise
  6. Accordlayingkit
    1,616
    1,747
    377
    My guess is it the Modellista body kit!
  7. eight08customs
    245
    583
    Hawaii
    JUst got the Airrex Suspension in.
    sfv41901 and Accordlayingkit like this.
  8. Accordlayingkit
    1,616
    1,747
    377
    When Ya gonna install!?
  9. eight08customs
    245
    583
    Hawaii
    got to find time in between all the other install i have to do. Still waiting for the wheels to get done and shipped. Ill prob just wait till the wheels come in that will take about month and half to build.
  10. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Marshall I would like to check your Prius out in person when you are all pau.
  11. eight08customs
    245
    583
    Hawaii
    Sure man hopefully before the end of the year ..
  12. eight08customs
    245
    583
    Hawaii
    Had some time to work on my Air install ..
    Using Airrex Elite Serise with
    1 Dual 3 gallon Specialty Suspension Seamless Tanks
    2 Single Viair 480 Compressor
    3 Stainless Steal Hard lines
    Doing a custom install in the spare tire well.
    I was thinkni ng what to do with the tanks as far as color goes and had a nice idea to stick with the theme of the car. Hybird..
    Im going to paint the tanks like a battery.
    Here is some past work i did on other cars.
  13. eight08customs
    245
    583
    Hawaii
    Put some wood working time in today on the base of the install.
    Whe perfection is needed. A router table is a must in Wood working. Used it to cut out templates
    WE could have just mounted the compressor on top of the wood but we are taking it one step further and
    installing a Pexi glass under and lighting it up with LED lights.
    Next is mounting the ECU and Manifold valve. We are going to be hiding the ECU under the Manifold.
    we will be using some fiberglass work to get the the rounded shape
    Justdidit and Accordlayingkit like this.
  14. Accordlayingkit
    1,616
    1,747
    377
    About how much is the setup you have if u don't mind me asking?
  15. eight08customs
    245
    583
    Hawaii
    Had some time today to get a little done. Made a template for the pexi glass floor for the compressor. Cut the pexi on the router table and cut a step in the wood so the pexi would be flushed on the under side.
    sfv41901 likes this.
  16. eight08customs
    245
    583
    Hawaii
    SLow progress but got to put some time into the car the last few days.
    Layed some fiberglass to make the curve for the ECU cover and Manifold mount
    After that layed a few layers of bondo to smooth it out . IT didnt have to be perfect becuase it was going to be covered up with Carpet
    Next was gluing on the carpet. We made a step in the wood so we could staple the carpet down than cut excess carpet off with razor for a clean look even though its the bottom side.
    With that all done we test fit again ..
    Next was the wiring
    Everything wired up .. just have to paint the tanks and make all the stainless hard lines and Plumb the system
    Accordlayingkit likes this.
  17. Accordlayingkit
    1,616
    1,747
    377
    ^Great job so far Bro!
  18. eight08customs
    245
    583
    Hawaii
    Little more done .. Did some of the stainless hardlines
    CT.Ross likes this.
  19. A617
    A617 Member
    213
    95
    OKC, OK
    How much did that air suspension kit cost ya?
  20. eight08customs
    245
    583
    Hawaii
    if i had just stayed with a Single tank and normal 380c compressor its was 5000.00
