2010 gen3- When to replace struts/shocks?
Discussion in 'Gen 3 Prius Fuel Economy' started by windstrings, Sep 15, 2014.
  1. windstrings
    6,278
    373
    Central Texas
    My 2010 had cheap tires on it and rode fine till I put 100k Michelin and then was very mushy, especially at high speeds.
    So I had them replaced with a bit firmer tires but still worse than the original by far.
    I run at 40/42 psi and that helps but not really a sporty feel like I like.
    I appreciate the smoother feel on road surfaces at lower speeds but high speeds with crosswinds is unnerving.
    Now the tire store I'm at "which I've used for years" and has always treated me right, thinks I need new struts and shocks.. I'm assuming shocks in back?
    My car has 150k.. When is it typical they need replaced?
    I searched and found a little about gen 2 but now gen 3.
    Any suggestions?
  2. windstrings
    6,278
    373
    Central Texas
    Oops I just realized I posted in wrong section... Mods please move to Maintenance and troubleshooting.. Thx!
  3. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Alan,
    I would think that after 150K the struts and shocks are probably fairly worn. Not sure which tires you have there. Got the Michelin Primacy MXM4 on our Prius. Have them aired up to 51F and 50R (17" tires and wheels). Rides and handles like a dream even in a strong cross wind. Much much better than our old Gen II was. Every time I passed a 18 wheeler or was being passed, I would have to counter steer to stay on the road. Not with the Gen III we now have. Not sure if it is the tires, new suspension or just what but this thing is rock solid on the road. Even when the streets are wet it stays firmly in place. Feels real comfortable and safe too out there on the highway even at 75 or 80. I usually don't drive the Prius that fast, but it is good to know that it does handle well at those speeds.
    Ron
  4. Roland1555
    Roland1555 Senior Member
    282
    68
    Vancouver BC
    Although I really think the problem is with the tires Alan, I was asking my service manager about the shock/strut issue with the GenIII's and essentially they have a super long life, not really determined by miles as far as their experience but likely by road conditions. Unless you can see any staining from leaking oil on any of your shocks, likely they are still fine.
    It's funny, but I recently replied to a replacement tire question elsewhere here and mentioned the user should at least take a look at the tires I went with for replacements. They are ultra high performance snows actually designed for year round use. The handling and over all responsiveness of these tires are remarkable. In your neck of the woods I don't think you need the snow and ice performance of these particular tires, but if you have any of the time limit left to switch to a different tire assuming your purchase is recent enough... check that out first I'd suggest.
    The tires I bought this time around are Nokian WRG3's and I run them at the door frame pressure cold... get excellent fuel economy and sharp but comfortable and quiet performance. I can't see changing to another tire when it comes time to replace these once worn out assuming I still am driving my 2010.... 5 years on her and likely get 5-6 years on these tires, but maybe the GEN 5 Prius will be tough to avoid....
    Tires make a huge difference on this car I find.
    Roland
  5. dorunron
    3,318
    1,103
    Houston, TX
    Absolutely, the tires on the Prius make a big difference in ride, economy, longevity and traction. Choose carefully and be educated about the tires you are going to purchase BEFORE you spend your hard earned money.
    Ron
    #5 dorunron, Sep 15, 2014
  6. qdllc
    qdllc Senior Member
    1,358
    396
    I remember the old "bounce" test for shocks, but it doesn't hold very true on newer cars and vehicles with good suspensions.
    My best "test" to know when your shocks need replacing is when you hit bumps and you notice your wheels skip more than they should because the shocks are letting the tire bounce rather than holding them in place. If you hit some "chatter bumps" and you have a skip or two, that's fairly normal. If it lasts longer than that, your tire is likely bouncing from the shock.
    Depending on your driving habits (pickup trucks tend to get it worse than cars), by 100K you need to be watching for this. No need to replace them if they are not bad, but if you replace one, replace all.
  7. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Just had the 200,000 KM service and my shocks are still fine despite considerable KMs on rural dirt roads. It depends on what sort of terrain you drive and the luck of the draw on the assembly line.
  8. qdllc
    qdllc Senior Member
    1,358
    396
    Also, while this indicates bad shocks/struts, if you have severe nose dive under heavy braking, that's an indicator that they need changing.
    It's not easy for me to explain, but in physics, once there is nothing left to absorb your forward momentum, the weight of the car shift more onto the front tires. This can overpower the traction that the front wheels have to help you stop. The springs and shocks/struts absorb enery and keep the full weight of the car from transferring into the wheels directly.
    It's easier to illustrate with a motorcycle. Brake hard enough and the back wheel comes off the ground (and this is why motorcycles on the street put the vast majority of braking power on the front wheel...as momentum shifts to the front, there is less weight holding the rear tire to the ground...reducing the effectiveness of the rear brake).
    If there was no suspension, turning or braking at any significant speed would get ugly very fast on what we are used to as wheels/tires.
  9. windstrings
    6,278
    373
    Central Texas
    Thx Roland, are those 15" tires?
    Also, what air pressure you running?
    Lol! Your famous, found your review too! Nokian WRG3 - The new Nokian WR All-Weather tires offer a virtuoso combination of safety and carefree driving pleasure for every season. / Nokian Tires
    #9 windstrings, Sep 15, 2014
  10. windstrings
    6,278
    373
    Central Texas
    Right, that's a good test for soft dampening but not so good for quick, but it's a start.
    I'm thinking tires too... I don't hit things "except coyotes and possums and Dodge a few armadillo
    Otherwise no pot holes etc.
  11. Keithstef
    Keithstef Junior Member
    17
    Northeast, Pa
    I replace my original rear shocks last week. 120,000 miles and thought it was time. The ride was not horrible, but felt like it was riding rougher that it use to.
    When I compressed a new and a used shock next to each other, they both seem to have the same level of slow speed compression.(Me pressing down at both at the same time and approximately the same force)
    Rebound speed was different between old and new.(Sorry I forget which one was slower...)
    Once installed, the ride it different. The is smoother ride and the ride height has increased. How much??? Not sure, but I noticed more room above the tire and the rear fender.
    They were very easy to change out the rears and the cost was not too bad.
    I did notice that the Toyota shocks are manufactured by KYB(Same shocks on my snowmobiles and MX bike ) Very good quality. Too bad they are not (easily) rebuildable. LOL! Cause a oil change and a Nitrogen recharge is all they need.
    Fronts are next.
  12. windstrings
    6,278
    373
    Central Texas
    Had an alignment done "it was a little off", that seemed to help some.
    But I'm getting prices from 850 to 1000 to do the whole job.. At this point I'm erring against it..
  13. Roland1555
    282
    68
    Vancouver BC
    I run my Nokians at the pressures listed on the door frame placard, 35psi front and 33psi rear with cold tires. (or not having been driven for over 3 hours)
    And yes Alan, my car has the 15" wheels just as pictured in my avatar... blizzard pearl ATP Canadian package.
    Roland
    windstrings likes this.
  14. Fred_H
    Fred_H Misoversimplifier
    546
    473
    26
    Germany
    Hi windstrings, although theoretically and statistically possible, it is unlikely that your shocks would suddenly go bad just at the same time as you get new tires.
    At least part of the "mushiness" of the new tires is, with absolute certainty, due to them being new. The thicker tread of new tires absorbs quite a bit more of small bumps, and deforms much more from side to side when cornering than the thinner tread of nearly worn out tires. This results in a smoother ride, slightly less cornering traction, and significantly slower and less precise steering response.
    If you replace worn out tires with new tires of exactly the same model, you will notice a big difference. I have done that, and I was surprised at the big difference.
  15. windstrings
    6,278
    373
    Central Texas
    I agree Fred.
    Although yesterday while mowing my yard, I briefly stopped too look at one of the sprinkler heads of my aerobic septic system, then rolled over it with my riding lawn mower with plenty of clearance.... While on top of it as I passed, the system came on, the head went up, and I chopped off the top of the head!
    2 seconds earlier or later that wouldn't have happened... What's the odds!
    Anyway, I think these walls are a bit thinner too.
    I will try and locate the Nokia tires.. Thx for everyone's help!
  16. Roland1555
    282
    68
    Vancouver BC
    Check out this little blog written by a fellow with a 2010 Prius, and he bought a set of Nokian WRG3's.
    Hakkapedia blog | Page 2
    I found it very helpful before taking the plunge myself. Plus I read European reviews and checked for Youtube information and reveiews of any and all tires that might be good for our cars.
    The elephant in the room when it comes to tires is now upon us, at least those of us with 2010 cars.... age of the rubber.
    There are fellow PCers here, who drive very few miles per year, they may also change tires and or rims for 6 months of the year to cope with winter conditions. The tires they have no doubt 'look' great and are not worn out in terms of tread depth... but they are now over 5 years old.
    There have been people killed, sometimes killing other road users because their tires have failed due to age.
    This can happen in hot weather, or even if you have to turn suddenly to avoid an obstacle on the highway, the tire basically self destructs.
    Very sadly, many tire retailers have and apparently still will sell people so called new tires, that have sat on a rack and are actually older than the recommended 6 years.
    If anyone hasn't heard of this issue with tires, learn about the 4 digit date of manufacture code stamped on your sidewall. The first 2 numbers are the week of the year, and the second 2 numbers are the year itself.
    I drive close to the average number of, miles, kilometers up here, and by having one set of tires on all year, not extending the number of years I might run by changing to winter tires.... I can use up and get my money out of the Nokians I have now as they have a treadlife that lines up with my driving pattern so that after 5-6 years they should be worn out before they get too old to be safe.
    Guess I am also suggesting, that if you don't drive a ton, why select something with a mega treadlife limit if the thing will be on your car for 10 years and could end up killing you because it is too old to be safe to drive on. Getting killed is worse than having to dispose of a tire that still looks good to your eyes and wasting some money. So be aware of how old your tires are in addition to how much tread you have on them to help with rain snow and slush, as well as keeping them properly inflated.
    Ok... enough preaching.... be safe and well out there folks.
    Roland
  17. windstrings
    6,278
    373
    Central Texas
    Don't have that problem! About 40k a year for me!
  18. Roland1555
    282
    68
    Vancouver BC
    That is a lot. Good for you, but when you read all the messages here, it is clear that many drive very little.
    Just an honest concern that others are not aware of the issues related to driving on old tires that visually may appear fine.
    Roland
  19. windstrings
    6,278
    373
    Central Texas
    True, also tires under inflated seem to wear faster when sitting
  20. windstrings
    6,278
    373
    Central Texas
    How come I can't find these tires?
    Either no one carries them or no one has the size, I use 195/65R/15
    Not here
    Nokian WRG3 Tires in Fort Worth, TX | Camp Bowie Tire And Wheel
    http://m.discounttire.com/dtcs/tires/nokian/home.do?r=TGRINT%7Cpc%7C76048
    Discount acts like they can't get them... Really? Then take them off your website!
    #20 windstrings, Sep 18, 2014
    kenmagill and pdj like this.
