Corroded AC wiring harness 2010 - anyone heard of this?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius-Alfa, Sep 15, 2014.
  1. alekska
    alekska Active Member
    435
    138
    Atl
    Newer heard of it. If this was design flaw, we would hear about this problem all the time. How many Gen 3 Prii are out there ? Close to 2 millions? But nobody mentioned it before you. So it must be very specific to your location/use/unlucky combination of factors. Maybe even manufacturing defect - they do happen, its just a question of how often?
    - Alex
  2. Den49
    Den49 Member
    498
    267
    Maryland
    Good thought about dielectric grease. Has anyone asked the dealer if cleaning and applying dielectric grease or other corrosion inhibitor to the connection is a good or bad preventive measure and whether there is a TSB for this problem? The design of this connection does look like it would promote corrosion. Having to replace an expensive compressor and wiring sub-harness because of something like this is outrageous.
    #22 Den49, Sep 16, 2014
    mertechperformance likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    If its like the G2 compressor there's only one wire harness and thats the HI VOLT line from the Inverter to the compressor. The orange harness. No splicey there.
    Must be replaced from the Inverter.
    Which is not a real big deal but hard to find an Indie that won't be afraid of that. Don't have the G3 book but Inverter may have to come out.
    First need to find out if its just the connector end on the harness thats rotted or the connector on the compressor itself also which would be a new compressor also.
    Need to pull the harness out of the compressor and inspect terminal condition but be careful make sure car is off off!!!
    HI VOLTAGE THERE WOOHOO!!
    It will as they say in the electrician trade turn your hat around.
    #23 edthefox5, Sep 16, 2014
  4. Mendel Leisk
    38,260
    Yeah, seems to me the main time this gets done is if the car has been resold, by a dealership trying to impress the customer.
  5. Den49
    Den49 Member
    498
    267
    Maryland
    I inspected the AC compressor electrical connections on my 2010 Prius with 68,xxx miles. There are two electrical connections to the compressor, the high voltage power connection on the side of the compressor and a low voltage control connection that runs to the various AC sensors and controls. It is this latter low voltage connection on top of the compressor that exhibits corrosion. Below is a picture of the low voltage connection on top of the compressor. Notice the corrosion at the bottom right corner.
    Below is a picture of the wire that plugs into the base of the connector. Notice that there is no corrosion on this part of the connection.
    Below is a picture of the base of the connector on top of the compressor with the wire disconnected. Notice that the corrosion is on the metal that the base connector sits on, not inside the connector where the pins are. It appears that water sits around the base of the connector and corrodes the metal. Presumably the metal will eventually corrode until it disintegrates and cause the connection to fail. So this is a real problem, but it looks like it can be managed by applying anticorrosion material to the metal around the base of the connector.
    The question is: what is the best corrosion inhibitor to apply to this area? It would be good to hear from a naval or automotive engineer, or materials expert.
    Also, is there electrolysis between the connection and the metal? Would dielectric grease inside the connection help prevent this?
    #25 Den49, Sep 16, 2014
    Roland1555, kc410 and xliderider like this.
  6. qdllc
    qdllc Senior Member
    1,358
    396
    My best guess is a liberal application of dielectric grease. It should do the job.
  7. Prius-Alfa
    Prius-Alfa Junior Member
    22
    Seattle
    "Exposure to salt water/salt air?"
    The car hasn't been driven through salt water and has been within a few miles of the ocean only a few days over the past five years. It rarely snows here so salted roads aren't an issue. Seattle is on Puget Sound which is salt water, but it is about 80 miles inland from the Pacific. It's not like the smell of the salt air is on the wind here. In general, cars don't turn into rust buckets here even with the rain and being next to Puget Sound. There are lots of old cars still on the road around here. If Prius electricals are corroding so badly here because of what little salt air there is, then it would seem they should be having much greater problems in places like San Francisco or Hawaii. I think kc410 probably has it right that the design of the connection to the compressor acts as a trap for water to accumulate on the connection.
  8. Den49
    Den49 Member
    498
    267
    Maryland
    ^Non of the above, rather after further inspection, I am fairly certain it is galvanic or dissimilar metal corrosion. The body of the compressor is a nonferrous alloy and the bracket that attaches the connector to the compressor is a ferrous metal. Therefore, I am going to put dielectric grease inside the connector, but I have not decided exactly which anti-corrosion inhibitor to put on the outside.
  9. bisco
    49,003
    great investigative work and pics den, very helpful, thanks!(y)
  10. Prius-Alfa
    22
    Seattle
    OK. Here's a photo of the offending AC compressor connection. The two pins you can see laying on the bottom of the well are corroded through at their bases.
    There is some green corrosion visible on the corresponding holes on the connector that goes here.
  11. bisco
    49,003
    i wonder if rain water could have gotten inside the connection? perhaps it was loose or defective.
  12. Mendel Leisk
    38,260
    10 minutes to dig down to that plug, then 30 minutes later: it's still plug 1, Mendel zero. I know there's a release at around 6:30 on the above pictures, but it's really playing hard to get.
  13. Mendel Leisk
    38,260
    So that connector's part-and-parcel of the compressor?
  14. bisco
    49,003
    good question, looks like it's fastened on?
  15. Prius-Alfa
    22
    Seattle
    The connector fitting on the end of the wiring harness is intact. No cracks that would cause a loose fit. Although the fitting acts as a sleeve that slides down over the outside of the receptacle on the compressor, the fitting has several openings in the sides that would allow moisture in
  16. bisco
    49,003
    sounds like poor design, but i wonder why we aren't hearing about it more often?
  17. Prius-Alfa
    22
    Seattle
    I wonder about that too. The Gen IIIs have been on the road long enough now that if this was common, people on this site would have heard of it. I just don't see what's special about our car that this would happen.
  18. bisco
    49,003
    right, and people drive in a ton of worse moisture than your area. strange that the dealer acted like they see it all the time. isn't it nice that when they sell you the car, they tell you it's bullet proof, then, when something goes wrong, they're like, well it's just the moisture in our area and low miles.???
  19. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    It does, but special fasteners, like I've never seen before. :confused:
  20. bisco
    49,003
    every time they come out with the special tool for the public, the mfg.'s come out with a new fastener.:mad:
