Combination meter bulb replacement
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, Sep 19, 2014.
  1. bwilson4web
    15,386
    Thanks to Paul, this is how it is done:
    Take the front bezel off and these two screws. The internal lamp carrier will flip out:
    Replace the burnt out light. I would recommend using the 'seat belt' light or the 'cold coolant' light. Seat belt because it really isn't needed by those with a clue. The 'cold coolant' light because it has no practical application. Then send me a private message with your mailing address.
    I had though about replacing the wheat-seed bulb with an LED but if the car lasts long enough for that, I'll do it then. Replacing with a LED requires finding out the polarity or adding a LED, bridge rectifier, and current limiting resistor. Not all that hard, I figure I'll have at least another 10 years to figure it out.
    The following instructions show how to access the logic board:
    I've removed the lights but the back shows five screws holding the back on. For our purpose, only the front, black fascia needs to be removed and the two screws on middle, right near the beeper.
    There is a flat cable that feeds the lights on one side that has to be disconnected IF the logic board is being removed. It is not necessary if replacing a burnt bulb.
    At the lower center and left, are what appear to be tilt or possibly air bag deployment sensors. These have to be removed to take out the logic board. But this is not necessary if replacing a burned out light. My light, the cruise control, is in the box to the right. Removing the two screws on the back holding it on makes it accessible.
    Here is a light in its socket and twist base.
    Here the logic board has been removed, not necessary to replace a burnt out light. The lights and socket are on the right and it is held on by two screws.
    #1 bwilson4web, Sep 19, 2014
    robert mencl likes this.
  2. LEVE
    LEVE Member
    191
    97
    On the Willapa
    Maybe this can speed up the process:
    LED Resistor Calculator
    Ten years is a long wait!
    Next question, can you put the LED/resistor circuit in the OEM bulb base? That would make a clean installation.
  3. bwilson4web
    15,386
    I can not find a polarity aspect of the mechanical light base. This means the incandescent light can be rotated 180 degrees and work just as well.
    I have not ohmed out the circuit but since these are logic level controlled, I suspect one side is logic controlled and the other is either ground or (unlikely) Vcc, a simpler electrical configuration.
    LEDs are polarity sensitive so I would need to install a LED with a current limiting resistor with the right polarity. A bridge rectifier solves the polarity problem and allows a smaller current limiting resistor.
  4. ChapmanF
    15,055
    I'm pretty sure Bob could calculate a resistor for an LED with his eyes closed. The trickier bit, as he points out, would be following back the printed-circuit traces to figure out which side of the light carrier should be the anode. Unless you just want to throw a bridge rectifier on it and call it good.
    None of that's impossible, but when the replacement bulb 90010-06019 is all of $1.70 over at Village Toyota Parts and your time is worth something, and it uses all of 1.12 watts when it's on and it's off most of the time ... the question could come up, what would the LED save you?
    Now ... if somebody wanted to figure out the right polarity for all the bulbs in the combo meter, and design little LED + resistor + base thingies to replace them (with due attention to matching light output and appearance and all that), and upload those to the thingiverse so anybody who wanted to could 3d-print and build them ... that might be a fun project. :)
    -Chap
  5. bwilson4web
    15,386
    No, I would probably use two, white LEDs wired in series, reverse polarity, with a current limiting resistor on each. <GRINS> DAMN! Sounds like a patentable device . . . wheat-bulb replacement LED.
    • CHEAP, FAST - . . .
    NOTE: it also works for AC feed.
    #5 bwilson4web, Sep 19, 2014
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    What happens if the LED polarity is wrong ?
    If it just fries the LED then I say start with five and replace four ;)
  7. bwilson4web
    15,386
    Looking for parts, I found a simpler circuit with two LEDs in reverse polarity, parallel and a current limiting resistor in series.
    Bob
  8. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    Sage, I had to try it, reverse polarity did not fry the LED, it just didn't pass current the other way like a good little diode. So it looks like you would be safe to prep some bases and if installed wrong and they don't light, just turn them around. "Polarity aspect" is now a new term in my vocabularity.
    I tried it on some Chinese bare LED's on I had on hand- I am making a separate 12v circuit in my house for lighting so I can run bare naked LED's without the wasted energy and heat of the rectifier-transformer circuit in the bases of the 120v. led bulbs. Their price was awesome, enough bare LED's for the whole house, with a lifetime life expectancy- cost less than a pack of 4 incandescent bulbs!
    Using these in hard-to-reach places like the combination meter could prevent ever having to pull that sucker out again.
    On the efficiency side, you've got me thinking about changing my headlights and running lights to LED, reducing the load on the DC-DC converter and possibly extending its life, and it would be great for those hard-to-replace headlights, once and done. I see some headlights on Ebay for $2.42 each.
    SageBrush likes this.
  9. bwilson4web
    15,386
    Just use a 12V step down transformer and the dual-LED with current limiting circuit means the LEDS only conduct half the time.
  10. ChapmanF
    15,055
    I'm pretty sure I can pop my combination meter out and back in again faster than I can usually decide if you're kidding. :)
    There genuinely are some spots in my house I'm thinking of using LED tape that runs on 12V nominal. Underside of the bookshelves over my desk is one, and considering the stack of little chargers, peripherals, routers, etc. that all sit right there plugged into their own individual 12V wall warts, one larger 12V power supply would make good sense right there. Inside of the dark cabinet the stereo lives in would be another.
    The LED tape isn't yet close to the lumens/watt you get with Cree's Edison-base bulbs at Home Depot, and the lumens/dollar could also still use some improvement, but all that's improving so fast....
    For wiring the whole house with 12V circuits (and not just local areas like a desk or cabinet), I'd still have to think hard about wire gauge and current. Compared to all-incandescent, all-LED could use maybe a fifth of the power originally budgeted for lighting ... but at a tenth of the voltage, that's still twice the current ... I haven't yet looked at what wire gauge it would take to keep the losses down.
    -Chap
  11. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    Thanks Chap, I will look at ampacity. I am using all 120v LED now, Ariston micro hot water heater, induction cooktop, large convection oven/mic, threw out the cookstove. Got the power bill down to about 20 bucks a month, and enjoy cooking more. The waste heat from lights no longer causes the AC to kick in at night when I stay up to read.
    35 years ago I set my camp in Maine up all 12v and it was great, but today there are such lower draw devices available. I didn't mind paying $8 for Cree led bulbs last year, and would have paid $100. for one 35 years ago.
    I want to start using some solar panels and want to avoid the conversion losses of going dc-ac-back to dc at the LED. Same problem with inverter mini split air conditioner.
    #11 robert mencl, Sep 22, 2014
