How can I mod the DRL to have it on at all time? (for 2013 models)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by m3rhkp, Apr 26, 2013.
  1. itommytang
    itommytang Junior Member
    Roseville, California
    So this may be a dumb question but I just want to make sure, you don't put the relay back in that you took out right?
    Second, can you still turn off all the lights on the car from the stalk or does the drl now stay on when the car is on?
  2. StarCaller
    StarCaller Senior Member
    1,240
    692
    Cedar Crest, NM, USA
    with the jumper the drls come on as soon as your dash says 'ready'. they'll go off (obviously....) once you shut the car off.
    BION
    StarCaller
  3. KeepitSimple
    KeepitSimple Member
    128
    Washington, District of Columbia
  4. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
  5. Lakerfan02
    Lakerfan02 Junior Member
    29
    17
    Having trouble finding what kind of wire that is you guys are using?
  6. StarCaller
    1,240
    692
    I just used a decent 12 gauge wire/
    BION
  7. Lakerfan02
    29
    17
    Where can I get this 12 gage wire?
  8. xliderider
    7,848
    3,102
    Honolulu, HI
    Anywhere, even Walmart automotive section has it, AKA ignition wire.
    SCH-I535
  9. Lakerfan02
    29
    17
    what about the end that connects to the fuse box?
  10. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    Is called Mini Blade "Add-A-Fuse" or "Add-A-Circuit" or sometimes called "Tap-A-Fuse"
    Your local Auto Stores might have it but cost alot than ebay.
    Good Luck!.......btw: this is my 1st post in months!!!
    Lakerfan02 likes this.
  11. xliderider
    7,848
    3,102
    Honolulu, HI
  12. Lakerfan02
    29
    17
    got the wire but it doesn't fit it's the smallest size I found at autozone. Am I missing something?
  13. xliderider
    7,848
    3,102
    Honolulu, HI
    You have to cut off the Blue connector and put one of these on:
    Or, if you have a longer run to your tapped fuse, don't cut off the Blue connector and crimp a length of wire in between the Blue connector and the male push on terminal.
    SCH-I535
  14. Lakerfan02
    29
    17
    So I am cutting both ends correct?
  15. xliderider
    7,848
    3,102
    Honolulu, HI
    Nope, you leave the fuse tap end alone. That will replace the fuse you are taking your Ready mode power from.
    SCH-I535
  16. Matthew Mai
    Matthew Mai New Member
    Riverside, CA
    BUMP of an old post.
    When I plug the piggyback fuse mod I made my DRLs no longer work. Any idea why this is? I reversed everything and they work again but I want them to stay on with my headlights. Thanks!
  17. Tim Fancher
    Tim Fancher Junior Member
    Look at the pictures attached on tab 3 of this thread. There are 4 pix that show clearly what relay to pull and where to attach wire.
  18. Matthew Mai
    Riverside, CA
    That is what i originally followed. This is what I made and how i connected it but as stated before. No luck.
    Tim Lucchino likes this.
  19. xliderider
    7,848
    3,102
    Honolulu, HI
    You probably plugged the terminal from the tapped fuse into the wrong socket/connector in the DRL relay socket.
  20. Matthew Mai
    Riverside, CA
    Its the middle one where the DRL relay socket is correct?
