Project: Angry Panda
Discussion in 'Gen 3 Prius Accessories and Modifications' started by RightOnTime, Sep 8, 2014.
  1. RightOnTime
    RightOnTime Senior Member
    744
    1,612
    183
    Kidnapped in OC, CA
    Wanted to go a different route on a front lip and decided to purchase a Modellista Version 3 lip.
    The front lip arrived painted to match the color of my car and being from Japan the fit was perfect!
    Installation pics:
    Burna J, Accordlayingkit and sfv41901 like this.
  2. RightOnTime
    744
    1,612
    183
    Kidnapped in OC, CA
    Well it was time to get the car lowered, so i decided to go with Tein Street Advance Coilovers Suspension. The best part of living in Southern California is that there main headquarters is local. This helps out if the Coilovers need to be rebuilt or re-valved in the future.
    Overall:
    The Coilovers did stiffen up the ride and gave the car a more sportier Suspension and feel. With 4K springs front and back the car felt alive and was ready to take the corners!
  3. RightOnTime
    744
    1,612
    183
    Kidnapped in OC, CA
    Took the car over to West End Alignment to get the car Align and Corner Balanced. From the print out below (TOP) is a measure of the weight from each individual wheel that is measured on individual scales.
    The get the car Corner Balanced ---- The Front Left + Rear Right must equal the same values of Front Right + Rear Left which was 1583.
    I must recommend this procedure if you have Coilovers, one side may be lower than the other which may contribute to alignment problems and stability at higher speeds.
  4. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    U still have the front lip?
  5. RightOnTime
    744
    1,612
    183
    Kidnapped in OC, CA
    The front lip took the casualty of a orange cone that was in the middle of the Freeway :mad:
  6. sfprankster
    sfprankster Active Member
    443
    490
    Santa Cruz Mountains, CA
    Hope that orange cone paid dearly for the damage done. :cry:
    #26 sfprankster, Oct 20, 2014
  7. Accordlayingkit
    1,616
    1,747
    377
  8. RightOnTime
    744
    1,612
    183
    Kidnapped in OC, CA
    Yup, that cone payed dearly as it was dragged under my car for another 2 miles :cry::cry:
  9. RightOnTime
    744
    1,612
    183
    Kidnapped in OC, CA
    6/06/13 some more goodies came in!
    Wanted to go a different route and purchased:
    1. Prius G's Headlights
    2. Prius G's Taillights with fog option
    Dylan Doxey likes this.
  10. RightOnTime
    744
    1,612
    183
    Kidnapped in OC, CA
    The G's Taillights are quite different from the US specs. Here are a couple of pictures as compared to the Plug-In Taillights
    saulbassfan likes this.
  11. Accordlayingkit
    1,616
    1,747
    377
    What's the Mugen rear strut bar on?
  12. RightOnTime
    744
    1,612
    183
    Kidnapped in OC, CA
    With the almighty help from Sean(sfv41901) (y)(y)(y)
    He was able to help me with the wiring harness for the G's Headlights and i was good to go!
    sfv41901 and Burna J like this.
  13. RightOnTime
    744
    1,612
    183
    Kidnapped in OC, CA
    [/QUOTE]
    What's the Mugen rear strut bar on?[/QUOTE]
    Strut Bar is for my Integra Type R
  14. Accordlayingkit
    1,616
    1,747
    377
    Did you have side skirts and a rear lip on n this pick or do I need to jus slow down? Because it's coming haha
  15. Accordlayingkit
    1,616
    1,747
    377
    Strut Bar is for my Integra Type R[/QUOTE]
    That's right.... your profile pic used to be the intergra Right? I was wrong...was thinking about mcmmotorsports with the Integra profile pic haha
    #35 Accordlayingkit, Oct 22, 2014
  16. RightOnTime
    744
    1,612
    183
    Kidnapped in OC, CA
    Muffler: Ganador Pasion
    Well it was time for another upgrade, so i decided on a bolt on muffler that would give me mid range torque and Yes, improved fuel economy!
    This muffler is made specifically tuned for the Toyota Prius and is not a simple universal muffler that can be welded to any car. It did take about 1 month for the muffler to finally arrive but it was worth the wait!
    The Ganador Pasion muffler has two options to choose from:
    Polished Tip
    Hyper Blue Polished Tip (My Choice)
    Underneath shot
    Stock Muffler/Ganador Pasion
    Installed
    sfv41901, Burna J and Accordlayingkit like this.
  17. RightOnTime
    744
    1,612
    183
    Kidnapped in OC, CA
  18. Accordlayingkit
    1,616
    1,747
    377
    ^How expensive?
  19. RightOnTime
    744
    1,612
    183
    Kidnapped in OC, CA
    Everything purchased in Japan is expensive! You can check Yahoo! Japan Auctions for a good price.
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,291
    Palmdale, Ca
    Sad but so true
