  1. xliderider
    xliderider Senior Member
    7,849
    3,102
    Honolulu, HI
    What does it look like against a flat wall from a distance? How hot does the lens/vinyl get?
    SCH-I535
  2. sfprankster
    sfprankster Active Member
    443
    490
    Santa Cruz Mountains, CA
    A flat wall is a tough commodity to come by here. My house is built into the mountainside and the deck goes around the other three sides. So I won't get the chance to check the light pattern until I go to Santa Cruz tomorrow night after work. I'll see if I can get a pic of the pattern into the stairs or the dirt hillside in front of the car. I am mainly attempting to create less light going above the HID headlight cutoff off the bottom of the light body/reflector.
    As to the heat, sitting still the glass lens gets fairly warm, but not to hot to touch. And when moving, the flowing air and the heatsinks keep them barely above a lukewarm temp. If it does ever get too hot and begins to peel, it was only a few pennies worth of vinyl and less than 20 minutes to make. ;)
  3. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    colors...
    ckam1989 likes this.
  4. xliderider
    7,849
    3,102
    Honolulu, HI
    I thought of doing this before, but only tried it with dark gray translucent vinyl. Needless to say, it wasn't very effective at reducing glare. :( It didn't occur to me to use opaque vinyl. ;)
    Then I thought of fabricating some louvers or slats to keep the light going out at a level to low angle while screening out high angle light. But I never got around to making it.
    Yours looks pretty retro, like those WWI era pictures of vehicles during air raid times with painted headlights.
    SCH-I535
  5. sfprankster
    443
    490
    No fog lights on:
    With only the HID fog lights on:
    The car is sitting approximately 4" below the bottom concrete step. Tough to see in the daylight, but the yellow light really shows behind the second step on the hillside, with very little light going above the second step. After it gets dark, I'll take a few more pics to see where the cutoff occurs as compared to the headlights.
    The idea came from an image I found on Amazon for LED fog lights...
    #5365 sfprankster, Oct 20, 2014
  6. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
  7. Accordlayingkit
    1,616
    1,747
    377
    What the heck is that!?
  8. sfprankster
    443
    490
    A Cylon from Battlestar Galactica?
  9. Accordlayingkit
    1,616
    1,747
    377
    OK I'm a dummy... cargo leds working now after the fuse was blown because the wires touched during install because of the plug coming off when it was shipped in the box! It was wrapped in the white paper and I didn't see it until today. Oopps sorry @sfv41901 for wasting your time asking u questions on this!
    RightOnTime likes this.
  10. sfprankster
    443
    490
    I just ordered a set of those a few days ago(17th). How long did it take to ship them?
    I'm assuming they came from Share Style in Japan.
  11. Accordlayingkit
    1,616
    1,747
    377
    Ordered 9/5/14 and delivery on 9/16/14 from eBay mitaccessories (topsage)
    Jus got around to putting them in
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    No worries. Glad it was just a fuse.
  13. rcs3434
    rcs3434 Member
    56
    163
    Danbury, ct
    image.jpg Put on my new summer rims, konig feathers 17x7.5, will rock them for a few weeks and switch back over for winter. Couldn't wait 6 months and not see them on.... I know it's 4x4 status but I figured I'd wait till after winter to put my springs on image.jpg
    Ramtart, RightOnTime, Burna J and 2 others like this.
  14. Accordlayingkit
    1,616
    1,747
    377
    What's that above the Hybrid emblem.. a zit? on both sides lol
  15. rcs3434
    rcs3434 Member
    56
    163
    Danbury, ct
    Lol, never thought of it like that..... It's a toyota logo sticker that was part of the pin strip that was on the car when I got it, never thought to take it off when I dipped it.
  16. Accordlayingkit
    1,616
    1,747
    377
    haha OK I was sitting here thinking about mine and after I seen it on both sides I was like what n the world could be there as I knew I didn't have anything above my hybrid emblem
  17. sfprankster
    443
    490
    Update pics, taken without a flash or any additional light sources, of the 3k HID fog lights, w/cutoffs, and 5k HID headlights, showing the overall light pattern:
    No more yellow light is showing from the fog lights, in the overall light pattern, above the 5k HID headlights pattern.
    ckam1989 and xliderider like this.
  18. xliderider
    7,849
    3,102
    Honolulu, HI
    What's the distance between the stairs and the lights? If it's too close, the lights could be rising, but it may look ok. Increase the distance, and the light might be able to spread up more. If it's about 20 to 30 ft and no stray light above lowbeam cutoffs, then yes, I'd say glare is gone. ;)
    SCH-I535
  19. sfprankster
    443
    490
    Pic taken with the car backed up 26' from the stairs/hillside, from the hood of the car:
    Just the slightest amount of yellow light showing above the headlight pattern cutoff from the fog lights. I can adjust the fog light to project a lower pattern on the housing itself.
    xliderider and ckam1989 like this.
  20. xliderider
    7,849
    3,102
    Honolulu, HI
    Looks good. Thanks. :)
    Maybe I'll try Plastidip on my Camry foglights. Easier than getting and cutting vinyl.
    SCH-I535
