2010 Prius Coolant Drain Bolt
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nicoj36, Oct 20, 2014.
  1. nicoj36
    nicoj36 Active Member
    495
    156
    Does anyone have a picture of the drain bolt for the coolant on 2010s? Trying to do a coolant change. Thanks :)
  2. Mike500
    Mike500 Senior Member
    2,593
    763
    The ecu inverter drain plug is located on the bottom of the transaxle. On the Gen III's, it is the same 10mm socket hex as the transaxle fluid drain plugs.
    I made up several kits that replaces the plugs with a much easier to use hex head with a complete set of washers.
    I am posting photos of the OEM plug and my kit which includes a rare earth neodymium magnet transaxle drain plug and two other plugs with the aluminum gasket washers.
  3. Mendel Leisk
    38,247
    Engine or inverter coolant? Oh heck, here's both. The pictures of engine drain bolt is lousy, but at least indicates rough location.
    CT415 likes this.
  4. nicoj36
    495
    156
    Thank you sir!
