Prius C with Corolla Radio
Discussion in 'Prius c Audio and Electronics' started by Jt Torres, Jul 14, 2013.
  1. Motov8r
    Motov8r Member
    102
    the corolla radio has different dimensions (wider) than std double din. metra probably would work if you hacked it up.
  2. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    #82 ROLOPR, Aug 9, 2014
  3. Motov8r
    Motov8r Member
    102
    Rolopr, do you know if JT is still selling his plate?
  4. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    As far as I know JT doesn't sell anymore.
  5. Southernmost
    Southernmost New Member
    2014 Prius c
  6. lp8788411
    lp8788411 New Member
    2014 Prius c
    Just got a 2014 C Model 2, and really wanted the sat nav. I've been looking for after market stuff that looks more like the stock model 4, on the cheap.
    Any thoughts on getting junkyard parts? Just came across a site called automotix and found 38 GPS radios in stock... under $200. Also saw several 2013 Corolla radios for less than $150 -any thoughts. I'd have no idea which one to get.
  7. AlfredoMR
    AlfredoMR New Member
    Guayaquil, Ecuador
    Hello jonpk, One question, I bought and install the same radio you have, the back lit buttons you mention are the ones in touch screen... did the power, audio, tracks, setup, etc buttons also have orange back lit? since in my radio those button do not have back lit, or maybe the radio i received is broken... don't know, please confirm me this. Thanks.
  8. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    the backlit on those buttons will only come on with headlights AND if you turn up the brightness of your car's interior dash lights (on the knob to the right of the steering wheel that controls the brightness of dash lights)...if the knob is turned all the way down (lowest brightness of dash with headlights) then you won't get any backlit
    and yes those backlit are orange/lava colored in nature (it is probably green for those who have the highlander radio instead)
  9. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    yes the highlander radio has green backlit buttons. They only turn on with the headlights and if your dash light dial are high enough.
  10. AlfredoMR
    Guayaquil, Ecuador
    I dont have the dash light dimmer in my car !! I guess I'll have to order one switch. When I turn on the headlights the radios button won't turn on and the you can't see them in the night.
  11. SwhitePC
    495
    214
    ca
    wow...that's cheap of toyota of Ecuador I guess. What's that dial next to the side mirror control?
  12. AlfredoMR
    Guayaquil, Ecuador
    It's dimmer that controls the "range angle" of the headlights, the part I need is the Light Rheostat 8411942020, I hope this can connect to the main electrical system.
  13. kingnba6
    1,018
    242
    NY
    did you car come with HIDs or LEDs?
  14. AlfredoMR
    Guayaquil, Ecuador
    HIDs
  15. kingnba6
    1,018
    242
    NY
    do you have a picture of your headlights? i am wondering what OEM hids look like.
  16. AlfredoMR
    Guayaquil, Ecuador
  17. kingnba6
    1,018
    242
    NY
    thanks for the pictures. do you also have an output picture of the hids against the wall?
    also regarding the radio; did your stock radio have the back lit buttons?
  18. AlfredoMR
    Guayaquil, Ecuador
    Yes, my stock radio had lit buttons.
  19. kingnba6
    1,018
    242
    NY
    hmmm interesting that your new radio doesn't work. i honestly dont see why the new radio lights wont work but the old radio, which uses the same connections, works.
  20. SwhitePC
    495
    214
    ca
    It's just the nature of the beast that the stock radio is programmed (or w/e) so that backlit comes on when headlights come on (no matter the position of the dash brightness dial), while the corolla/highlander radio may not be programmed in that way for the C...
    But it's just weird that your country doesn't require a dash brightness dial for vehicle (s)
