  1. *Goldfinger*
    *Goldfinger* Junior Member
    79
    17
    Sheffield, England
    I have read there is a dash dimmer, for adjusting the brightness of the speedo etc. I have a 2007 UK spec Tspirit but for the life of me I can't find it. Was it included on the UK spec model? If so where is it?
  2. vskid3
    vskid3 Active Member
    773
    228
    Down and to the left of the steering wheel for the US version. Might be opposite for you. Only has an effect when the headlights are on.
    Image borrowed from this thread: EV button like switch | PriusChat
  3. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Is it mentioned in your manual?
  4. dolj
    dolj Senior Member
    7,448
    3,751
    Wellington, New Zealand
    No it's totally different for the UK T-Spirit, and yes, it is in the manual.
    It should be the right most button under the MDF, and it has two jobs. It has a symbol on it that I think is supposed to look like a speedometer.
    Job one is dimming the dash and MDF -- quick presses. This only works when the headlights are on.
    Job two is toggling the speedo display between km/h and mph for use in Eire and Europe -- press and hold for about 2 secs.
    hope this helps.
    #4 dolj, Nov 26, 2014
    ftl and *Goldfinger* like this.
  5. *Goldfinger*
    79
    17
    Sheffield, England
    Got it, thanks very much :)
    Thanks for your help vskid
  6. GregP507
    GregP507 Senior Member
    3,002
    480
    I wish there were separate dimmer controls for the head unit. I know the brightness can be set in the menus, but a separate knob would actually be convenient.
