RIP PiP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by cyclopathic, Nov 26, 2014.
  1. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    John how 60 cents a mile? What's your elec cost out there?
    EDIT: I meant 60 cents/50 miles
    #21 wjtracy, Nov 28, 2014
    49,002
    not .60/mile, 50 miles for .60, i get 60 miles for .50, .16/kwh and 10=20% less in winter. check out the sticky spreadsheet. ymmv:)
  3. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    If I were to take advantage of the special discounts for plugging in at home, it's only 4.5 cents per kWh. The norm is just 11 cents. So, a realistic/typical full charge is 2.75 kWh, which comes to 30 cents. Figuring 12 miles per, that brings us to $1.25 for the 50... still half that of gas.
    The true advantage/persuasion really doesn't emerge until gen-2. But this is a good start.
    Remember, it's not dollars alone that makes it a better choice.
  4. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    50mi for $0.60 how? EPA (which we sticking to) lists PiP electric at 29 kWh/100mi. Are suggesting your electric rate is 4.1c/kWh?
    at $0.16/kWh cost would be $2.32 vs $2.67gal at local prices. I concede by charging PiP you're actually saving $0.07 per charge.
    And electricity cost would go down?
    And as soon as batteries get cheaper, Toyota will send you a rebate check in mail?
  5. cyclopathic
    3,292
    547
    2014 Prius c
    I can't argue with that. Every situation is different, so if PiP could get you into HOV/HOT lane free that alone could worth it.
    As is, with the fear repeating myself, PiP isn't really economically viable unless it also offers an MPG improvement in hybrid mode. YMMV
  6. john1701a
    12,749
    5,243
    57
    Isn't this thread about the future of PiP?
  7. bisco
    49,002
    i think doug made the future of the pip look bright!
  8. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    I charge once a day, and get about 15 miles per charge. 15 x 365 = 5,475 EV miles. It takes about 3 kW to fully charge at $0.18 per kWh which is what I pay. So my cost per EV mile is 3.2 cents per mile, versus gas at $3/gallon and 50 mpg is 6 cents per mile. So I save $153.30 annually. At $4/gallon, I would save $262.80 annually. Gas would have to be $1.60/gallon for the break even point, so I charge whenever I can. My annual savings are also conservative because I can take advantage of free charging about 10% of the time.
    So you're correct that it would take a long time to recover a PiP surcharge. But like I said before, I bought the PiP for less than a regular gas Prius (just under $20K + TTL after all rebates). Therefore, for me there was no "PiP surcharge" to recover.
  9. cyclopathic
    3,292
    547
    2014 Prius c
    We have to come to agreement on which numbers to use. EPA rates PiP range at 10mi; if you're getting 15 this is great! However I am getting low 60s on gas (best tank 68mi at 670mi/tank), shouldn't we use that as a baseline? Or perhaps those who got MPG in 70s would be a better choice?
    Personally I am applauding the idea of electric car and attempt to break away from fossil fuels. However the engineer in me sees that the technology is not mature enough and it has problems to be solved:
    - low energy density for batteries
    - long charge time
    - overwhelming fossil dependency of the grid
    - and it is not cost effective.
    Edit:
    BTW 3kWh x $0.18 /15mi = 0.54/15 = 3.6c, not 3.2.
    so 2.4 cent x 5,475mi = $131.4 a year.
    #29 cyclopathic, Nov 28, 2014
  10. bisco
    49,002
    agreed, but current technology doesn't lead to obsolescence, it leads to better technology. the current pip can't be judged against current gassers, they been improving for 100 years+.
  11. se-riously
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    You can use whatever you want for a baseline. PiP isn't for you. PiP was for me. For the 3rd time (which you always fail to quote), there was no PiP surcharge for me, so there's no question that it was cost effective. If you want to dollars and cents, it's unusual but true that my car cost less brand new than a used one would have.
    And thanks for the correction on the math. I'm not complaining, because it's still money saved, and still a conservative estimate given 10% free charging available to me.
    lensovet likes this.
  12. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    You do realize, your OP compared a $30k PiP to an S60 at $80k and then proclaiming RIP PiP. Both are not good comparisons as they are unlikely to to be cross shopped.
    Overall, though, I agree with you. The technology is not mature enough. That's why the government gives us solo HOV and generous rebates. But that is no reason to proclaim the PiP dead. When the first gen Prius came out with it's 45 mpg and <$2 a gallon gas prices, I thought only idiots would buy it. You save no money. Now, I own a PiP and my numbers concur with se-riously. There is no surcharge to own one for me... unless gasoline remains under $3 a gallon. FYI, I get 70 mpg including electricity with a 53 mile per charge commute, much longer than most people's commutes.
  13. MikeDee
    MikeDee Senior Member
    1,536
    583
    San Francisco Bay Area
    I'm envious of what some of you are paying for power. I'm in PG&E land in the SF Bay Area, and I would pay over $.30 per kWh to charge a PIP. It makes no economic sense for me to change to a time of use plan since I need A/C during the summer. Solar power doesn't make economic sense for me either.
  14. roflwaffle
    roflwaffle Member
    381
    75
    Orange County
    That's about right. Using the fueleconomy.gov defaults for your 30k miles/year I'm seeing payoff in ten years/300k miles per the attached screenshot. That excludes any advantages in maintenance (few/no brake jobs) and possibly better reliability.
    I think you're confounding one thing. People in densely populated metro areas will have short commutes with more city driving, not longer commutes.
    The higher insurance premium also reflects a higher residual value (More value to insure), and my guess if the higher residual value of the Prius C is what someone is paying for. It's also the advantage if/when they sell the car or it's in an accident.
    The insurance premium also won't always be $1000/year unless the driver has a really crummy record. It'd start at ~$1000/year and decline to ~$100/year at the end of a decade IME. It still eats up a big chunk of the gas savings, but not all of it over 10 years, and at 10 years the C will almost certainly be worth thousands of dollars more than the Mirage.
    I'm not a middle aged suburbanite. I'm thirty+ living in a region with a population of 3+ million, and if a Prius C is less expensive for me then a Mirage, it's likely less expensive for the majority of drivers.
    I suspect it's less expensive even for very young (~20yo) drivers even after the higher insurance premiums if you were to include the greater residual value. It'd be neat to throw in a spreadsheet to examine in detail.
  15. Chabelo
    Chabelo Junior Member
    24
    Valley Springs, Ca
    2014 Prius Plug-in
    my sole criteria for the PIP was th HOV sticker for CA, this saves me 20-40 minutes a day which is... priceless...
    PriusC_Commuter likes this.
  16. cyclopathic
    3,292
    547
    2014 Prius c
    Perfectly makes sense.
    if I lived in CA I'd be riding a bike every day. Nice weather all year around, all the fun lane splitting, no gridlock whatsoever for under 6K with 64MPG, eh?
  17. wjtracy
    11,314
    3,588
    Northern VA (NoVA)
    Here would be my rough approximation for EV vs. gaso miles:
    Base case: About $4/gal gasoline is approx. equal to 25 cents/kWh in EV use
    So if gaso = $2.50/gal equivalent elec cost per gal (approx.) = 25 x $2.50/$4.00 = 15.6 cents/kWhr
    Of course you can beat this via hypermiling techniques or charging for free at work etc
  18. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I'll agree that the comprehensive & collision parts of the auto insurance will decrease over time but in NJ it is not 10% per year. I wouldn't expect the Personal Injury Protection portion to change much because the car in its tenth year can do as much damage as in its first year. Year to year I don't see much of a change.
  19. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    what are your other assumptions to arrive at that ?
    I found even in NewEngland with 3 freezing months I averaged 12.5 EV miles per charge so 50miles on 4 full charges.
    (20-25% better in warm weather)
    Using your 15.6 cents kWh that makes a bit under 50 cents per charge = bit under $2 for the 50 miles (or sub $2 gas)
    reading through all these posts it seems pretty clear that there's a huge range of electric prices
    Someone in WA was paying under a dime ! sweet, clearly makes a plug in worth it
    Someone in SF stated 30 cents / kWh ?! no PiP for you !
    #39 fortytwok, Nov 30, 2014
  20. wjtracy
    11,314
    3,588
    Northern VA (NoVA)
    ^^^I am 12 cents/kWhr so gaso has to get down to $2 to be as cheap as elec. I might get a PiP someday but I hold cars a good many years.
