Low Rolling Resistance replacement tires: Current List
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Apr 17, 2011.
  1. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    Well, was just told to think about new tires on my 2012 four. 31000 miles, 50.5 mpg on OE tires.
    Starting to catch up on this discussion. I think my OE tires are P195/65R15.
    Suggestions? Would like to keep mpg and reduce noise.
    [I need to update fuelly]
  2. Mendel Leisk
    38,953
    Ecopia EP20 will not miss a beat with the mpg, but do get a bit noisy when worn.
    HaroldW likes this.
  3. Matt H
    Matt H Active Member
    164
    104
    Okinawa Japan
    2012 Aqua
    At 62,000 km, put on Ecopia EP20's. Same fuel mileage, but without the spine smashing ride the OEM Dunlop's had. Night and day.
    HaroldW likes this.
  4. F8L
    19,011
    4,081
    Grass Valley, CA.
  5. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    I now have the True Contacts on the Prius a month or so ...no complaints yet, except one day before our appointment install the tires from Tire Rack, my wife had a fender bender slipping on wet roads. I did not think the other tires were bad (I was just trying to beat winter) but sure would've been nicer to have the new tires on there sooner.
    I just put the Defenders on my minivan, since some a few owners mentioned a potential issue with True Contacts high speed on minivans. Decided to hedge my risks. Well, guess that gets me out of the tire threads for 3 or 4 years.
    F8L likes this.
  6. Ramtart
    Ramtart Senior Member
    432
    797
    San Jose, CA
    Hi everyone,
    I was able to put together a set of 225/45/r17 size Continental Contiprocontacts for a set of 17x7.5 wheels that I have. Found various sellers on local craigslist with takeoffs with literally 10/32 and 9/32 tread left and made a set.
    Anyone roll on these? Any feedback? Road noise, mpg, handling (wet and dry), etc.
    Thanks in advance!
    Ram
  7. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Should be ok. Let us know how you do after a couple tanks. Will not match the 195/65/r15 fe however. How are they in the noise department. Hal
  8. Ramtart
    432
    797
    San Jose, CA
    Hal, thanks for your input! Will definitely report back!
  9. wjtracy
    11,329
    3,593
    Northern VA (NoVA)
    Heard on radio today, some interest groups want to say tires are too old at 6 years old. Tire mfg cos. are saying it's not until 10-years that tires are too old. This is just re: age per se not talking about wear or other variables..
  10. bwilson4web
    15,586
    I saw a similar article on the CBS evening news but could not find a ready source . . .
    Tire aging reports | PriusChat
    Let me suggest we use a separate thread to discuss this apart from rolling resistance.
  11. ETP
    2,802
    1,170
    Auburdale FL
    Need one tire maybe but might buy 4! I hit a large metal object today with a razor blade on the end ( tread cut) and I probably need to replace one of my OEMs. 44K and a lot of tread left.
    Sam's has the Michelin fuel saver 44 PSI but that will not match the OEM Ecopia 20.
    I am debating on ordering 4 OEMs to split between both cars from Tirerack and use the spare for 10 days.
    BTW/what a job to change a tire. There is enough space, it looks like to me, for a full size spare in the well.
    Michelin Energy Saver A/S - P195/65R15 89T - Sam's Club=
    Also noticed another Michelin Energy Saver A/S at the SAMS site that was 51 PSI.
    #1091 ETP, Dec 31, 2014
  12. ETP
    2,802
    1,170
    Auburdale FL
    Noticed Wal-mart carries the EP 20s. Any one have experience getting these at Wal-Mart?
    HaroldW likes this.
  13. F8L
    19,011
    4,081
    Grass Valley, CA.
    Why are you hung up on psi?
  14. HaroldW
    716
    95
    ETP why not go with a Ecopia ep 20 from wal-mart. I find these to be the most comfortable LRR tire I have ever had and too butt they give the lowest FE of the 5 brands I have owned. H
  15. bwilson4web
    15,586
    The effects of tire pressure are reproducible:
    1. fill the tires to max sidewall
    2. warm-up car for 10-15 minutes around a benchmark path, 6+ miles
    3. reset trip meter and do benchmark path, record MPG
    4. draw out 5 psi and repeat #3-#4 until door jam pressure -5 psi are reached
    Now you have a table and can choose the pressure that matches your preferences:
    1. reinflate tires to desired MPG pressure +5 psi and set tire pressure sensor
    2. reinflate every two months
    There is an optimum ratio between tire psi and ride comfort. I find maximum sidewall provides the best handling and most precise steering but it feels every road defect.
    HaroldW likes this.
  16. ETP
    2,802
    1,170
    Auburdale FL
    Checking the dealer on Friday as Wal-Mart was a head fake. I can order online and Wal-mart will install them. Friday for update.
    42 PSI with OEM has been my sweet spot.
    My Wife want the 20's on her car.
  17. F8L
    19,011
    4,081
    Grass Valley, CA.
    I think you mistook my question. I meant why be hung up on a tire's max psi. Max psi doesn't mean much with regards to efficiency in our vehicles.
  18. ETP
    2,802
    1,170
    Auburdale FL
    maximum
    Well it does as it will limit how much air you can put into the tire. Bob's answer was spot on. Most of us have had hybrids that required 51 PSI tires and we ran 42-51 in those tires. A 44 PSI tire will be at my maximum personal comfort level at 42 PSI.
    I have compromised and run 42 PSI in all my hybrids and the higher the PSI the better the MPG.
    That is how I have most of my tread left at 44K. Low pressure will kill a tire on wear and lower your MPG. Of course you may be more susceptible to impacts with road hazards
    #1098 ETP, Jan 2, 2015
    HaroldW likes this.
  19. F8L
    19,011
    4,081
    Grass Valley, CA.
    I get that but the problem with focusing on a tire with the highest pressure rating is you will miss out on a tire that is actually more efficient but has a lower max pressure. If all tires were created equal then I wouldn't question your motive. But since they are not equal in terms of efficiency I do question it.
    #1099 F8L, Jan 2, 2015
    HaroldW likes this.
  20. bwilson4web
    15,586
    We'll have to agree to disagree:
    I would agree if we had rolling resistance metrics, real numbers, for these tires. All I need is a table for each tire showing coefficient of drag on a standard day at tire pressures from say 30 to maximum sidewall pressure. Then the problem is solved but that is not what we have today.
    Today "low rolling resistance" has the same credibility as 'looks fine, runs a long time.' There are no hard metrics so I am left having to treat it as 'eye wash.'
    Look at our own threads about tires. We are not seeing A-B-A tests but spot results.
    Maybe this is something we should 'crowd source.' Pool our money to buy or build a tire test fixture and then buy samples of the 'leading' low-rolling resistance tires and test them. If someone wants to try a different tire, work up some sort of 'test fee' or 'loan for testing.' Then we'll have some real numbers instead of the salesmansh*t we get today.
