Sudden engine oil loss
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Marathon Jon, Dec 18, 2014.
  1. Marathon Jon
    Marathon Jon New Member
    Harvard, MA
    Prius Gen III 96K miles indicated 'oil pressure low' 2K after last oil change. Fortunately we were only a mile from home and were able to drive it home on battery charge. We exclusively use synthetic Mobil 1 0W-20 oil. The oil pan bolt was dry, and it appears the leak is coming from somewhere above the oil filter canister, which I verified being seated and tight. After the engine cooled, I drained the remaining oil (about 3/4 quart) and removed the oil filter canister to check the O-ring seating and integrity of the filter. All appeared normal. After reinstalling drain plug and filter, I slowly put in 3 quarts oil to minimum oil level indication on dipstick. Started engine and ran it for 1 minute and checked for leaks -- no leaks. Turned off engine and allowed the car to sit overnight. The oil level remained unchanged the next morning. I started engine and let it run for two minutes this time, at which time it started leaking rapidly (fortunately I kept the oil catch pan underneath the car). So the oil leaks when the oil pressure rises with warming engine. Any ideas on what I should check to determine the cause?
  2. JC91006
    JC91006 Senior Member
    16,470
    8,383
    If you are positive that the oil filter is seated properly and tightened, you'll have to go to Toyota to get a proper diagnostic. It sounds a bit weird from your description of it leaking rapidly after running for 2 minutes during warm up. If this occurred everytime during startup for 2000 miles, you should have gotten a low oil warning a looooong time ago.
  3. Yakoma
    Yakoma Active Member
    470
    122
    ATL-ish
    Ouch...I speculate that you have a punctured or cross-threaded oil filter.
  4. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    As you stated the leak is somewhere above the oil filter canister, get yourself a good light, inspection mirror, box of towels and some alcohol. Clean and isolate.
  5. AzWxGuy
    AzWxGuy Weather Guy
    968
    490
    Tucson, AZ
    2021 Prius
    Is that for cleaning, or perhaps medicinal purposes?
    irrational likes this.
  6. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    Agreed. You stated that it started leaking after the engine warmed up, but did not mention specifically where the leak was coming from. Please give us an update...
  7. irrational
    irrational Member
    102
    Tulsa, OK
    The oil is going somewhere. If all else fails, add some fluorescent dye to help locate it.
  8. frodoz737
    4,297
    2,347
    33
  9. Mendel Leisk
    38,247
    Is it out of warranty?
  10. KeinoDoggy
    KeinoDoggy Member
    Could it be a leaking oil pressure sending unit?
  11. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    New filter and O-ring
  12. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    For what it's worth the oil pressure is probably highest when firs tstarted cold.
    As others have suggested, you need to see where the leak is.
