There is a problem with the transmission 'P' lock mechanism......
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ps23112, Oct 1, 2012.
  1. csphilipps
    csphilipps New Member
    Help! I'm getting the "problem with transmission P lock mechanism" issue in a 2008, and the car won't shift into D. Following the advice on this thread, I put in a new Optima battery but the issue hasn't been resolved. The car still won't drive. Any ideas?
  2. Patrick Wong
    18,199
    6,464
    1. Measure the voltage on the new 12V battery. It is possible that the new battery is partially discharged.
    2. Once you are sure that the battery is fully-charged and that the battery cables are tight (also check the negative cable where it bolts to the body) then if you still have a problem you'll need to have your car towed to your local Toyota dealer for assistance.
  3. Yakoma
    Yakoma Active Member
    470
    122
    ATL-ish
    Got something similar the other day when I needed to nudge my car forward a bit and had the door open when I put it in D. Message came up with a ! on the MFD. Spooked me but still went into Drive though.
    If it was this
    Close your door and try again?
    #23 Yakoma, Dec 20, 2014
  4. csphilipps
    Tragically, the battery was fully charged and didn't seem to have any loose connections. My local dealer can't find the problem using computerized methods, so they're taking the car apart. Cross your fingers.
  5. GregP507
    GregP507 Senior Member
    3,002
    480
    I'm impressed. That's a detailed piece of diagnostic information to come from the computer.
  6. csphilipps
    Apparently they put in a new ECU and that didn't fix it. I say it must be gremlins.
  7. kodiac_kidd
    kodiac_kidd Junior Member
    apopka
    same thing happened to me inst. panel went off intermittently then on i played with the wheel that turns the brightness from low to high on the speedometer and after turning it bright on and off 2 times i havent had problem since
  8. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    I get error message I the title when the car is in ACC and I turn headlights on, everything seems fine and it goes away when I turn the headlights off...
    when the car is in ready mod no warning with headlight on..
    any ideas?
  9. dolj
    dolj Senior Member
    7,502
    3,770
    Wellington, New Zealand
    12 V Battery in poor state of health.
  10. Beachbummm
    1,160
    392
    thanks will pull i t and get it tested
  11. Beachbummm
    1,160
    392
    had it tested and it was bad,replaced and the error message is gone,thanks
  12. dolj
    dolj Senior Member
    7,502
    3,770
    You're welcome.
    All the best.
  13. MikeSTL
    MikeSTL New Member
    St. Louis, MO
    While this worked, for my Prius 2009, I had to hold the DISPLAY button down, not the INFO button.
  14. Zahid Bhatti
    Zahid Bhatti New Member
    Pakistan
    I have Prius 2010. Now facing the same P Lock error for the past few weeks. After reading all the above threads, i have also replaced my battery but that evil P error is still there. Even replaced battery is perfectly fine. I have also get it checked quite a few times but that P error is now getting on my nerves.
    I have also tried to remove the 7.5 fuse from the switch box but P error is still there.
    Whenever P error appear, i simply apply the parking brake and turn the vehicle off. After 5 minutes wait, i turn on the vehicle and every back to normal like nothing would had happened.
    Please help me out. May i need to replace that 7.5 fuse or connect some cable between the 7.5 fuse to blue wire. Or what.
    If anyone know the permanent solution of this problem, please do let me know.
    Let me reiterate that 12V battery is perfectly fine.
    Please HELP.
    SOS
  15. dolj
    dolj Senior Member
    7,502
    3,770
    Your car is a Gen 3 Prius, so you might get more replies and better information if you ask your question in one of the Gen 3 forums, rather than here in a Gen 2 forum.
  16. Zahid Bhatti
    Pakistan
    Thanks for your reply. I have posted the same comment in Gen 3 Forum as you advised. Now lets see.
    Anyway, thanks for your help.
  17. qmanqman
    qmanqman Active Member
    297
    110
    CO
    This happened to me at 11:30 pm last night on the interstate. All dash lights light up and I get the "There is a problem with your transmission Plock mechanism . . . "
    - That red triangle of death scared the sht out of me
    - Pulled off onto the scenic overlook (packed with cars)
    - Found this thread
    - Went through that "MFD in Maintenance Mode" procedure
    - Got to the menu that showed my 12V battery at 9.4V
    - Started reading the next step and the Maintenance Mode went away
    - Tried to get into Maintenance Mode 3 more times
    - Two cars drove off thinking I was a drug dealer or a cop flashing my headlights to someone out there
    - Couldn't get to Maint Mode so I said "fork it"
    - Started up the car and finished the drive home with no issues whatsoever
    - Plugged in the OBDII scanner and nothing
    Are y'all telling me this is an indication that my battery is dying? That's a lot of "scared the sht" out of me for low battery voltage.
  18. Jan_Marcel
    Jan_Marcel Junior Member
    Brazil
    How you repair your car? Please help
    Me
