LT fender liner retainers/clips
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by skiddl3s, Dec 20, 2014.
  1. skiddl3s
    skiddl3s New Member
    I'm looking to replace my front driver fender liner.
    Are there universal retainers or clips I may use for this DIY project?
    Another post noted that 11 of the 90467-07164 is required for each fender liner in front.
    Fender Splash Shield Push-Type Retainer
    Black Nylon
    Head Diameter: 20mm
    Stem Length: 10mm
    Fits Into 7mm Hole
    Will this fastener work similarly for a 2011 Toyota Prius front fender liner LT?
    The attached diagram indicates there are 10 different fasteners/screws/clips/what-have-you's to replace the fender liner. It's a tad bit pricey to get each one... as you can imagine.
    Any advice would be appreciated. Thanks!
  2. Yakoma
    Yakoma Active Member
    470
    122
    ATL-ish
    I feel your pain. I ended up getting an assortment of sizes as I have missing fasteners all over my used 2008. Ebay sells a boxed assortment for about $24. Had to get some of the clips/screws from the Dealer as I couldn't locate them online. Good luck.
  3. skiddl3s
    skiddl3s New Member
    I called the dealership and he quoted me $27 total per the diagram above.
    Body shop lists two that's only required: 9015960488 and 9046710183. However, the first one is a metal screw, which doesn't make sense. There must be a similar plastic fastener that fits the bill.
    90159-60488 (21838):
    M6.3-2.5 x 24 mm
    16mm washer
    10 mm hex
    90467-10183 (20869):
    Front Fender Liner Push-Type Retainer
    Head diameter:18mm
    Stem Length: 7.5mm
    Fits into 7mm hole
    What would 21838 look like as a push-type retainer?
  4. Yakoma
    470
    122
    ATL-ish
    Yes, the first one is a screw going into plastic/nylon clip. The clip goes into the fender hole - and the screw attaches the fender liner to the clip/fender. If you're saying $27 is for all the pieces in Diagram 53875A or B, that's not a bad price for all that stuff if you ask me. You could go to a hardware store and they could maybe assemble a bunch of pieces that cost only $10, but they won't necessarily look very right nor will they necessarily stay in place over the long haul. Know anybody at a non-dealer body shop? They may be able to help you for less than Toyota.
  5. Mendel Leisk
    38,247
    There are some metal screw fasteners, as you can readily see by having a look around the car. They're not that impervious to rust either. ;(
