iPhone 6+, Bluetooth & Siri Troubles
Discussion in 'Gen 2 Prius Audio and Electronics' started by boulder_bum, Oct 23, 2014.
  1. boulder_bum
    boulder_bum Senior Member
    1,371
    Castle Rock, CO
    I have an iPhone 6+ and a 2007 Prius, and have never had problems connecting via Bluetooth. However, voice dialing via Siri and the iPhone 6+ has been broken since day one, which is a problem I never had with my iPhone 5.
    Can anyone confirm if they also have the issue? Basically, if you try to voice dial by saying something like "Call my wife", Siri will start the process (a call attempt will show up in my call history), but it will fart when actually trying to make the call, as in it never even starts to ring the person on the other end.
    If I disconnect from Bluetooth and try the same thing just with the handset, all works fine.
  2. walpoleauto
    walpoleauto Junior Member
    48
    Walpole, Massachusetts
    I have had similar issues with my Prius. Try updating to the latest iOS as they have had multiple bluetooth issues with the release of iOS 8. Restart your phone, delete and re pair them.
  3. boulder_bum
    1,371
    Castle Rock, CO
    Thanks. I actually hoped 8.1 would fix it since the release notes said it resolved some "Bluetooth issues", but it was actually loaded before I posted this thread (but didn't resolve the issue, obviously).
    I may try re-pairing, but the connection doesn't seem to be the issue per se: I can still make Bluetooth calls, it's just that voice dialing is borked.
  4. lulu prius
    lulu prius Junior Member
    Orange County, CA
    2014 Prius Plug-in
    My wife's 2014 PiP Advanced is having the same issue with her 6 plus. It works to make or receive calls via BT. But Siri is not working
    Have not upgraded to 8.1
  5. boulder_bum
    1,371
    Castle Rock, CO
    Thanks, Lulu! It's good to know I'm not alone.
    Since others seem to experience the same issue, I will probably mention that to support if I contact them again.
  6. lulu prius
    Orange County, CA
    2014 Prius Plug-in
    Thanks let me know if you get it to work and what you did to fix it.
  7. Enio Cordoba
    Enio Cordoba New Member
    South Pasadena, Ca
    My 5S started doing this about a month after I bought the 08 Prius in September
    My 5
