What is this part and purpose?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LurkAzusa, Dec 20, 2014.
  1. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    Can you please tell what the part circled in red is and what is its purpose?
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Stiffens the body.
  3. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    It's a brace (that stiffens the body).
  4. uart
    uart Senior Member
    4,215
    1,200
    Australia
    From the photo I can't tell for sure whether or not that bar is connected to the suspension. If it's connected to the suspension on each side then it's an anti sway bar, otherwise it's just a strut brace (body stiffener).
    #4 uart, Dec 20, 2014
  5. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    Thank you all.
  6. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    I notice that the car in the picture has the old hourglass mid-body brace (the short brace in the center of the chassis). If this picture is of your own Prius, I strongly recommend that you buy either the new tube-like Toyota brace or Rude person's's E-bay aftermarket brace. You'll be very pleasantly surprised either way - and it's a 5-minute DIY job.
  7. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    I have a 2012 Prius Plugin. This was the only picture I could find of a Prius undercarriage. It was pushed up a bit to meeting the pan above it. Hope it isn't anything critical. It seems to drive fine
  8. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    :eek: How'd that happen?
