DC outlet not working
Discussion in 'Prius c Main Forum' started by iS~, Jan 28, 2015.
  1. iS~
    iS~ Junior Member
    Millbrae, CA
    Does anyone know where the fuse is for the DC outlet for the C? I am not getting power to it so I can charge my phone.
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    Im not sure exactly where it is, but it will be under the drivers side fuse block. But are you sure it is the fuse and not the charger? its kinda hard and strange that the cell phone charger would blow the fuse.
  3. iS~
    iS~ Junior Member
    Millbrae, CA
    yea thanks, I found the blown fuse. i didn't know of that driver side fuse box until i did some more research because I couldn't find any blown fuses in the engine compartment and those were the only 2 fuse boxes that i knew of.
    the fuse on my tacoma was also blown so i wonder if its the cig plug adapter (the usb kind) that blew both fuses for both cars. thanks
