2005 Prius- Battery went dead- Error reading "transmission lock mechanism abnormal"
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by C Jakel, Jan 30, 2015.
  1. C Jakel
    C Jakel Junior Member
    Lockhart, TX
    Battery went dead after alarm went off in parking lot. Got the error reading "transmission lock mechanism is abnormal. park your car flat place and set parking brake."
    I have seen that i need to replace the battery. I will replace ASAP. But 2 questions:
    1. Once I replace, will the error code automatically go off or reset or will i need to do something to clear the message.
    2. Best place to get 12v battery at dealer or are there any other good options?
    Thanks
    Longinus876 likes this.
    48,988
    yes, it should go away. i prefer the oem, but some like the optima from elearnaid.com or exude from auto zone, or duracell from the battery store. whichever you buy, make sure it's 13 volts before installing, or trickle charge it. the car does a poor job of increasing the voltage. all the best!(y)
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    1. Once you recharge the battery the error should go away. If not the first time you may have to stop and restart to clear.
    2. The dealer is the best place to get an OEM replacement. These are AGM type batteries with vent tubes since the batteries are in the cabin with you. I just replaced mine and the cost was $220 for a 7 year warranty battery.
  4. C Jakel
    Lockhart, TX
    update....after jumping battery and driving for awhile, the error code went away....should i run the diag to check the battery and just keep running it? Or should I still replace the battery?? Thanks for the quick response yall!
  5. jdcollins5
    5,131
    1,338
    Wilmington, NC
    If the battery is over 5 years old I would recommend replacing it based on feedback from this site. If less then run the battery testing. If you have questions post the results of the battery testing on here and you can get feedback.
  6. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    After you jump started it you need to keep it in Ready (or just drive it) for 2…8 hours to charge the 12V battery. Or you can use external charger.
  7. C Jakel
    Lockhart, TX
    If i run for 2 hours will I still need to use trickle charger for 8 hours? or will this fully charge it?
  8. usnavystgc
    3,159
    988
    Tucson, AZ
    It will probably charge it good enough but it would be best to trickle charge it to full capacity overnight.
  9. bisco
    48,988
    did you run it down by leaving a light on or anything? if not, you should replace it. oh wait, did the alarm run it down? how long was it on for?
  10. C Jakel
    Lockhart, TX
    it was in a plot and alarm went off, but no one knew whose car it was so they didnt notify us...no idea how long it was on....when wife finally noticed the lights were blinking a little then went dead
  11. bisco
    48,988
    you may be okay then, but i would keep an eye on it. winding these little batteries down is often a death knell. any idea how old it is?
  12. exstudent
    exstudent Senior Member
    2,212
    900
    Torrance, CA
    If you don't have a battery charger, why not just get a new "smart" battery charger that is capable of charging Wet/Maintenance Free, AGM, and Gel batteries?
    Many to choose from on Amazon.
    Amazon.com: agm battery charger: Automotive
    I have the Schumacher SSC-1500A/CA charger. Good value at $43, as it can charge the Prius battery and traditional batteries. Just make the settings, then walk away.
  13. valde3
    2,002
    745
    Finland
    It depends. If your 12V battery can take charge good then 2 hours may get it full. If it can’t then it may take 8 hours or it may never get full.
  14. C Jakel
    Lockhart, TX
    Here is a pic of signal check in diagnostic mode....12.4 on battery...I did it again later after running headlight s for a little bit and showed 12.3...should I still trickle charge our just let it be
  15. bisco
    48,988
    you're probably okay, how old is it?
  16. valde3
    2,002
    745
    Finland
    It’s charged enough. You can test your 12V battery condition more by pressing power again to get to ign-on and putting headlights and rear defroster on and checking the voltage then. If it’s more than 11v its good and if it’s less than 10,3v you definitely need new one.
  17. dolj
    dolj Senior Member
    7,509
    3,772
    Wellington, New Zealand
    If the battery is 11V or less with this load, it may be good, but it is at the discharged end of the spectrum so will benefit from a proper full charge.
  18. Longinus876
    Longinus876 Junior Member
    81
    Long Island
    Did you just say that battery charger will charge the hybrid battery?
  19. dolj
    dolj Senior Member
    7,509
    3,772
    No, he didn't. He's talking about AGM and flooded Pb/Acid 12 V batteries. The Schumacher will charge both types.
