Repair shop instead of dealership?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Debbitydo, Jan 31, 2015.
  1. Debbitydo
    Debbitydo Junior Member
    Sacramento, Ca
    My Prius C is due for the 30,000 mile maintenance. The dealership is wanting to charge me a lot. Any suggestions on how to find alternate repair shops that know hybrids? I'm in Sacramento.
  2. mikefocke
    3,729
    1,665
    Sanford, NC
    I googled "hybrid repair sacramento ca" and got several positive reviews of Maxit
    Debbitydo likes this.
  3. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    If you read up on the items in your 30,000 maintenance they aren't hybrid-specific so you mainly need to find a good shop, whether hybrid specialists or not.
  4. Mendel Leisk
    38,960
    And what's "a lot"?
  5. bisco
    49,799
    all you need is oil, filters, tyre rotate and inspection. you may want to consider tranny oil change, any AAA shoppe can do it.
  6. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    775
    360
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Even if you don't technically "need" a hybrid specific shop, as an owner of a hybrid I'd recommend finding one.
    Whether dealer or an independent hybrid repair facility I think it is an advantage to have a relationship with a shop that can handle your entire vehicles needs.
    Then if and when a hybrid issue develops, the confidence and relationship is already in place.
  8. Debbitydo
    Sacramento, Ca
    It was around $350.
  9. bisco
    49,799
    yup, way too much.you can also ask the dealer how much for just the toyota recommended maintenance.dealer should be around $160. private wrencher $120. with oem parts.
  10. Mendel Leisk
    38,960
    It's mainly the circled. Everything will likely get a cursory glance, at best.
  11. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    The engine and cabin air filters you can change yourself.
  12. Avi's Advanced Automotive
    775
    360
    Adding in transmission fluid replacement wouldn't be a bad idea. I doubt the dealer was including it.
    Avi
  13. Debbitydo
    Sacramento, Ca
    Thanks for the advice everyone! Appreciate it :)
  14. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    Get an oil change and tire rotation at any place that does them, but be sure they use 0w20 - should be under $50 for full synthetic. If they don't have 0w20 or want to charge you a bunch for it, get a 5 quart jug of it from Walmart for ~$25 and ask how much they'll charge you for just the labor. The filters you can buy yourself at the dealership/Amazon, and replacing them yourself takes well under 5 minutes for both.
