Low Rolling Resistance replacement tires: Current List
Discussion in 'Gen 2 Prius Fuel Economy' started by F8L, Apr 17, 2011.
  1. Mendel Leisk
    38,106
    Maybe other tires get noiser too? I know we had some aging Ecopia EP20 (on our previous Civic). I'd just swapped back to them (from our snows) and REALLY though something was wrong at first, the noise was so loud. You get accustomed to it though.
  2. Iamjo20
    Iamjo20 Member
    259
    And they woud get noise with age because?
  3. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    I wish I knew the answer to this. H
  4. Graz
    Graz Member
    178
    28
    I replaced my tires with P185/65R-15 Bridgestone Ecopia EP422 SL in June. I found they were very quiet, and nearly instantly gave me the mileage I was getting on my old tires... Thanks for all the information. This thread helps anyone make better decisions.
  5. Iamjo20
    Iamjo20 Member
    259
    OH OH---I got my Michelin Energy Saver A/S yesterday--the mileage has already improved!!!! So far, at least in one day, I am thrilled!!!!!
  6. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    what did you have to pay? Or did that swap them out for you? Anyway, I'm happy for you! It's strange to think tires can make such a difference in miles per gallon isn't it?!
  7. Britprius
    Britprius Senior Member
    5,194
    1,910
    Herefordshire England
    The mpg will get better as the tyres bed in. Run them at 40/38 psi or a couple of psi higher if you do not mind the firmer ride to get the best mpg.
    John (Britprius)
    Data Daedalus likes this.
  8. HaroldW
    716
    95
    Energy Savers are rated by most, the best! Everybody that purchases them love them. Good luck, Hal
  9. Iamjo20
    Iamjo20 Member
    259
    thanks--My Prius has HAPPY shoes! :) , and a thrilled driver again!
    Still waiting for news about the 2016--seems like it is taking FOREVER!
    thanks all!
    jo
  10. HaroldW
    716
    95
    You will like the gen 3. Or 4 whatever it will be. Very fuel efficient! I like my prius's especially the 2014. Got my first 625 mile tank and it only took 9.5 gal. too fill it. 60% in town and 40% highway. actually it was my last fill up.Hal
    Data Daedalus and PriusGuy32 like this.
  11. Iamjo20
    Iamjo20 Member
    259
    sounds awesome --I truly hope the car is ore quiet on the inside--looking forward to a new one--- and mine only has 22600 miles! May try to sell it myself! :)
    PriusGuy32 likes this.
  12. HaroldW
    716
    95
    I would keep it. It is new yet. I have almost 50,000 miles on my 2006. I like it as well. Not as FE as the gen3 though. It's my wife's car now. Hal
  13. Iamjo20
    Iamjo20 Member
    259
    It truly depends on what the new one offers----since I purchased it is 2007, I have the "ITCH"--lol
  14. HaroldW
    716
    95
    New is fun! H
  15. Iamjo20
    Iamjo20 Member
    259
    yes it is!!!!! I love NEW tech on cars! Hopefully, there will be some awesome new body styling! And, a QUIETER ride! :)
  16. Mendel Leisk
    38,106
    Here's a short Consumer Reports test report on the Michelin Premier A/S, comparing to the Primacy. Just an interesting read. It makes a bit of mention of rolling resistance, maybe token? I'm kinda resigned, it'll likely be these or similar. If I EVER need new tires. What with our usage dropping, and using snow tires for over 4 months yearly, both our snows and (OEM) Michelin Pilots are at 8/32" still, lol.
    Tests Reveal the Michelin Premier A/S Tire Doesn’t Give Up Grip as it Wears - Consumer Reports News
    BTW, I'd love to get those Energy Saver's but Michelin in their wisdom doesn't make them in 215/45R17. :(
  17. Iamjo20
    Iamjo20 Member
    259
    thanks for this!
  18. Mochabuzz
    Mochabuzz Junior Member
    46
    SoCal
    I got Bridgestone Ecopia 422's A few weeks ago... I'm running them at 41psi. My mileage has gone from 44 to 51mpg. I suspect it will improve once they wear in a little bit. Pretty incredible tires.
    HaroldW likes this.
  19. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    The newer Premier seems to be the best, Tirerack's test showed a strong performance as well. Nice to see the CU test confirming the wet traction as well. Our aging 2007 Camry hybrid needs some new shoes now. The Yokaham Envigors have about 45,000 miles, and two are no good. The mileage from these tires has been stellar, delivering a consistent 2-3 mpg more than the previous Bridgestone LRR tires. After checking the prices online, we'll be putting four more new Envigors on this 116,000 mile car now, saving about $100 plus a set. I will definitely put these new Michelin Premiers at the top of my list when my Prius needs new tires.
  20. Steve terry
    Steve terry Member
    217
    Oklahoma
    What did you have on the car before ?
