Reducing Cabin Noise
Discussion in 'Gen 2 Prius Accessories & Modifications' started by DenToyPri05, Feb 21, 2015.
  1. DenToyPri05
    DenToyPri05 Junior Member
    118
    24
    Denver, Co
    I know this has been a topic discussed ad nauseum, but I need guidance. Most of the projects seems to focus on accommodating an upgraded sound system.
    I'm not upgrading to a megawatt sound system; I just need to reduce the road noise coming in. What parts of the car should I Peel n' Stick/Dynamat?
    I've read about tires and will get the Michelin Defenders. I read about jute, but not interested in mold potential, even though I live in a dry climate, or negatively affecting finished carpet fit. And I read about adding an additional line of weather stripping around the doors, but the sound is coming from other areas.
    I'm okay with losing a couple mpgs for a quieter ride, especially on long distance road trips.
    Am I on the right track to focus on tires? And then dynamatting trunk area and doors?
  2. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    I think your on the right track for noise reduction particularly with the doors. An area I found that that was responsible for noise was the flat area between the 12 volt battery and the spare wheel well. This area if tapped with your fingers resonates like a drum. With it's close proximity to the rear wheel, and being immediately above the rear silencer (muffler) it made a noticeable difference adding Dynamat.
    Finding tyres that are quiet does not mean loosing mpg's. In fact the opposite as producing noise wastes energy.
    We are perhaps lucky in the UK/EU that tyres at the point of sale not only have to show there energy efficiency, and wet grip, but also there noise level in DB.
    John (Britprius)
  3. DenToyPri05
    118
    24
    Denver, Co
  4. Data Daedalus
    Data Daedalus Senior Member
    1,022
    1,182
    Wembley, London
    That's very useful information John, thank you! May I ask, is it difficult applying dynamat to the areas concerned? And approximately how much would it cost to do this? I am very impressed at how quiet the Prius II is at cruising speed, but I wouldn't mind reducing cabin noise during phases like climbing a long hill at 50 mph. The Prius does do a good impression of a "quiet" twin turbofan engined aircraft taking off at reduced power when flying up a hill ;)
    #4 Data Daedalus, Feb 22, 2015
  5. Britprius
    5,194
    1,912
    Dynamat and it's equivalents is not cheap, but it does work. It changes doors when you close them from a metallic clang to a refined clunk when applied to the inner surface of the outer skin "if that makes sense". To apply means taking off the door panels and working through the holes in the inner door skins. To get an idea of how it works tap the outside skin of a door near the centre with your fingers, then do it again with your other hand placed flat on the same panel.
    Engine noise is more difficult to stop because of the requirement to soundproof the front bulkhead (fire wall) this mostly being behind the dashboard.
    To soundproof the doors and other areas that are reasonable to get at "rear quarter panels, boot floor, area under the rear seat" around £100 just for materials.
    John (Britprius)
    Data Daedalus likes this.
  6. DenToyPri05
    118
    24
    Denver, Co
    I'll start with the spare tire area and do one door next weekend, and then plan to do one door per weekend until my road trip. Each week I hope to hear a difference.
    In my gargantuan truck, I can easily hear my kiddo from the 3rd row during our weekend jaunts to the mountains, easily 130-mile round trip on the highway.
    Britprius likes this.
  7. DenToyPri05
    118
    24
    Denver, Co
    Spare tire area and three doors (inner AND outer panels) are done! What a difference. Right now, with one door left, I can already hear that the noise has altered a bit...it's less noticeable. I will do last door next week and get better tires the week after.
    #7 DenToyPri05, Mar 1, 2015
  8. Britprius
    5,194
    1,912
    Thanks for the update on the soundproofing. Be careful on the tyres you choose, and you will not only loose noise, but gain MPG.
    John (Britprius)
  9. DenToyPri05
    118
    24
    Denver, Co
    Thanks John. I thought of getting Michelin Defenders, but they seem a bit pricey right now. Although...they do have an attractive warranty (90k) and have consistent high ratings and feedback. Any thoughts on other brands I should check out? Where I live, the temp swings from winter through summer can range from singles F digits to mid-90's F, with summer afternoon rain.
    I'll have to get tires sooner than later. I just measured and realized I measured incorrectly the first time. I thought I had about 1/8 left, but I have 1/16 left.
  10. DenToyPri05
    118
    24
    Denver, Co
    Michelin Defenders installed yesterday. What a difference healthy tires make! The tires that came with the car were down to wear bars. I still have one door left to Dynamat. I'm not an audio technician, but it seems that multiple frequency levels are being altered and this results in what I am experiencing as sound deadening.
    I applied material to both inner and outer door layers. There's a YouTube video of someone doing just this same process, but he broke off the styrofoam attached to the exterior door panel. Don't do that. It's simple to unbolt styrofoam, apply material, and then reattach styrofoam. My philosophy is that if the piece is there, it's there for a reason.
    So, now, the majority of noise is coming from engine bay and under seats. I might attempt to squeeze in more research on the seat area AND install a sound barrier under seats before my road trip. This is my first choice only because anything having to do with the engine bay seems more complicated and intensely process-oriented (read: accessing nooks and crannies to clean and cut Dynamat to form) compared to unbolting seats and peeling back carpet layer. Regardless, though, I'm very pleased with the results so far.
    If anyone has already done the sound project under the seats, I wouldn't mind skipping the research and just jumping right in, following your process :D!
  11. Britprius
    5,194
    1,912
    This has been done and a full report with pictures posted. I will see if I can find a link, but it's possible it got lost with the server update.
    John (Britprius)
  12. DenToyPri05
    118
    24
    Denver, Co
    John, thank you! I thought I came across it beofore the server update and was trying to find it again.
  13. Britprius
    5,194
    1,912
  14. DenToyPri05
    118
    24
    Denver, Co
    Holy crumbs! I remember this post, and now have a better understanding and appreciation of the process and result. Thank you!
  15. DenToyPri05
    118
    24
    Denver, Co
    I haven't seen any post so far that recommends replacing weather/vapor barrier. Should this be a necessary step?
  16. Britprius
    5,194
    1,912
    I would think if your soundproofing inner and outer door panels the answer is no. If you are just doing the outer panels thenit should be re applied or replaced.
    John (Britprius)
  17. DenToyPri05
    118
    24
    Denver, Co
    I did both inner and outer panels, so I'm going to forego the replacement of the vapor barrier.
  18. Britprius
    5,194
    1,912
    Perhaps I should have qualified my answer with as long as the sound proofing seals all the hole the vapor barrier did.
    John (Britprius)
  19. DenToyPri05
    118
    24
    Denver, Co
    Ah...I'll be adding barrier then. Glad I asked.
  20. DenToyPri05
    118
    24
    Denver, Co
    Sound deadening/dampening project completed a week ahead of schedule! Topped off project with new Michelin Defenders, too! My kiddo told me that there was no need to yell anymore.
    There are already so many better documented posts out there that there's no reason to clog up this thread, but I will say that there were some things I stayed focussed on in the process that made a difference in my time and final outcome.
    1. Plan to take your time, and then add another hour for each door.
    2. Always lay your tools down in the same spot over and over again.
    3. Use a small container to hold screws, bolts, fasteners that are removed from the door.
    4. Work in a cool place (this especially helps when removing the black silicone adhesive beading on the vapor barrier from the metal).
    5. Pinch and pull the black silicone beading to remove. Try to stay close to the door surface after each short pull.
    6. Save the vapor barrier to either reuse or use as a template, depending on its condition, after removal.
    7. Measure out the same amount of Dynamat (or whatever you are using) for the rear doors as well as the front doors for equal weight distribution.
    8. Measure twice, cut once.
    8a. Use titanium blades on your box cutter.
    9. Keep a lot of lint-fee cloths available for surface clean up before sticking material on. Do not reuse cloth. When soiled, toss aside and grab a clean cloth.
    10. When applying deadening material, start at the bottom and work horizontal layers up...like house siding.
    11. Make a template for Dynamat (or whatever you are using) for areas with odd angles, bolts, wires, etc.
    12. If the roller is hard to get into smaller grooves, grab a pair of leather work gloves and use your fingers to get into hard-to-reach grooves to press material down.
    12a. Start on one end and push material into grooves as you go toward other end.
    13. Since the interior door panel is off, cover the inner skin of the outer door. Just do it.
    14. Do not break the styrofoam piece off of the interior...just unbolt it, apply material behind it, then reattach styrofoam.
    15. Do not cover holes in door; you may need access to window hardware later.
    16. Reinstall, or create new, vapor barrier; attach with black silicone adhesive.
    16a. Do not use the tube; use a caulking gun...much more uniform bead. The tube was hard to manage, trying to maintain consistent pressure and uniform bead.
    My car's front doors have JBL speakers near the side view mirrors, and when I removed them before sliding interior door panel up and off, the clips that keep the speakers snugly in place came off. They are small metal clips that slide over a black plastic piece on the speaker. I was able to reattach speakers without the metal clips, but there is a very slight play without the clips. Just a heads up on that one.
    Very pleased with the results.
    #20 DenToyPri05, Mar 8, 2015
    Jope and Britprius like this.
