Click, click, click, speed related noise
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, Mar 30, 2015.
  1. bwilson4web
    15,400
    So I first heard it last week but it got worse this morning. Half-shafts? Wheel bearings? 165,000 miles on original brake pads?
    I turned around and dropped the 03 Prius at the Firestone dealer and asked for a diagnosis:
    • two lug nuts missing
    • one lug nut finger loose
    Uph! Well we now know the nut responsible!
    Robert Holt likes this.
  2. Mendel Leisk
    38,247
    Was that down to you Bob? I can see a fingertight nut, but missing?
  3. bwilson4web
    15,400
    Yea, it was me. I'd put the tires on the car a couple of months ago but apparently didn't do my "ugh" tug to perfect torque.
  4. Mendel Leisk
    38,247
    I sent my son off once, with the front lug nuts just semi-tight, as much as you can do while the wheels are off the ground. It dawned on me 2-3 hours later, called him and he informally torqued them with the emergency wrench.
  5. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The only time I almost lost a wheel (it had to be replaced) was on my wife's 1966 mustang after a tire dealer installed new tires. I learned from that lesson to always torque the lugs.
    JeffD
  6. Air_Boss
    Air_Boss Senior Member
    3,913
    1,068
    New Yawk
    I once watched rear lug nuts pass me under braking. Hello....
  7. Patrick Wong
    18,199
    6,464
    Bob - where was your 1/2" torque wrench set to 76 ft.-lb, when this was going on?? :eek:
  8. bwilson4web
    15,400
    If I remember correctly, I was 'racing' a rain storm at the time. Regardless, I probably need to 're-torque' the nuts as the Firestone staff probably left their air wrench on F-350, dually wheel setting. Don't need to have lug-nut shaped cracks in the wheel hub.
  9. ChapmanF
    15,104
    [QUOTE="bwilson4web, post: 2160969, member: 10647"I probably need to 're-torque' the nuts[/QUOTE]
    Come to think of it, I'm pretty sure my owner's manual says with the aluminium wheels I should always retorque 1000 miles after having them off. I think I've hardly ever done that. Kind of makes me want to go take my torque wrench out there right now.
    -Chap
