Bazooka FAST-8113 Jbl Premium Adapter
Discussion in 'Gen 3 Prius Audio and Electronics' started by Stefan Dohn, Mar 31, 2015.
  1. Stefan Dohn
    Stefan Dohn New Member
    Germany
    Hello, I'm planning to do an Bazooka Subwoofer Install on my Prius Gen III Modell 2012 with JBL GreenEdge sound system
    I've seen that there is a JBL Amplifier Adapter Available called the Bazooka FAST-8113 Fast-Toyota/ Jbl Premium Adapter. Has anyone here used this Adapter in a Gen III Prius.
    Or else asking must I use another Adapter from a second Company to make it work in the Gen III Prius.
    The install with this Adapter and a Bazooka BTA6100 BT Series 6-Inch 100-Watt Amplified Tube Subwoofer plus the Bazooka FAST-BTAH Fast Extension Cable seemes to be straight forward.
    Any thoughts about it?
    With kind regards from sdohn
  2. memphisprius
    memphisprius Junior Member
    memphis
    Did you figure this out?
  3. Stefan Dohn
    Germany
    no this adapter won't fit for a 3rd gen prius 2010 with a JBL Green Edge Sound System.
    The reason is that they have changed the plug which goes into the jbl amp.
    cheers!
