What have you done to your c today?
Discussion in 'Prius c Accessories and Modifications' started by kingnba6, Nov 21, 2013.
  1. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    In the gen3 hatchback, mesh is installed behind the grills to protect the radiators, especially the inverter coolant radiator. If that is damaged, very expensive damage can occur, as in inverter failure.
  2. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    Here's the result of todays window tinting. It looks a bit darker than what it really is.
    LnG, NDcowPoke, robbm3 and 1 other person like this.
  3. Danger Dang
    Danger Dang New Member
    Houston
    2014 Prius c
    Looks nice! is that a stock 2015 bumper and wheels? if so i regret my 2014 :( lol
  4. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    It is.
  5. tk1971
    tk1971 Active Member
    253
    133
    SG Valley, CA
    Those ARE nice wheels.
  6. mertechperformance
    532
    126
    Nor-caL
    Some markets have had them before the refresh. Waste of money imo. But yes they look nice. Just no reason in spending on narrow 16's
    #466 mertechperformance, Apr 17, 2015
  7. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    Yes, they are factory installed, but they are the optional 16" alloy wheels.
  8. mertechperformance
    532
    126
    Nor-caL
    Excuse the typo. Fixing now.
  9. wkme
    wkme New Member
    socal
    those look awesome, where can i find them?
  10. gmacfan01
    gmacfan01 Junior Member
    56
    what was the aprox cost to do this job i am intersted in doing something like this to mine
  11. gmacfan01
    56
    Those re awesome wheels
  12. yOsHi LiN
    yOsHi LiN Active Member
    215
    137
    los angeles
    2014 Prius c
    at a local car shop !!!
  13. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    I saw where someone else had modified the support structure by the spare tire, in order to have at least some storage area.
    Here's my version:
    Now to find some plastic containers that will slip into the open areas.
    PLSPUSH, robbm3 and tk1971 like this.
  14. tk1971
    253
    133
    SG Valley, CA
    Is that welded EMT?
  15. mertechperformance
    532
    126
    Nor-caL
    If only there was room for a non super custom dual 10" sub enclosure under there.How much depth is there on the sides of the spare from the floor and the deck?
    #475 mertechperformance, Apr 18, 2015
  16. gmacfan01
    56
    Def like this better than the stupid foam.
  17. orenji
    orenji Senior Member
    5,884
    3,486
    I would be worried in a rear end accident, with the metal and wood now in place. I am sure Toyota designed it with the foam in place and tire as part of a safety device.
  18. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    Yes it is. Lightweight and easy to bend with a hand bender.
    There's 5" beneath the conduit to the floor. I have the shelf raised 1/2" to allow the conduit to have enough clearance to go over the high point of the spare tire.
    I understand your point, but I'm apparently not anywhere nearly as paranoid as you seem to be. No offence meant, we just view things differently. I see the wood and conduit as a non-issue.
    When Toyota chose to use foam, I'm sure that cost of material (and weight) played a very important role in their decision.
    PLSPUSH and mertechperformance like this.
  19. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    maybe instead of running the metal pipes
    great mod, but why lay the bars from front to back? should lay them sideways (just in case something rear ends you and send those rods going through someone's back)
  20. SamanthaC0716
    SamanthaC0716 Active Member
    333
    115
    Injen intake is installed.
    iPhone ?
    JD_Ghost, robbm3, yOsHi LiN and 2 others like this.
