Headlights. . .
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by tgpii, Apr 19, 2015.
  1. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    I have a Prius C 2 so it has the headlights but no driving/fog lights. Is it just me or do the headlights tend not to light up a lot?
  2. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    HID retrofit kits are common. They work well with the Toyota projectors to minimize glare.
  3. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    If you don't want to go the HID route (ballasts, rewiring, etc.), you can install modified 65w halogen H9 bulbs (link in my signature below). The H9 mod will give you approximately 50% more light over the 55w H11 bulbs that are standard.
  4. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    Throw some hids in the low beams and you'll be in love.
  5. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Don't worry much about fog lights. They just light up the sides and a little right in front of you. You get a good shot of people's trash cans as you drive past. Not much good if there isn't any fog.
    Couldn't tell you anything about a C2's headlights. I have the C4. They aren't too bad. I've had worse. I had to point them a little higher than the way they came. The cutoff just wasn't doing it for me...wasn't lighting up many signs or roadway.
  6. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    How do you "point" them higher? Is there an adjustment? Thanks.
  7. orenji
    orenji Senior Member
    5,884
    3,486
    Put more air in your tires! :D
  8. xliderider
    7,849
    3,103
    Honolulu, HI
    There is an adjustment bolt/screw in the back of the headlight housing. You can turn it with a socket wrench or with a Philips screwdriver.
    TC400 likes this.
  9. Mr Incredible
    955
    506
    Neb
    5/32" socket is what I used.
  10. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Yes I adjusted my headlights it helped immensely.
  11. kingnba6
    1,018
    242
    NY
    After installing HIDs, I actually had to aim my lights down.
  12. xliderider
    7,849
    3,103
    Honolulu, HI
    8 mm socket ;)
