Ottonavi HU: How to customize (a bit) the UI
Discussion in 'Gen 3 Prius Audio and Electronics' started by Bulle, Feb 12, 2012.
  1. cid batista
    cid batista New Member
    brazil
    good afternoon, sorry if I am posting in the wrong place. i'm a beginner.
    Please I need help. I bought a central multimedia roadrover for mercedes c200 (w204) installed in the aux. the original cd player.
    To access the CM follow the steps:
    1) click on the CD button on the original radio
    2) touch the screen to enter the CM
    3) touch the screen in "music"
    4) touch the screen in "usb"
    5) touch the screen in "Options"
    6) on the menu options choose "random"
    I would like the CM "remember" (?autosave comand?) the music that was playing before turning off the car. Or if possible when I access the CM go straight to the steps 3-4-5-6. I think some lines of code in the file "config.ini" can solve, or editing the skin by RUIEditor.
    Can you help me with that?
    Thank you,
    ( if anyone has the "guide commans" to program the file "config.ini" I9 the folder would be great. Thank you.)
    My file "config.ini" contains the following codes:
    language= int,8
    radio_advance= int,1
    radio_local= int,0
    radio_ta= int,1
    radio_xm= int,1
    Bt_name= string,"Bluetooth"
    language_pack= string,"EU2"
    no_game= int,0
    selected_skin= string,"\Storage Card\I9\Skins\BENZ_NOLOGO.rrui"
    time_zone= int,26
    day_saving_time= int,0
    time_24hours= int,1
    date_format= int,-1
    unit= int,16
    tpms_com_port= int,-1
    tpms_type= int,0
    car_recorder_port= int,-1
    bird_view= int,0
    car_device_port= int,-1
    ccd_radar_prior= int,1
    outsite_temp_unit= int,0
    fuel_consum_unit= int,0
    ipod_usb= int,0
    no_mp4= int,0
    no_exe= int,0
    no_pdf= int,1
    no_office= int,1
    no_navi_path= int,0
    no_rmvb= int,1
    no_ibook= int,0
    agent_title= string,"NetAgent"
    agent_path= string,"\NAND FLASH\Bin_CE\NetAgent.exe"
    accesory_name= string,"RoadRover"
    manufacturer= string,"RoadRover CO,LTD."
    model= string,"LC1X"
    firmware_version= int,10000
    hardware_version= int,10000
    artwork_height= int,128
    artwork_width= int,128
    support_ipod_video= int,0
    local_path= string,"\iNAND"
    ref_list_accord_disk= int,0
  2. Bulle
    Bulle Member
    378
    49
    Hi Cid,
    sorry; there is no easy way to do this right now.
    The only way (maybe) would be to start your own application from the registry and then send virtual keys or commands to the Roadrover Manager. Possibly that would work; but it's a lot of work to find out and assemble those keys.
    As for the .ini guide file, there is none that I know.
    The truth is that there are new keys with every new version so it's hard to keep track.
    I noticed you have a new skin file (BENZ_NOLOGO.rrui); it would be nice for you to share it with us to see what it looks like.
    cid batista likes this.
  3. cid batista
    brazil
    Thank Bulle, thought it would be an easy task. :(
  4. Bulle
    Bulle Member
    378
    49
    Thanks for sharing the skin!
    Stylish; with simple controls. Nice.
  5. cid batista
    brazil
    yes, it is beautiful in Mercedes.
    lack a button (music button) on the main screen that clicked open the mp3, set in random and play.
  6. Bulle
    Bulle Member
    378
    49
    Yes, very neat idea.
    If I can find some time, I'll try to work on it.
  7. Bulle
    Bulle Member
    378
    49
    Hi Laser,
    so I managed to find a way to test this new skin but I was wrong about the shell version number: it is 3.03.9.
    That's good because it means we can test your string changes before trying them in the RR unit.
    I will prepare soon a new txt and dat file for you to try.
    But in the mean time, it would be better for you to know which OS version you have.
    This is for you in case something goes wrong later; they will be useful for restoring your unit to original.
    So go to: Apps-Options-System and report to us the Shell, OS and MCU numbers you see there.
  8. cid batista
    brazil
    Shell: 2.90.8
    OS: EN-PRIMA-128-V1.76
    MCU: D6229FH62SH----V4.07
  9. cid batista
    brazil
    why the roadrover :eek: does not report the "command guide" of the command lines to the "config.ini"? Top Secret! rsrs
    I want to configure it to get into the mp3 player screen the standard stay at random (shuffle). I tried to invent a syntax with "random" and "shuffle" but could not.
    I also tried the Ruieditor but could not. Does anyone have any idea how to do?
    thank you (y)
    CM M1 Roadrover
    Mercedes C200 Class
    i9 / BENZ_NOLOGO.rrui
    RRUIEditor .rrui
    Config.ini
    Random Shuffle Repeat
  10. lasertechstore
    lasertechstore New Member
    Brazil
    any good news ??
  11. Bulle
    Bulle Member
    378
    49
    I was sure I had PM'ed you about it.
    No that won't be possible; not an easy task.
    Apparently the API has changed somewhat and further research would be needed to make this works.
    Sorry.
  12. VladimirRUS
    VladimirRUS New Member
    Russia, Volgograd
    2011 Nissan LEAF
    Tell me, where is the software radio, DVD. I want to modify the skin so that the program could have been further HOBDRIVE, MVButton? Can I do this? Is it possible to place the screen layout button on each screen skin. The main thing that I want to do is place as a "window in the window» HOBDRIVE, perhaps for many it will be interesting.
  13. Bulle
    Bulle Member
    378
    49
    Hello Vladimir, welcome on this forum!
    An easy way to install external WindowsCE apps is to simply *edit* the icons in the Main menu or the Apps menu.
    Basically you can press and hold for 4 seconds any icon slot (even empty slot) and a small popup will appear and let you browse and change the .exe filename. That would create the window in window effect you want IF the app has been correctly programmed for this.
    You will find more details in post #1 in the section *HOW TO CUSTOMIZE YOUR ICONS IN THE MAIN AND APPS SCREEN*.
    There might be another way of adding icons on any screen by using the RRUIEditor tool.
    But I never tried myself so I'm not sure if this will work; but that would be nice to know!
    Let us know!
  14. VladimirRUS
    Russia, Volgograd
    2011 Nissan LEAF
    [QUOTE = "Булле, должность: 2278536, член: 81877"] Привет Владимир, добро пожаловать на этом форуме!
    Самый простой способ установить внешние WindowsCE приложений, чтобы просто * * редактировать иконки в главном меню или в меню Apps.
    В общем, вы можете нажать и удерживать в течение 4 секунд любой слот значок (даже пустой слот) и небольшой всплывающих появится и позволит вам просматривать и изменять .exe файла. Это было создать окно в окно эффекта вы хотите, если приложение было правильно запрограммирован для этого.
    Вы найдете более подробную информацию в пост # 1 в разделе * как настроить иконок в главном и приложения экрана *.
    Там может быть другой способ добавления иконок на любом экране с помощью инструмента RRUIEditor.
    Но я никогда не пытался сам, так что я не уверен, если это будет работать; но это было бы приятно знать!
    Дайте нам знать! [/ QUOTE]
    Well, I'll talk about what I did. How to add an external application as I know, I have recently made. Understanding the inconvenience of use in this case, I planned to do just a skin in the attached file. I it is important that HOBDRDRIVE worked and was always on the screen, though you can easily use the radio, DVD, or other functions. Therefore, the skin will have exactly this kind has attached in the file.
  15. theblen
    theblen Junior Member
    Sabah, Malaysia
    it has been so long i visit here.
    one question please, my 'Movies' (video) wont play any media (mp4) anymore, be it from SD, USB or even transfered into the internal memory.
    used to play but suddenly cannot play and an error popup saying
    voFilter Error:
    Unknown Error (0XFFFF0004)
    how to reset this? :cry:
  16. Bulle
    Bulle Member
    378
    49
    Hello theben,
    The first thing to try is to restore the original files in the Filters folder from a USB drive.
    (They probably got corrupted somehow)
    IMPORTANT! Write down your MCU version, Windows version and UI Shell Version.
    (just in case you need to reinstall any of those)
    Then we will find the right package for you either here (post#1) or at China-RNS.com
    If that doesn't work, you may have to reinstall Windows, UI and settings; long process but not too difficult.
  17. AllMightyM15
    AllMightyM15 New Member
    Richmond, Virginia
    This looks pretty cool
  18. zml
    zml New Member
    NY
    I just bought a second hand Chevrolet Cruze with RoadRover(??) multimedia center.
    Hopping that there are still some people here that can help me...
    I found this info about the device
    OS: AR-PRIMA-ARM-SLC-V1.28 MCU:1.31CRZ5H9I-8F
    Don't know how to find the UI shell version
    The windows OS is CE 6.0 (3122)
    Have some questions:
    A) Can you tell me what is my device name / model?
    B) Can I make a full backup (and if needed a restore)? I could not copy the windows folder to my USB flash with CEcmd.exe
    C) Should I upgrade the system?
    D) Whenever my phone plays any sound (notifications, dial pad etc) the radio stops for some seconds,
    Is there a way to stop this and only allow it to jump to the Bluetooth on phone calls / real (long) media play back?
    Thanks,
    zml
  19. Bulle
    Bulle Member
    378
    49
    Hello zml, welcome to this thread.
    I believe the UI is the D2280 type (prior to the I9 interface).
    A) It would be easier to tell if you can post some pictures. But it looks like its a Roadrover first generation.
    You can also look at the folders in the Flash memory (there should be an I9 or D2280 folder for the UI).
    B) Good idea to do a backup! But no need to backup the Windows folder.
    But you do need to backup the storage card and the contents of the Flash memory.
    That should be in the NFlash folder (or something similar) I believe.
    C) Depends on what we find; I believe it's possible to upgrade to I9 with some units. A lot more info on: China-RNS.com .
    (It should be possible to upgrade at least the Windows OS, the MCU and may be the UI shell too.
    D) Not that I know; I believe it's by design.
    Good luck!
  20. zml
    zml New Member
    NY
    Bulle,
    Thanks for your fast replay and for this great thread!
    A) Yes I have a D2280 folder under: \StaticStore.
    B) Could not copy \touch_map_file to backup.
    I put the UI shell 2.85.2 in the USB card and managed to run it. The MCU version was blank, and I could not control the radio and connect to the Bluetooth.
    Where is this MCU file located?
    Could not run 2.78.10 – did a select -> run, but nothing happened.
    Took some photos (it was dark so they are not the best)
    ZML
