Were you told "There's No Such Thing as a Toyota Special Order?" Read This
Discussion in 'Dealers & Pricing' started by ggood, Jan 28, 2015.
  1. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Here is Toyota's description:
    "When the available Blind Spot Monitor detects a vehicle, it illuminates a warning indicator on the appropriate sideview mirror to help you know when it’s safe to change lanes. Rear Cross-Traffic Alert works in much the same way. When you slowly back out of a driveway or parking spot, it provides audible and visual indicators to warn you of approaching vehicles."
    The warning lights on the mirrors seem to work as advertised for BSM. They also flash for rear traffic alert. You eventually see things on the backup monitor, of course. Also beeps at you. Here's a video:
    #21 ggood, Apr 27, 2015
    48,945
    congrats! well done, all the best with your new hycam.(y)
    our 2013 hycam blind spot monitoring system went out in less than a year. we haven't had it repaired yet, because they looked at it and said they would need it for a whole day.
  3. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Do you have auto high beams on your 2013? If so, do they work well?
  4. bisco
    48,945
    no, i don't recall that being an option, although there was one package higher than others with the large screen, maybe it was on that, don't know. sounds like a nice option if it does work well.
