Prius C electric motor swap possible?
Discussion in 'Prius c Technical Discussion' started by Hyper_PriusC, Jun 28, 2013.
  1. Hyper_PriusC
    Hyper_PriusC Member
    83
    55
    San Jose, CA
    Has anyone looked into whether if it's possible to swap the Prius C 45kW (60hp) motor with a regular Prius 60kW(80hp) motor? Or any type of electrical performance upgrade?
    robertmaria likes this.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The two electric motors are part of the transmission. No way to swap them.
  3. Mendel Leisk
    38,247
    To answer your question directly:
    You're probably the first. ;)
    Hyper_PriusC likes this.
  4. Hyper_PriusC
    Hyper_PriusC Member
    83
    55
    San Jose, CA
    I see, Thanks for the reply
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Facetiousness doesn't translate into text... being more direct... he is not the first to ask... :D
  6. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    The Prius trans is larger overall and won't fit the downsized C engine or mounting locations.
    I guess you could always hack it, but you'll also need to alter the battery and control systems.
    You would be better off getting a Prius drive train and making your own car :cool:
  7. bisco
    48,987
    are you looking for:
    a) better mpg's
    b) more power
    c) more electric distance?
  8. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    D) All of the Above. :)
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    My answer is odd. In every Prius explanation I have read, (and I have NOT read one for the c) M/G2 is sized larger than the battery can supply and larger than M/G1 can supply, and in fact larger than both can supply.
    If this is also true of the c, then making M/G2 larger will not help.
  10. Mendel Leisk
    38,247
    Hyper_PriusC,
    You've "liked" my answer, I'm a bit embarrassed by it, sorry, it was smart-nice person.
    Seriously though, it doesn't seem a good idea, near-new vehicle, under warranty and all.
  11. PeterHaas
    PeterHaas Member
    152
    29
    Monterey Bay, CA
    The c (lower case) has a quite different HSD than earlier Priuses ... it is more like the Lexus HSD than the earlier Pruises in that there is NO CHAIN, and the double planetary gear system of the Lexus hybrid is employed, with the ICE input shaft having three planet gears (hence also the MG1) whereas the MG2 has five planet gears on its input, which only makes sense as MG2 is normally doing more work.
    The internal lubrication is quite different as well.
    Toyota document RM000004ELD010X is available on Toyota's site (16 pages), and goes into great detail about this new drive system, including diagrams showing the relative motions of all the shafts and other components in each of the drive's modes.
  12. bisco
    48,987
    so it is possible to swap motors? cool!(y)
  13. Motov8r
    Motov8r Member
    102
    I am thinking of putting the 5.7L V8 badge from my wife's sequoia on my c, will this enhance performance?
    iPhone ?
  14. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The battery will charge quicker.
  15. bisco
    48,987
    most definitely!(y)
  16. xpcman
    1,302
    295
    You will decrease MPG due to the extra weight
  17. Matt H
    Matt H Active Member
    164
    104
    Okinawa Japan
    2012 Aqua
    No.
    The C uses a completely different transmission than any other Toyota/Lexus hybrid. The exception is the Gen2 Prius engine to transmission bolt pattern might be the same, as they share the same base engine, but that's where it stops. No other HSD will even bolt to the C's engine.
    If you want hybrid boogie in your C, the best available option would be to swap a complete 2.4 liter system from the Lexus NX300h in. Extensive modification, and electronics know how will be required ;-)
  18. PeterHaas
    PeterHaas Member
    152
    29
    Monterey Bay, CA
    Sure, the basic 1NZ-FXE engines are the same, but the 1NZ-FXE was extensively updated for the Prius c by replacing all belt-driven subsystems with electric motors.
    These are 1NZ-FXEs in name only, and not in their specific implementation.
  19. Matt H
    164
    104
    Okinawa Japan
    2012 Aqua
    ...yes, the fact that the Gen1/2 and Prius C 1NZ's are about 70% different, as well as the the differences between the generation 2 and 3 HSD, as well as the differences between the P410 and P510 transmissions have been discussed ad infinitum on this forum.
    It's especially well known by those of us who own hybrid specialty repair shops.
    Don't take this the wrong way, as you may just not know, but everything you wrote in your original post that dug this two-year-old thread up from the dead, is pretty common knowledge here on Prius Chat. The member base here is very tech-savvy. There's not much that hasn't been written and discussed about the technical difference between the C and other HSD's.
    Cheers.
  20. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    I don't think it is likely to be possible. From what I read before Aqua was released that it was Gen II based, and that they specifically redesigned HSD and made it smaller and lighter than Gen3.
