Remove power window panel
Discussion in 'Prius v Main Forum' started by sean v4, May 23, 2015.
  1. sean v4
    sean v4 Junior Member
    Corona, CA
    2015 Prius v wagon
    Hi
    I wanted to removal the silver panel where the power window switch to paint them. Does that part just pop out? Do I have to remove the door panel if so how? I only see one screw where you pull to close the door.
    Thanks
    Sean
  2. JACoH
    JACoH Enjoying the mileage
    193
    40
    Oregon
    Yes, there is a screw below the rubber pad in the space where your fingers go to close the door. But that grey panel comes off upwards and towards you, pry with a plastic trim tool carefully at the back from that place where your fingers go to close the door, then progressively along the door toward you, I say carefully because the wiring is short underneath. You don't want to mess that up.
  3. sean v4
    Corona, CA
    2015 Prius v wagon
    Thank you. I give give that a try this weekend.
  4. tanasit
    tanasit Member
    399
    60
    Philadelphia
    This is what I did with mine using 3M di-noc carbon sheet.
  5. sean v4
    Corona, CA
    2015 Prius v wagon
    That's a great idea!
    Nice work tanasit.
  6. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Thanks and here is another one:
