What is the correct engine idle speed?
Discussion in 'Gen 2 Prius Technical Discussion' started by JC91006, May 26, 2015.
  1. JC91006
    JC91006 Senior Member
    16,470
    8,383
    I'm having an issue (on going) with my 2006 engine knocking when it idles. I notice this happens when the idle speed is around 980rpm. I'm not even sure if this is the correct idle speed for the car. There are certain times the car would idle around 1200rpm and it seems to idle correctly without any knocking sounds.
    Can someone tell me what's the correct idle speed? If it's not 980rpm, what could be causing the engine to idle at that level?
  2. ExMachina08
    ExMachina08 Junior Member
    72
    27
    United States
    My Gen 2 Idles anywhere from 960-1250. Is this knock coming from a cold start? During cold start the engine runs a different valve timing to facilitate faster warmup. Did you buy gas at somewhere other than your usual place? Cheap gas can have water or other impurities that can cause an engine knock. This can be alleviated with an octane boost and a refill with higher quality gas. Have you tried replacing your spark plugs yet? Spark plugs and wires replacement is usually a cheap and good place to start when troubleshooting detonation issues.
  3. JC91006
    16,470
    8,383
    The knocking only comes when the car idles slow at around 980rpm. This normally happens when the car is warm, cold starts, the car is forced to idle a little faster.
    It's more evident when I'm about to come to a stop......just before the engine shuts down. I used my techstream and checked, those are the times the car idles under 1000rpm. It also happens during inspection mode, when the car also idles slower at under 1000rpm
  4. ExMachina08
    72
    27
    United States
    I would say buy a bottle of octane boost from Napa and throw that in and then top off with fuel from chevron or another decent quality provider. If that fails look to the ignition system. Pull your plugs and look for scorching or buildup and then test the plug gap and make sure it is around .043" with the spark plug gauge you can pickup while you're at Napa. If your Prius is over 100k and you haven't replaced spark plugs and leads then its probably about time to do it, also look into replacing PCV valve while you have it open just to save some future time and it only costs a few bucks.
  5. JC91006
    16,470
    8,383
    This problem is not octane related, it's not that type of knocking sound. I keep up the maintenance on this car, all spark plugs, pcv, coolant, etc all done in a timely matter. I'm just not sure what would cause the engine to make this knocking sound at under 1000rpm and seem quite normal around 1200 rpm.
  6. Mendel Leisk
    38,252
    My gen 3 idles somewhere around 950~, as observed on ScanGauge. I forget exactly, I haven't had RPM showing for a while, but yeah: 9 something.
  7. JC91006
    16,470
    8,383
    so the knock seems to come when the engine is at it's proper idling speed. When it speeds up a bit to 1200rpm (cold idle), the faster rpm works to rid the sound. funny thing is, this car runs with no issues. very fast and responsive with a oil burning at 1qt/1500 miles.
  8. ExMachina08
    72
    27
    United States
    I would still at least pull your plugs and make a visual inspection. If it hasn't thrown a CEL it could be a number of things. I've seen cracked engine mounts cause the knock sensor to retard the timing and cause early detonations when idling due to the lower RPM and higher vibration in other cars. Do you have a video of your engine knocking? Have you considered replacing the knock sensor? If you're burning oil I wouldn't be surprised if you have carbon deposits on the head decreasing the space in the cylinder and causing early detonation. I would still try higher octane gas or an octane booster and see if the problem follows. It would at least rule that out.
  9. JC91006
    16,470
    8,383
    I made this a while back, this is what it sounds like at around 980 rpm
    At around 1200rpm
  10. ExMachina08
    72
    27
    United States
    That doesn't sound like knocking to me, it sounds more like a timing chain or valve tick. Have you ever had the engine run low on oil? You claim its burning 1qt/1500 miles. Its possible that the chain tensioner is going bad and creating some top end noise. Might be worth opening up the valve covers and checking for slack in the timing chain.
  11. JC91006
    16,470
    8,383
    I haven't messed with it since the car runs perfectly fine, just sounds like a clunker coming to a stop. I thought it could have been caused by the engine idling at the wrong speed. I'm pretty sure this engine has run low on oil, I bought it as a project and it had that sound since I bought it at 115k miles.
  12. ExMachina08
    72
    27
    United States
    Well the idle chain tensioner in these engines is supposed to last forever with proper maintenance, but I have heard of some premature failures related to poor oil changes or running out of oil. Definitely would look there first because it isn't particularly difficult to get the valve cover off and to check for play in the chain. Sounds very much mechanical to me and not detonation based.
  13. JC91006
    16,470
    8,383
    that probably would be a easier solution than to adjust valves, I will have my mechanic look into the chain. Thanks
  14. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Different idle speeds have to do with engine operation modes. http://techno-fandom.org/~hobbit/cars/training/800/valvetmg.png Since the noise is only heard in one mode maybe comes from the lose VVT-i unit? I think you can find some talk about VVT-i unit (also called intake cam gear) or its oil filtering screen on this forum.
  15. JC91006
    16,470
    8,383
    Someone had mentioned VVT-i to me before, I didn't know what that was in relation to the Prius engine. Thanks for the link
  16. JC91006
    16,470
    8,383
    Loose VVT-i unit would be like a loose timing chain tensioner? Easy fix if you can see it?
  17. Patrick Wong
    18,199
    6,464
    I agree that the sound is not a knock. I would not expect a knock to occur when the engine is running at an idle speed and not under load.
    Well, then if you feel the engine is working OK, then I suggest you just accept the noise since it only happens for brief periods as the engine is about to shut down.
    That would require replacing the intake camshaft sprocket which contains the variable valve timing mechanism, which would not be particularly easy.
    JC91006 likes this.
  18. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    I suppose that you are using 5W30 oil. If it is a lighter blend, 0W20 you may get a knock like that.
    If you have a scan gauge II you could check the oil pressure. If it drops low at the 960 idle, the oil has lost some viscosity or the oil pump is weak and needs replacing.
    Changing oil is easy, the oil pump is not.
    Then again I may be way off base.
    Does the mileage seem OK? If the timing chain has stretched that changes the valve timing resulting in bad mileage. This not a usual scenario though.
  19. Shinyside
    Shinyside Junior Member
    For anyone looking at this post all these years later(great video btw!) the issue here is a dirty throttle body. The butterfly flap gets gummed up and chokes the engine at low throttle. Easy 20-45min fix.
  20. AzusaPrius
    AzusaPrius Senior Member
    1,673
    772
