2012 Prius v (lowercase v) heater problem
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Littlei, Jun 30, 2015.
  1. Littlei
    Littlei Junior Member
    Chicago, IL
    I bought a new Prius v (lowercase v for the Prius v wagon) in 2012 & have hit 36,000 miles with no problems but now on chilly mornings when I want some heat, it only blows lukewarm air! Ex: Outside temp shows 63, I put it up to 75 and even after driving most of way to work, still blowing cool! Turned it up really high to 85 and slightly warmer. What's going on??!!
    Noticed no one in forum writes about this problem. Help. (n)
    48,862
    that's a stumper. could be the thermostat, or a clog in the system, or the damper not moving all the way. sonds like a trip to the dealer, or a decent mechanic.
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    Use auto mode. When its warmer outside it won't heat the air as much as when its cold out. You can't judge by the feel of the air coming out of the vents. Just set it at the temp you want it to be and don't worry about it unless you feel cold.
  4. Bashpriusv
    Bashpriusv New Member
    Montréal
    Have you solved your problem with heater? If so pls advise what was the issue because I have the same problem.
    Thanks
