CPO 2010 Prius LOW MPG After Major Repair
Discussion in 'Gen 3 Prius Fuel Economy' started by Dwijesh, Jul 3, 2015.
  1. Dwijesh
    Dwijesh New Member
    Antelope, CA
    So I went in to get a tire rotation and the dealer noticed an oil leak. Since it's a CPO I told them go ahead and fix it.
    Before the repair I was getting 42-44MPG after I got it back from the dealer I'm now getting 38.
    Summary of Repair:
    OIL LEAK AT INTERSECTION OF BLOCK, HEAD, AND TIMING COVER, RECOMMEND TO REPLACE HEADGASKET (INCLUDES TIMING COVER RESEAL)
    -ONLY FRONT COVER RESEAL AUTHORIZED, RESEALED FRONT COVER ONLY.
    TOYOTA EXTRA CARE AUTHORIZED TO REPLACE TIMING COVER GASKET ONLY AT THIS TIME. CUSTOMER TO HAVE CYLINDER HEAD GASKET REINSPECT AT NEXT OIL CHANGE SERVICE TO VERIFY OIL LEAK
    CUSTOMER STATES THAT THERE IS A LOUD NOISE/WHIRRLING FROM THE HOOD WHEN THE A/C IS ON. INSPECT AND ADVISE.
    INSPECTED FOR NOISE WITH A/C ON. COMPRESSOR DOES SOUND MUCH LOUDER THAN NORMAL,ALSO VIBRATES THE FRONT OF THE CAR SLIGHTLY. PERFORMED ACTIVE TEST, SPED UP TO MAX (7500RPM) AND NOISE IS MUCH WORSE. RECOMMEND TO REPLACE COMPRESSOR BEFORE CATASTROPHIC FAILURE OCCURS. ALSO REPLACE DRYER BAG/FILTER.
    TOYOTA EXTRA CARE AUTHORIZED TO REPLACE A/C COMPRESSOR AT THIS TIME. EVACUATE, RECLAIM AND RECHARGE AC SYSTEM W/R134
    So as you can see so much for buying a CPO I'm stuck with this car. Does anyone have any idea what could be the problem with this car.
  2. Mendel Leisk
    38,956
    How are you determining this mpg drop? How many miles, or tankfuls have accumulated, post- repair?
    Also what is "CPO"?
  3. OBJ
    OBJ Member
    62
    27
    Stouffville, Ontario, Canada
    CPO = Certified Pre Owned
  4. Dwijesh
    Dwijesh New Member
    Antelope, CA
    Thanks OBJ, yes CPO =Certified Pre-Owned
    I assumed they probably had the car going on and off during those repairs and I understand it could be low.
    So I refilled up my tank and now I am halfway through it.
  5. bisco
    49,799
    check your tyre pressures, oil level and 12 volt battery. sometimes, a rotation can affect mpg's for awhile.
    please let us know the outcome after you refill and manually calculate.
  6. Mendel Leisk
    38,956
    Reminds me: if you're running higher tire pressures, service depts are known for setting them back to spec.
