Brake Pads Wear According to the Dealer
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hhanna04, Jun 28, 2015.
  1. tpenny67
    tpenny67 Active Member
    464
    402
    Massachusetts, USA
    Wow, I used the word "neglect" once and suddenly I have a reputation for automotive abuse :) The point I was trying to make is that the problems I've had with cars generally haven't been due to lack of maintenance. Road salt? Yes. Pot holes? Yes. Cheap gasket that leaks antifreeze directly into the engine oil and sludges up the whole motor? Definitely. Actually, I'll take part blame for that last one as I knew it was using antifreeze, and was waiting for the leak to get bad enough to show a mechanic (oops!) Live and learn.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    ^^ you remind me how happy I am to have moved away from road salt.
    tpenny67 likes this.
  3. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    You're not alone, expensive lesson.
