Transmission problem or not
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kim Bromley, Jul 27, 2015.
  1. Kim Bromley
    Kim Bromley New Member
    I have a 2008 Prius with 135000 miles. A month ago the dash lit up like a Christmas tree so I called Toyota and they said to get it checked right away. It was after hours so Pep Boys looked at it and said they thought it was the tranny (or whatever it is called in the Prius) but they couldn't work on it and I needed to take it to a dealer. Picked it up the next morning and lights were all off so thought, make a go for it home 3 hours away. Got an hour out of town and lights came on and car slowly bogged down on the highway but I was able to limp to an exit and get off. Tow truck towed to nearest dealer. They said codes said it needed a transmission. They wanted about $5000 for a new Toyota tranny so opted for a used - 80,000 one for $2000. So things were going good for a month and then again, lights all came on and it bogged down. Had it towed to nearest dealer. They said codes said it needed a new tranny. Called dealer that put in tranny (which was an hour away) because it has a one year warranty. They said they would work it out with the other dealership. Called them back and they said they had talked to the place where the used transmission was purchased and apparently they told them to check something else and they then came up with no it wasn't the tranny but a different code came up and it was going to be another $2000! Called original dealer back and they said they would tow it to their dealership and check it out. They do a diagnostic on it and there are no codes - they can't find anything wrong. They said all codes were wiped clean when they installed the tranny previously and that there is no indication of any other codes since they replaced the tranny. That seems weird because all the warning lights came on when it broke down. And wouldn't the codes the other dealer saw be seen? Wouldn't the codes show up? They have had it for 4 days and still can't find anything wrong.
    1. I'm feeling like it was originally misdiagnosed and I paid for a tranny I didn't need.
    2. Why would the other dealer get two different codes?
    3. Why would the codes be cleared?
    4. What's wrong with my car? It's driving me nuts, not to mention the fact it keeps breaking down 3 hours away from home! Anybody with any ideas out there? HELP!
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Wait for more codes, the out of town dealership wiped them.
  3. Kim Bromley
    But the dealer that installed the new tranny has had the car for 4 days and no codes are showing up. It took a month for it to act up again. I'll probably end up picking it up because they can't find any codes, get half way home and break down again. That's my dilemma....
  4. SageBrush
    11,627
    2,530
    Southwest Colorado
    Having the car sit for four days is not going to bring out the problem.
    You have to drive it. I suggest not on long trips.
  5. JC91006
    JC91006 Senior Member
    16,470
    8,383
    ask for the codes you got from the 2nd dealer......then pass those codes to the dealer that put in the used transaxle. It could be a bad transaxle that was put in.
    are you the original owner of the car? any accidents?
  6. Kim Bromley
    They tell me they have been driving it as their courtesy car and the service manager is going to drive it 40 miles home tonight. Hopefullly something will kick in.
    Also, I did call the other dealer that got the codes but had to leave a message yesterday. He hasn't gotten back to me so I'll call again tomorrow. Good idea. I don't know why the dealers don't talk to one another..
  7. rjparker
    7,610
    4,464
  8. SageBrush
    11,627
    2,530
    Southwest Colorado
    Interesting information if true. It suggests a part eventually over-heats
  9. Kim Bromley
    That would make sense. I would think their techs could figure that out but I'm assuming the technology on these cars is such that no one has a handle on them yet. I suggested they call their Toyota Tech hot line. They did and the response was, they need a code!
  10. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    They told you that after the fact???
  11. JC91006
    16,470
    8,383
    you must have a better idea
  12. ILuvMyPriusToo
    778
    514
    Outside Philly, PA
    If I take my car in to the dealer for service, I would not expect them to turn my car into their loaner and not ask me first (or probably the folks driving it as a courtesy car) about that. Perhaps I am misunderstanding the post.
  13. JC91006
    16,470
    8,383
    I'm sure their meaning is "we've been putting all kinds of miles on the car to try and duplicate your problem. We even drive it home to add additional miles."
    How else are they going to duplicate something that requires driving? Give it to an Uber driver?
  14. Kim Bromley
    Yes, that's my understanding of what they are doing. They are trying to duplicate the problem by putting miles on the car. And yes, they told me that after the fact. I'm quickly loosing faith in Toyota.
  15. SageBrush
    11,627
    2,530
    Southwest Colorado
    I think you mean that specific dealership.
    In case you did not know, they are independent franchises.
  16. bisco
    48,995
    a tranny at 135k is very unusual.
  17. Kim Bromley
    Another day and still no answers. They want to hold on to my car and keep driving it until the problem materializes again. It took it a month and several hundred miles the last time. Surely they can go beyond their computer and figure this out.
  18. JC91006
    16,470
    8,383
    intermittent problems can point to bad wiring or ecu problem. I say trade it in before the problem comes back
